calipers locked up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chromesides, Jan 17, 2014.
  1. Jan 17, 2014 at 3:00 PM
    chromesides
    chromesides [OP] New Member
    Milton Wa,
    06 TRD PreRunner
    So i had a little fender bender this morning(rear ended a semi trailer at very low speed) after the impact my front calipers are locked up?? i found if i remove the vacuum hose from the master cylinder it "hisses" and relieves the pressure and the calipers are free until i start the truck again and hit the brakes, then they lock up again.....anybody have any ideas??
    its a 06 double quad cab prerunner with the V6
  2. Jan 17, 2014 at 5:17 PM
    smd3
    smd3 Well-Known Member
    Hmm. There's a diaphragm in there, perhaps it's leaking/torn/damaged somehow.
  3. Jan 18, 2014 at 8:49 AM
    chromesides
    Milton Wa,
    06 TRD PreRunner
    I think something maybe bent? my foot was on the brake pedal when the impact happened, the tow truck driver seems to think the rod from the pedal to the master cylinder is bent?? Im going to check it out today
  4. Jan 18, 2014 at 10:08 AM
    smd3
    Perhaps, if that were the case I would think it would be easily noticed, and I'm not sure if it would explain why the brakes release when you release the vacuum.
    They'll figure it out with the rest of the repairs I'm sure.
  5. Jan 29, 2014 at 3:17 PM
    chromesides
    Milton Wa,
    06 TRD PreRunner
    Ok so truck has been in the dealership for 3 days now and there baffled...... there saying the calipers, rotors and pads need to be replaced......im not agreeing with this!
    its covered under the insurance claim so its no money out of pocket(except my deductible) but I still don't understand how its possible for the calipers to lock up then up and unlock when the vacuum is released? I don't think its the calipers???
  6. Jan 29, 2014 at 4:33 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Take it somewhere else they are clueless.
  7. Jan 31, 2014 at 7:19 PM
    smd3
    Any updates? I'm curious to see what the problem is or was.
