Buzzing when steering is at full lock
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Mar 25, 2011.
  1. Mar 25, 2011 at 10:35 AM
    x2468
    x2468 [OP] Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    I get a pronounced buzzing noise when ever I turn my steering wheel full left or right. Is that normal?
  2. Mar 25, 2011 at 10:54 AM
    KCin HBCA
    KCin HBCA Well-Known Member
    Keith
    Huntington Beach
    09 Dbl Cab PreRunner
    That is the sound of your PS pump straining its guts out. Once you hit full lock there is no place for the pressure to go and it builds up in the system.
    There isn't a pressure relief system in most PS systems, holding the wheels in the full lock position is not good for the PS pump. If I have to make a sharp turn and hit the stop I just back off the wheel to take the strain off the pump.
    Hope this helps...
  3. Mar 25, 2011 at 11:01 AM
    geoff06
    geoff06 261k and counting
    WI
    '01 PreRunner Xcab lifted
    3" lift, Bilstein 5100/OME coilovers, rear AAL, Swiss camper shell, Rough Country 9000 rear shocks, 265/75/16 AT's on stock steel rims painted black, All-Pro 1.5"F/1.25"R wheel spacers, airbox elbow mod, Flowmaster Super 44, Davico post-cat, I took off my DIY angle iron bed/light bar!, bed wheel well shovel-mount, blacked out grill emblem, Poineer DEH-P3900 head unit, Alpine Type R front component speakers, Pioneer Coaxial rears, Dynamat in door panels, scratchbuilt aluminum holders for my ipod nano and phone, and for some reason, I painted the headlight fillers black...
    thanks Keith, i've been wondering about that. figured it was not the best thing to have my steering at full lock making that noise. nice to know what the noise is
  4. Mar 25, 2011 at 11:04 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Smart man not many ppl know that.
  5. Mar 25, 2011 at 11:12 AM
    x2468
    Vermont
    My tiresare 265 michelin ltx m/s. so not very large. Usually when it makes the noise I jive the wheel back and forth like an F1 driver taking a turn so that the noise isnt constant.
    But should my truck be making the noise? Its normal right?
  6. Mar 25, 2011 at 11:18 AM
    KCin HBCA
    Keith
    Huntington Beach
    If the noise goes away once you get off full lock it should be ok. Prolonged stress will cause the PS pump to fail eventually. Just keep track of the fluid level for signs of leaks (other than the obvious drip) and smell of the oil (burnt means you've been doing it to much).
    Best advice... avoid full lock!
  7. Mar 26, 2011 at 8:52 AM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    Ya that noise is normal when your in full lock position. The noise will very from vehicle to vehicle, with some PS pumps making a sortof scrapping sound when fully locked to (like my truck and my dads truck) a buzzing sound. Tire size really shouldn't play apart in the noise, but does unfortunately add a bit more strain to the system.
