Buyer Beware: KTJO 4X4 Driver's Side Grab Handles w/ A Pillars, HUD, and Bowl Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Dec 13, 2019.
DAH Delivery Challenge
  1. Ordered?
    27.2%
  2. Received?
    37.9%
  3. Have to bend upper clip to fit?
    15.9%
  4. Missing Upper Cover?
    6.0%
  5. Missing Lower Cover?
    3.4%
  6. Incorrect Hardware?
    13.4%
  7. Scratches / Damage?
    9.9%
  8. Other (oh gawd)?
    20.7%
  9. Magically Perfect!
    25.4%
  10. Stuck in Shipping Label Created Purgatory?
    3.9%
  11. OGs Still Waiting since Before the Ban?
    7.3%
  12. Return Attempted?
    1.7%
  13. Return Actually Happened?
    3.0%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Jul 29, 2022 at 4:40 PM
    #6041
    Way Way Afar
    Way Way Afar Well-Known Member
    2022 TRD OR 4x4 DCSB AT
    Yeah, the simplest plan is the best plan.
    Also fits in the budget.
    tonered[OP] and tacoshell88 like this.
  2. Jul 29, 2022 at 7:44 PM
    #6042
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I did a couple years go. I had a small issue with installing the pins to the connector. I got it straightened out on one pin and had to do a little splicing on another. ensuring the proper orientation and making sure it is fully seated are key.
    The driver's side motor did go out on me after 1 year, and I had to replace it. I am not sure if it just went out on its own, or if an icy winter over worked it. So, i went ahead and put a manual switch under the arm rest to kill the circuit in the winter. During the winter, I turn off power to the system. The mirrors don't fold up, but the motors don't get over worked either. I just turn it back on in the spring.
    3rd Gen Tacoma Power Folding Mirrors | Page 24 | Tacoma World
    Power Folding Mirrors: Winter On/Off switch | Tacoma World
    RushT likes this.
  3. Jul 29, 2022 at 7:48 PM
    #6043
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    :cool:
    VicNic3 and Malvolio like this.
  4. Jul 29, 2022 at 8:14 PM
    #6044
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    Do you have a link or is there only one item that’s called “autozone speed nut”
    what makes this better than what a supplied?
    tell me why I googled OEM power folding :facepalm:mirror
    tonered[OP] and Malvolio[QUOTED] like this.
  5. Jul 29, 2022 at 8:37 PM
    #6045
    Way Way Afar
    See post 6030. It stays centered and doesn't move.
    venezian[QUOTED] likes this.
  6. Jul 29, 2022 at 9:06 PM
    #6046
    venezian
    Los Angeles
    2022 7545E
    thanks. Will pick this up tomorrow.
    Placed the order for the handle today and received a tracking number 3 hours later so that’s a good start.
  7. Jul 30, 2022 at 7:11 AM
    #6047
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
    Where did you get the other motor from?
  8. Jul 30, 2022 at 7:47 AM
    #6048
    fatboyfirebass
    Short answer I had to buy one from the seller.
    I made contact with the seller and explained the situation. I did a full diagnostic, (I documented with pictures for anyone else who runs into this issue), to be sure it was the motor, not a broken wire or bad fuse.
    I have the entire exchange saved. Her response was: "I have sent this to my vendor as well. I’m not sure what you could have done to be honest. I’ve had mine on since the beginning doing all the testing I’ve even doing and haven’t had one issue so I’m not sure. A new drivers side motor to replace that motor is $20...".
    The implication that I did something did sting a bit, as I hadn't done anything since install. But I needed the part more than I needed an argument.
    The install was a bit involved. I had to cut the wires feeding through the folding arm of the housing. Then splice in the new ones. I had to be careful to stager all the splices to be sure there wasn't a big knot in the middle of the bundle that would be in the barrel of the folding arm. It would have been too large to fit through. If anyone else ever has to do this, I recommend paste flux, solder and heat shrink. Crimped butt joints will just be too large to fit comfortably inside the housing. You can see the bundle of wires going down through the arm of the motor in the second picture below.
    Here is a picture of what it looks like when the motor fails, and screen shot of a portion of the information I sent her of what and how I tested when I was tracking it down. 1.jpg
  9. Aug 2, 2022 at 1:31 PM
    #6049
    venezian
    Los Angeles
    2022 7545E
    Delivered in 3 days.
    here’s my experience.
    I read the instructions on their website and watched this video - https://youtu.be/ckO4hbHoQGE
    NOTE: Do not start on the top bolt as the video instructs.
    1. Remove negative battery terminal
    2. Remove OE cover
    3. I purchased speed nuts from autozone based on recommendation on this thread, but I couldn’t use it because the supplied bolts were too small. I ended up using a little bit of masking tape to keep the supplied speed nut centered.
