Buying my first Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tbaytaco, Mar 27, 2012.
  1. Mar 27, 2012 at 5:29 PM
    Tbaytaco
    Tbaytaco [OP] Well-Known Member
    Nolan
    Thunder bay
    O6 TRD sport
    Well, after hours and hours of reading on this forum, and hours of consulting google. I have decided to get an OME lift with 885's and rear dakar leaf pack. Just want to check quickly with people here as to anything I may be missing before I order it.
    OME lift from toytec w/ Rear 3 degree shims,
    885 Springs
    LR UCA's
    Spidertrax 1.25 wheel spacers
    NO top plate spacer
    anything else I need to get?
  2. Mar 27, 2012 at 6:35 PM
    Woodstocktaco
    Woodstocktaco Well-Known Member
    Woodstock, GA
    09 SR5 ORDC 4X4
    3" OME lift, 885 coils, Dakar rears, diff drop
    Sounds like you're good to go. Are you getting the spacers in anticipation of aftermarket wheels and bigger tires? You don't need them for stock wheels & tires.
  3. Mar 27, 2012 at 6:48 PM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    are you only getting the coils? any front or rear shocks? and I guess you are keeping your stock wheels cuz your getting spacers?
  4. Mar 27, 2012 at 7:07 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    All sounds good except for the wheel spacers. Why are you needing them?
  5. Mar 27, 2012 at 7:37 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    Im getting the entire OME kit springs and shocks was just stating that im getting the 885's because I have a double Cab. I thought I needed the wheel spacers for the stock wheels when lifted. I wanna get aftermarket eventually but currently am undecided and cannot afford them. So with stocks I do or Do not need spacers? Thanks
  6. Mar 27, 2012 at 7:37 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    Oh and are there any downsides to spacers?? Ive only heard good things and that they make your stance look bad ass.
  7. Mar 27, 2012 at 7:38 PM
    1GR
    Scott
    BC, Canada
    Unless you are getting bigger tires, spacers are not needed. Spacers /a different offset are needed for wider tires to clear the Upper control arm.
  8. Mar 27, 2012 at 7:41 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    5mm trim packer for the driver's side to help eliminate the taco lean
  9. Mar 27, 2012 at 7:47 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    Ah I knew I was forgetting something. Thanks alot!
  10. Mar 27, 2012 at 7:47 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    OK, But is there any actual downside to putting spacers on? I haven't found too much on the subject on TW.
  11. Mar 27, 2012 at 7:57 PM
    1GR
    Scott
    BC, Canada
    Yes. It increases wear on most components, more so on the wheel bearings then anything.
  12. Mar 27, 2012 at 9:01 PM
    especk
    Erik
    Redding, CA
    no prob
  13. Mar 28, 2012 at 6:56 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Sounds like a complete setup:thumbsup:
    I would try an avoid running spacers in the front if you can, doesn't hurt anything just cause more wear from the added strain on the front end.
  14. Mar 28, 2012 at 7:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Another set of lugs to make sure you have tight and they're inaccessible when the wheel is on the vehicle. Also, because they space your wheel out, they put more force on the wheel bearings and can cause them to wear out faster. Lots of people run them and you will find a that people are either pro-wheel spacers or anti-wheel spacers. There's not a lot of middle ground. Personally, I wouldn't want them on my truck.. Can you guess which side I'm on? :)
  15. Mar 28, 2012 at 12:22 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    I could be wrong but the 5mm trim packer should come with the kit...it did for me....I had toytec assemble them for me ...no need for a spring compressor...pop the stock assembly out and new ones in....also if u have them assemble it for u...it comes with all new bushings...worth it
  16. Mar 28, 2012 at 12:24 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    What are you doing for the rear OP ?
  17. Mar 28, 2012 at 12:32 PM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    he said dakar leaf packs
  18. Mar 28, 2012 at 12:34 PM
    OZ-T
    Peter North
    British Columbia
    My bad , I just reread the OP
    Thanks
  19. Mar 28, 2012 at 5:26 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    ya rear Dakars. Should give what did you say like 2 3/4 inches lift in rear? Im really excited to NOT bottom out on the highway with fishing gear in the bed. Very poor payload capacity.
  20. Mar 28, 2012 at 5:32 PM
    98regstick
    98regstick Well-Known Member
    Maryland
    '11 DCSB SR5
    OME 90021 with 885s and top plate spacer, 2" AAL, OME rear shocks, Camburg Uniball UCAs, OME CB Drop, 285/75/16 BFG AT's on Level 8 Guardian wheels
    Are you eventually going to move up in tire size?
