Cabin Air Filter Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SouthernFried, May 7, 2021.
  1. May 7, 2021 at 4:57 PM
    SouthernFried
    SouthernFried [OP] Well-Known Member
    South Carolina
    2020 TRD OR DCSB
    Dealer told me mine is close to needing replacement at 8k miles and 1 year of ownership. Is this BS? Truck isn’t exposed to dusty conditions and has NEVER been off-road. A quick search online tells me that cabin air filters are typically good for 15-30k miles. While I am on the topic, what do you guys suggest for a replacement? Dealer wants $55 for theirs. I know I can get way cheaper online for something else. Is the K&N a good option, or is it just Chinese garbage?
  2. May 7, 2021 at 4:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Buy cheap ones unless you need to filter actual pollen.
    I blow mine out every oil change and replace it once its nasty.
    I only call them when the air filter is dirty as customers get pissed off like this lol.
    They always look dirty, very similar to a furnace filter.
    Kev250R and Junkhead like this.
  3. May 7, 2021 at 5:02 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I just take mine out and blow it out. Then reinstall. Takes five minutes. Will buy a new one in a few years.
    Junkhead likes this.
  4. May 7, 2021 at 5:02 PM
    2005 TRD Sport
    2005 TRD Sport Well-Known Member
    NM
    17 Black LTD
    Chrome step tubes, bed extender
    Inspect it first & see how it looks. Do it yourself. Standard filters are under $20 and YouTube has plenty of instructions. I did get a K&N and haven’t cleaned it in a while. If you go with K&N, keep the old one to use during future cleanings.
  5. May 7, 2021 at 5:02 PM
    SouthernFried
    South Carolina
    2020 TRD OR DCSB
    That was my original thought. When I was being told I already needed something replaced on something that is essentially brand new. My literal 2nd trip to the dealership for “Toyota Care”. I can already see what the future holds in their invoices 2 years from now.
  6. May 7, 2021 at 5:02 PM
    Tacospike
    Two Trucks
    check it first. If needed Do it yourself for a few bucks.
    Probably do not need a k&n
    Skydvrr likes this.
  7. May 7, 2021 at 5:06 PM
    Vacos Taco
    Vacos Taco Member
    2016 Tacoma TRD SPORT
    Cold air intake, MagnaFlow exhaust
    I have a K&N cabin filter, just wash and dry every 10k. Works for me.
    eurowner and SouthernFried[OP] like this.
  8. May 7, 2021 at 5:10 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Pull it out and take a look. They get black fairly quick. You can spray wash them with a garden hose.
  9. May 7, 2021 at 5:16 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Mine was disgusting at about 25k miles, I was very surprised actually. Also was surprised at the price of the new OEM, like 27$ I believe.
    shakerhood likes this.
  10. May 7, 2021 at 5:26 PM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    Amazon they are like 8 bucks for a fram replacement. I replace once a year since pollen is so bad. Cheap and makes a huge difference, 55 bucks is highway robbery!!!
  11. May 7, 2021 at 5:26 PM
    Sofasloth
    Sofasloth Well-Known Member
    2017 Tacoma Limited
  12. May 7, 2021 at 5:35 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
  13. May 7, 2021 at 5:48 PM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
  14. May 7, 2021 at 7:55 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I just bought one of these, my AC smells freakin' awful so I am going to spray disinfectant in there and put the new filter in.
    Junkhead and G8R_Taco[QUOTED] like this.
  15. May 7, 2021 at 8:19 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    Get some 90% IPA if you can find it (70% will work), put it in a spray bottle, pull that nasty filter and with the fan on medium or high, start spraying that shit into the fan area. Hit it heavy and then shut it off and let it cook. You will be ready to choke. Repeat a few times and pop that snazzy filter in there. :thumbsup:
    shakerhood[QUOTED] likes this.
  16. May 8, 2021 at 4:48 AM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    The 55
    It's not $55. It's the labor to pull it plus the filter. Most of the time they recommend something on time and or milage. If you are given a high number one gets scared it's a bigger job then it is. Unless it's an old Honda van, when you had to cut a steal flat support bar out that was in front of it with a grinding wheel or hacksaw the first time.
  17. May 8, 2021 at 6:13 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    The change it free at your 20k service.
  18. May 8, 2021 at 6:19 AM
    muskratX22
    muskratX22 Well-Known Member
    Dave
    Illinois
    I changed mine at 1 year and 11,000 miles. It was full of mice (dead and alive).
    vtwoodchuck likes this.
  19. May 8, 2021 at 6:49 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You already know the answer.
  20. May 8, 2021 at 6:56 AM
    Dr.Lou
    Dr.Lou Well-Known Member
    2016 TRD Off Road
    The dealer cabin filter change is another of their scams. It may indeed need changing, but at $200+ is silly. Had my 370Zs oil changed at the dealership, only because it was $10 with my oil and filter. Service tech told me my serpentine belt needed to be replaced at $300. It only had 30,000 miles on it and still looked fine. Same scenario for my Dodge Ram. Service tech told me my truck was due for it’s 50,000 mile service at a cost of $1200. Dodge doesn’t require a 50,000 mile service.
