caliper and other clearance issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wolftree, Oct 28, 2011.
  1. Oct 28, 2011 at 9:53 AM
    wolftree
    wolftree [OP] Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Is there any clearance or other issues using 1st generation Tacoma 6 lug 15 inch wheels on a 2nd generation Tacoma that was built for 16 inch wheels?
  2. Oct 28, 2011 at 9:55 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    I could be wrong, but that is going to be a tight fit on the calipers - even if you clearance them. I know it was going to be a huge PITA on my '99 4Runner when I considered running 15" rims.
    What are your reasons for going with a 15" rim? Cheaper tires?
    Fink
  3. Oct 28, 2011 at 9:56 AM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    I run 15" kmc enduros and there close but no issues and there known for running small on the inside
  4. Oct 28, 2011 at 10:24 AM
    Fink
    Orlando, FL
    On your 2nd gen?
    Fink
  5. Oct 28, 2011 at 12:52 PM
    wolftree
    Rick
    Ohio
    The reason I am inquiring. I sold all 5 of the Dunlop 245X75-16 OEM tires as they were trash, and replaced with 4 Michelin LTX M/S2 265X70-16. I know, I should have held onto the spare anyway. I have a 98 Tacoma wheel with a perfect Michelin LTX M/S but it is 15 inch. Until I can afford to buy another new / used Michelin 265-16 as a spare, I need a spare and wanted to use what I have.
  6. Oct 28, 2011 at 6:06 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Nope on my 1999
  7. Oct 29, 2011 at 1:02 PM
    Fink
    Orlando, FL
    Ok - I figured. He's wanting to run 1st gen wheels on a 2nd gen.
    Fink
  8. Oct 29, 2011 at 1:14 PM
    ratfink504
    ratfink504 Well-Known Member
    Paul
    New Orleans
    RIP 06 Tacoma Two Tone TRD Sport 4x4
    You can run 15" rims on a 2nd gen. I just put on 32x11.50r15 on mine 10 mins ago. I had to get 2" spacers for it to work... BUT! If I want to keep the I have to trim my fenders because I now have to make I 112 point turn to turn around =(. And they stick out like a mo fo
  9. Oct 29, 2011 at 3:26 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Oh got it I miss read the original post. Sorry about that
  10. Oct 29, 2011 at 5:33 PM
    wolftree
    Rick
    Ohio
    My problem is solved. My neighbor gave me a near new Michelin LTX M/S 255x70-16 that I can mount to my spare wheel. Thanks for you input everyone. It was better to find out here, than a dark, rainy night with a flat tire.
