Calibrating speedo for new tires?
Discussion in 'Wheels & Tires' started by Packman73, Nov 7, 2008.
  1. Nov 7, 2008 at 7:19 AM
    Packman73
    Packman73 [OP] ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I bought my truck as-is with the lift and larger tires. Is there a device that calibrates the speedometer? If so, how can I tell if I have one or that my speed is my actual speed without having the wife drive next to me on the highway? Thanks.
  2. Nov 7, 2008 at 7:21 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Hypertech makes an inline calibrator for our trucks - haven't used it or know too much about it.
  3. Nov 7, 2008 at 7:32 AM
    Packman73
    2007 TRD Off Road
    It may already have one on it...I just don't know where to look for it. :confused:
  4. Nov 7, 2008 at 7:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  5. Nov 7, 2008 at 7:55 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    You could also get the ScanGauge II. I have that and adjusted my speed for the percentage size change of my tires.
    Essentially, the difference was only about 2-3 MPH at 65. Before the tires, my speedo was 3 mph fast at 65. After the change in tire size, my speedo was 2-3 mph slow at 65.
  6. Nov 7, 2008 at 8:14 AM
    das56170
    das56170 Well-Known Member
    Temecula, CA
    2007 Tacoma Access Cab 4X4 SR5
    Flowmaster cat-back exhaust, volant cold air intake, 3" lift with AAL, 285/75 r 16 pro comp xterrains, 1" differential drop, spare tire mod, hypertech in-line speedometer calibrator, debadged
    I have the hypertech inline speedometer calibrator in my truck. It plugs in behind the speedometer. It takes a couple of minutes to hook up to your computer and enter the old and new tire sizes. Then it plugs in pretty easily. The only pain in the ass was taking the dash apart...and even that was pretty easy.
  7. Nov 7, 2008 at 8:16 AM
    myrcrocks
    myrcrocks The Reasonable One
    New Brunswick, Canada
    2009 Tacoma SR5
    So both of these units (Hypertech and Scanguage) will re-calibrate the speedo? What about the odometer? Approximate cost on each unit?
  8. Nov 7, 2008 at 8:22 AM
    das56170
    Temecula, CA
  9. Nov 7, 2008 at 8:32 AM
    LonghornTaco
    Minnesota
    +1. The scangauge only display information, however it's not just speed. It does ALL SORTS of stuff too! About $150-ish.
    I might look in to the hypertech if, for no other reason, to keep my odometer pretty dang close.
  10. Nov 7, 2008 at 8:35 AM
    myrcrocks
    2009 Tacoma SR5
    This is what I'm thinking...
  11. Nov 7, 2008 at 8:53 AM
    Packman73
    2007 TRD Off Road
    Thanks for the info. I'm assuming my speed is off.
    So, if I'm running oversized tires, does that mean that the odometer is recording less miles than the truck has actually traveled?
  12. Nov 7, 2008 at 9:06 AM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    I have 33's and according to my Scangauge the the odo is is reading correctly. Oddly the speedo still reads 2-3 mph fast
  13. Nov 7, 2008 at 9:10 AM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    yes -- assuming there isn't a speedo recalibrator installed.
  14. Nov 7, 2008 at 9:17 AM
    Packman73
    2007 TRD Off Road
    Ok, thanks. :)
  15. Nov 7, 2008 at 3:51 PM
    boogie
    boogie Well-Known Member
    south florida
    05 DC TRD Sport 2WD 6" Fabtec 951 Moto Metals
    bull bar, lift, rims ,tires,TRD floor mats,led interior bulbs, color matched bed cap
    FWIW....I recently put 35x12.5 x17's on my 05DC with a 6" lift. When my spedo showed 65mph my garmin showed 74mph.
    The 35's rubbed so badly I took the truck back to the installer and had them replaced with 33x12.5's.
    With the 33's the spedo and the garmin are almost in total agreement.
