Buying a gen1 Tacoma, question about the 4wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by Horyfrock, Oct 8, 2011.
  1. Oct 8, 2011 at 7:29 PM
    Horyfrock
    Horyfrock [OP] New Member
    I'm currently looking at a Tacoma i would love to buy. I have a question about the 4wd shifter though. on all the gen1s i've seen, the shifter for 4wd has L4, N, H2, and H4 as options. This one, however, only has L4, N, and H. The only thing i could think of would be an all time 4wd system, and i didn't know that Tacomas were offered with that option. Thanks.
    Here's a picture, if that helps: http://img64.imageshack.us/img64/5222/22603819466308301586im1.jpg
  2. Oct 8, 2011 at 8:16 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    from my understanding the button on the side of the shifter engages 4hi then pull back to engage L4 and the reverse for go back to high 2. you are refering to the "J" shifter style which is what i have. i think thats how those work.
  3. Oct 8, 2011 at 8:20 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Yeah thats common its just the push button 4wd, still a part time 4wd follow all the rules of engaging it you normally do, it just uses an actuator on the transfer case to engage 4wd.
  4. Oct 8, 2011 at 8:21 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    if you look at your transfer case it should look like this
    with that contraption to the left of the flange
  5. Oct 8, 2011 at 8:22 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    This.
    The push button ones only have H (for both 4H & 2H), N and 4L. You can engage 4WD on the push button ones at speeds up to 50 or 60 mph.
  6. Oct 8, 2011 at 8:22 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    its 50
  7. Oct 8, 2011 at 8:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Yeah, there's been numerous threads on here about who has a "J" shifter and who has the button. There doesn't appear to be a consistent pattern to how Toyota decided which trucks get which method.
    Bottom line is, once you get past how 4Hi is engaged, they are the same.
  8. Oct 8, 2011 at 8:32 PM
    Horyfrock
    awesome, thanks so much guys.
