Bypass Shock Tech
Discussion in 'AccuTune Off-Road' started by AccuTune Offroad, Mar 9, 2021.
  1. Mar 9, 2021 at 2:00 PM
    AccuTune Offroad
    AccuTune Offroad [OP] Well-Known Member Vendor
    El Cajon, CA
    Bypass Shocks PART 1
    • How do Bypass Shocks Work?
    • Shock Zones & Basic Tube Layout
    • Bottom Take Off Reservoir
    Bypass Shocks PART 2 | Release Date: March 23rd
    • Off the Shelf Options
    • Multiple Compression and Rebound Tubes
    • Staggered vs Overlapping Tubes
    • Piggyback vs Remote Reservoir
    Bypass Shocks PART 3 | Release Date: April 6th
    • Shock Diameter
    • Tube Layout Around Body
    • Tube Heights & Diameter
    • Custom Setup Recommendations
    Bypass Shocks PART 4 | Release Date: April 20th
    • Fox vs King Comparison
    • Check Valve Design
    • Pistons
    • Bypass Adjusters Screws
    • Piston Rods
    • Oil Seals
    Bypass Shocks PART 5 | Release Date: May 4th
    • Bypass Shock Setup
    • Up Travel
    • Motion Ratio – Coilover & Bypass
    • Total Weight
    • Weight Distribution (front/rear)
    • Unsprung Weight