    4. Install new cover, start from bottom, line up the two tabs, it’ll settle into place.
    5. Notice the slight gap on the bottom between the handle and cover. I’m applying some pressure up and putting the bottom bolt in. I did a few turns just to keep it in place
    6. Here’s where it gets tricky. The angle for the top bolt is off. The trick is to apply pressure up on the handle while also twisting it counter clockwise. In the pic below you’ll see the bolt and washer is misaligned as I am NOT applying any pressure and twisting when I took the picture.
    7. So if you get the pressure and twist motion right, the bolt will screw in nicely. As you tighten the bolt, the cover will line up and sit flush nicely. Is the handle OE flush? No, but I’d say 98% there.
    Install time took me 10-15 minutes. Reading ahead and watching the video helped with the process.
    Overall, I’m happy with this mod.
    EDIT: Does anyone know how to get rid of the “ashyness” from the rubber? I tried to wipe off… lotion? lol
  10. Aug 2, 2022 at 4:28 PM
    #6050
    VicNic3
    GA
    Try Cleaning with soap and water.
    venezian likes this.
  11. Aug 3, 2022 at 10:12 AM
    #6051
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Nice install pics and insight. My truck had that ashyness when it was new as well - a few applications of chemical guys VRP and it is clean now.
  12. Aug 12, 2022 at 9:26 AM
    #6052
    VicNic3
    GA
    Started on the drivers side power folding mirror. With the Rav4 BlindSpot mirrors and MESO Puddle Pods and V5 Signal Lamps
    markram, shiftd and RyanDCLB like this.
  13. Aug 12, 2022 at 6:54 PM
    #6053
    PilotSmall
    PilotSmall Member
    ‘22 Lunar Rock Sport 6mt
    With much trepidation, I placed an order for the KTJO drivers side grab handle last Sunday night. Arrived today via USPS, one day earlier than expected. Popped it on in less than 15 min, using supplied hardware. Only “mod” was to smush the speednut a bit with plyers to fit snugly on the lower bracket. The handle fits better than I expected after reading many of the posts and reviews, and actually is pretty nice! I’d say she’s got this dialed in at this point.
    My install tips:
    Be sure the lower plastic tabs are lined up before seating the panel, it’s easy to miss align one of them.
    Center the lower speednut with an awl and be sure both bolts will begin to thread in before trying to install the handle. Gives you a idea of the strange angle they will need to be for final assembly.
    Use a 1/4” drive socket and a small ratchet, too easy to crack a windshield swinging a 3/8” ratchet!
    298E825A-F798-4548-A19C-C87EDD2524C8.jpg 8D61D78D-01FF-461E-A4DD-36DEBBF737E8.jpg
  14. Sep 9, 2022 at 5:18 PM
    #6054
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    BOMBS likes this.
  15. Sep 9, 2022 at 8:02 PM
    #6055
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Malvolio, tonered[OP] and MarkOne like this.
  16. Sep 9, 2022 at 8:38 PM
    #6056
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  17. Sep 10, 2022 at 11:34 AM
    #6057
    CttAznRanger
    Brandon
    Boston, MA
    Malvolio likes this.
  18. Sep 19, 2022 at 4:12 PM
    #6058
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Fool me once, shame on, shame on you. You fool me can't get fooled again... The KTJO4x4 grab handle V2-PKTCMGRAB-C0 came in. Ordered Friday night, shipped out Monday afternoon. All parts accounted for and no cosmetic damage.
    With V2, the lower fastener changed from an M6 clip nut to a tiny M3 (?) rivnut, and KTJO4x4 includes a ratcheting cinch gun. The screw seemed too small, so I left the old clip nut in place and used the M6 grab handle screw from my previous 2nd gen, P/N 90159-A0047.
    Installation with the deep-set bosses and short screws is indeed easier than V1. I found a shallow 10mm socket with 3" long 1/4" drive extension was handy for the lower screw. Fitment of the screw covers is flush and tighter than V1.
    tektaco84 likes this.
  19. Sep 20, 2022 at 12:03 PM
    #6059
    7068ca
    7068ca Member
    South Alabama
    2022 TRD Off Road, Access cab, silver
    Driver side grab handle installed, running boards,
    I ordered the new v2 grab handle on a Sunday. It was shipped and I received a tracking number the next day. Seven days later I received it. Installed it this morning. Took about 25 minutes. It looks like it came from the factory. They have install instructions on their web site with pictures and written instructions. I also found a video on you-tube. https://www.youtube.com/watch?v=h2psQwgwZbw
  20. Sep 20, 2022 at 12:25 PM
    #6060
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    Time for this thread to be put to bed. We will never support and endorse these products on TacomaWorld.
Thread Status:
