Cab noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by First Taco, Oct 24, 2015.
  1. Nov 12, 2015 at 5:30 AM
    #101
    jimsmithrn
    jimsmithrn Well-Known Member
    Jim
    2016 Quicksand Tacoma TRD Off Road
    Mine is incredibly quiet. Of course, I moved over from a 15 y/o Jeep TJ so I feel like I'm in a luxury sedan! I've had others in the truck comment on how quiet it is though. Sounds like your truck has an issue. I'd bet that the rear vents are stuck open.
  2. Nov 12, 2015 at 5:30 AM
    #102
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I get a kick out of all of these "wind noise" & "loud cab" threads....it's a freakin' truck not a Cadillac.
  3. Nov 12, 2015 at 5:35 AM
    #103
    jimsmithrn
    Jim
    Sig45, I'd agree with you if Toyota didn't advertise the heck out of the quiet cab in the 2016. It's everywhere. If they're going to advertise it, they need to deliver it. I'm not complaining mind you. Mine is exceptionally quiet - for a truck.
    TacoBella likes this.
  4. Nov 12, 2015 at 5:39 AM
    #104
    Sig45
    Mark
    Maine
    My bad....I didn't realize I was in 3rd Gen section....still applies to 2nd Gen!
    TacoBella and jimsmithrn[QUOTED] like this.
  5. Nov 12, 2015 at 10:36 AM
    #105
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Here are some pics of MY solution... The vents fit very loose and sloppy (not now)...!! This solution has made a real difference, but so far I have not removed the masking tape from the vents....I'm gonna drive her this way for a while and get used to the sound and then remove the tape.....If any noise returns, I think it's by-by to some of these 8 vents.... Seems like I don't need them there now anyway..!
    This is the left side vent...note 4 flaps..!!
    Done...!! Note.. because the vents are a very loose fit....I sprayed liberally all around them to seal them in place. I think that was a main area of noise entry..
    I'll update after I get to drive her some.... Here is the product I used.... 1 can covered it fine...
  6. Nov 12, 2015 at 10:43 AM
    #106
    jimsmithrn
    Jim
    Are those pics from the inside of the cab?
  7. Nov 12, 2015 at 10:47 AM
    #107
    over60
    Muskoka, Ontario
    Yes.... the rear wall of the cab..
  8. Nov 12, 2015 at 11:49 AM
    #108
    alexderaven
    alexderaven Well-Known Member
    Alex
    Albuquerque, NM
    2016 MGM Tacoma Limited 4x4 (sold)
    JD, that is truly going above and beyond for some noise reduction. Let us know how big of a difference it is. If it works, I'd be curious to try this on the door panels as well.
    I married my tacoma likes this.
  9. Nov 12, 2015 at 4:42 PM
    #109
    LtTaco
    LtTaco Well-Known Member
    Tennessee
    2016 SuperWhite Limited 4X4
    I bet that smells terrible.
  10. Nov 12, 2015 at 4:59 PM
    #110
    Mothertrucker
    Mothertrucker Member
    Houston
    Dang I didn't know this! I hope the one I ordered is from the US!
  11. Nov 12, 2015 at 5:01 PM
    #111
    LtTaco
    Tennessee
    It doesn't matter. Mine was made south of the boarder.
  12. Nov 12, 2015 at 5:30 PM
    #112
    over60
    Muskoka, Ontario
    Not bad actually... I let it air out for the afternoon and then the next morning and now ...no smell...!!
  13. Nov 12, 2015 at 7:44 PM
    #113
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    Wow, nice work! How much effort was it to remove everything to get to the bare metal and vents? And does it go back together as easily as it comes off?
  14. Nov 13, 2015 at 7:25 PM
    #114
    over60
    Muskoka, Ontario
    No problem removing the hard plastic "bins"..(2 pieces)...3 small bolts each side. Then just pull at the left rear corner top and start to "pop" the plastic push pins that hold it to the metal rear wall. I think 3 or 4 on each side... don't be afraid... they will pop out and where that piece attaches to the right side part.. just pull and its out... same for right side... Then just a thin piece of crap 1/8" thick "sound deadening" (yeah right???) material that is held in by a few push plastic pins....
    You might break 1 or 2 of the shitty plastic red colored push pins on the hard plastic "bins"...(I did) when removing, but who cares... they are crap anyway, and not made for removal, just installation... My plan is when I decide to button everything back up... the plastic pins are gone and a good dab of silicone in those locations will be way better than OEM..
    Hope this helps... I've driven it a bit since the spray job.... It just snowed some here tonite..-2deg C.. I found out that I will need some ventilation to remove the moisture buildup from the interior windows and I'm planning on opening up about 1/2 of them and try that.
    The wifey even said..."you did a good job"... "I can notice about a 40-50% reduction in road noise... and that's with the rear seats still folded and nothing put back into place..
    I think I'll be happy as soon as I figure out how much ventilation is required.... I'm experimenting...!!
    I married my tacoma and wachuko like this.
  15. Nov 13, 2015 at 9:30 PM
    #115
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    I noticed the wind noise from the backseat on a 20 mile test drive (radio off of course), 2016 TRDOR DCSB 4x4 auto, 3 VIN, no tonneau, factory bedmat. Good job fixing it up, over60.
    No howling or whining sound, but a definite wind sound like the slider was cracked open a bit.
  16. Nov 13, 2015 at 9:53 PM
    #116
    cwpark529
    cwpark529 New Member
    2016 trd sport tacoma
    I got my first tacoma (16' double cab trd sport) and right away I noticed how bad the noise is when I'm driving. It is irritating the shit out of me as if I'm driving with my window open. Im gonna have to get mine checked. Can you tell me after you test drive another 16 tacoma?
    fatz likes this.
  17. Nov 14, 2015 at 10:36 AM
    #117
    over60
    Muskoka, Ontario
    I think you'll find they are all the same...that's just the way they are built. You will have to do something like I did or figure out another way.... Concentrate on those loose fitting vents on the rear of the cab....If you sir in back seat while on hwy. and drop 1 seat back...you'll figure it right away.
    Last night I could hear my tunes way better at Hwy. speed and at a lower volume level...!
  18. Nov 14, 2015 at 5:40 PM
    #118
    Gasmonkey
    Gasmonkey Well-Known Member
    20 dbcb offroad
    My 16 is silent aside from inclement wind and weather noise. The 13 wasn't any where near as pleasant to drive but, had typical " truck " type noises. I have to say I'm very pleased with the new 16. 1140 miles at present. Sorry to hear some of you are having these issues though.:itllbuffout:
  19. Nov 15, 2015 at 7:23 AM
    #119
    myke232
    myke232 Well-Known Member
    Drop 35+k on a new truck and have to do all that? yikes...
  20. Nov 19, 2015 at 7:58 AM
    #120
    First Taco
    First Taco [OP] Well-Known Member
    Robert
    Wa
    TRD Sport 4by4 4.0
    You have to be kidding? Going for the Darwin award? This was a new truck.
