Cab Mount Chop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by memario1214, Oct 24, 2011.
  1. Oct 24, 2011 at 10:16 AM
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Has anyone got any pictures or a walkthrough even of everything that needs to be done? I am planning on a 3" OME lift, and I have some 33" tires to throw on. I know I will need to do dome trimming and cutting, but it's hard to look this good! Any help is appreciated
  2. Oct 24, 2011 at 10:24 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    What did you do for the pinch weld?, I need to do something with mine.
  3. Oct 24, 2011 at 10:27 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
  4. Oct 24, 2011 at 10:31 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Agreed I've done quite a few cab mount chops and I found stitch welding the plate on works the best at keeping everything from melting. And I always keep a bottle of water near me to cool the Cab mount faster.
    I just took the measurements of a cab mount Saturday to design a CNC cut plate for the cab mount chops to take the guess work out of cutting the plates yourself and try to keep the cost down to about what it would cost buying the steel at Home Depot.
  5. Oct 24, 2011 at 10:37 AM
    memario1214
    Colton
    Missoula, MT
    Thanks guys!
    And Kevin, your thread took out all of the confusion I had about this. Much appreciated!
    Jerry... I'm listening. tell me more
  6. Oct 24, 2011 at 10:38 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    np colton :D
  7. Oct 24, 2011 at 10:53 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Im running 33x12.5's. Needed to bash the shit out of the firewall with a sledge. The body mount is cut back to the top 2 bolts. Not plated...
  8. Oct 24, 2011 at 10:55 AM
    JLee
    Jerry
    Grass valley CA
    I'll work on the DXF tonight My measurements are as the shop and I'm not there or I would make one up right now. I'm thinking of doing them in 12g plate not quite 1/8th steel. That should be plenty strong all the cab mount chops I've done is with 1/8th plate and they are solid.
  9. Oct 24, 2011 at 11:05 AM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Count me in if you cut up some plates for the cab mount chops.
  10. Oct 24, 2011 at 11:10 AM
    JLee
    Jerry
    Grass valley CA
    Okay I'll let you guys know tonight or tomorrow.
  11. Oct 24, 2011 at 12:21 PM
    mhuff29
    mhuff29 TÅpƐwo®m
    Arvada, CO
    05 Tacoma Double Cab SR5
    Air Filter (K&N) Wheels & Tires
    x2
  12. Oct 24, 2011 at 12:29 PM
    JLee
    Jerry
    Grass valley CA
    I better get to designing then :D
  13. Dec 15, 2011 at 9:15 AM
    JLee
    Jerry
    Grass valley CA
  14. Dec 15, 2011 at 12:16 PM
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
  15. Dec 15, 2011 at 12:25 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    :eek:,is that your finished product????????
  16. Dec 15, 2011 at 12:29 PM
    memario1214
    Colton
    Missoula, MT
    That appears just cut, not plated
  17. Dec 15, 2011 at 12:56 PM
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Cut, not plated. Lots of sledge hammer beating. No swaybar with 33x12.5's on 3" lift.
    Probably wont plate it either. 1st time i did... no difference
  18. Dec 15, 2011 at 1:06 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    o...k...dokie
  19. Dec 15, 2011 at 1:11 PM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    here is mine for 35's - had to cut the ear off also.
  20. Dec 15, 2011 at 1:22 PM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    I have a 3" OME lift and 33" tires... I didn't have to do any cab mount chop's at all. The UCA rubbed pretty bad before spacers, and now with spacers it seems I will need to do a slight bit of trimming on the fender flares...
    I'm not sure if I'm special or not, but I was under the impression cab mount chops would only be necessary for 35"+ tires...
