Bypass shock hoops
Discussion in 'Long Travel Suspension' started by dunerdude13, Aug 18, 2019.
  1. Aug 18, 2019 at 3:10 PM
    dunerdude13
    dunerdude13 [OP] Member
    Brady
    Chandler, AZ
    Blue 2017 Tacoma TRD sport
    Icon Vehicle Dynamics Coilovers with CDC. Icon Vehicle Dynamics Delta Joint UCA Fox Rear 2.0 Smooth Body Rear Shocks
    I’m wanting to add bypasses to my front camburg kit. I’ve heard of people having figment issues with camburgs hoops..That being said, can I use another manufactures shock hoop? Leaning towards dirt kings setup
  2. Aug 19, 2019 at 2:34 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    any hoop should work as long as it lines up with the lower mount. also, what issues have you heard?
    Dalandser likes this.
  3. Aug 20, 2019 at 5:12 PM
    dunerdude13
    Brady
    Chandler, AZ
    I’ve seen pictures of hoops where the tube running vertical doesn’t land on the frame. Not a big deal but would rather have a hoop I know will be 100% right.
  4. Aug 22, 2019 at 10:00 AM
    motoxscott
    motoxscott Well-Known Member Vendor
    Scott
    Socal -> Hurricane, UT
    2017 Tundra - 2008 Tacoma
    Camburg, FOX, Method, General Tire, Deaver
    @dunerdude13 We tuned up the bypass mounts and welding fixtures a little over a year ago to make installation easier and address some issues we'd see come up from time to time. Have had zero fitment issues with the newer versions. One of the main things we did was slot the mounting plate that fits on top of the coil bucket. That allows you to pivot it to the frame so everything lands flat and where it should. Your Toyota frame has slots and over-sized holes everywhere so it's far from perfect and consistent between trucks so when we make something too precise, it can have fitment issues on some trucks and not others. The pictures on our website are still of the older versions, haven't shot the new ones to update. We also spent alot of CAD and laser scan time with these as you can see in the pic below. I don't see any company building them better than what we have now.
    Scott @ Camburg
    tacotunner06, whatstcp, sicki and 5 others like this.
  5. Aug 25, 2019 at 8:38 AM
    dunerdude13
    Brady
    Chandler, AZ
    Thanks Scott, so if I order on your site the new design is what I’ll get? How soon would They be shipped?
  6. Aug 26, 2019 at 9:14 AM
    motoxscott
    Scott
    Yep, they are in-stock so they would ship right away.
    Scott @ Camburg
  7. Nov 21, 2019 at 11:02 AM
    sicki
    sicki Well-Known Member
    i get turned on when i see these photos pop up!
  8. Dec 6, 2019 at 8:40 PM
    Nickgbmx
    Nickgbmx Well-Known Member
    Nick
    2010 Tacoma Trd
    Check out Dirt King Fabrication top quality products
