Caliraised light bar buffeting
Discussion in 'Lighting' started by Neil O, Sep 25, 2019.
  1. Sep 25, 2019 at 6:38 PM
    Neil O
    Neil O [OP] Active Member
    Neil
    Beverly MA
    08 quad cab 4x4
    Howdy
    Bought a caliraised 52" light bar and installed, love the light it throws, but the wind noise is driving me crazy! its not a whistling, its major vibrating buffeting. vibrates the heck out of the windshield and makes everything in the rearview mirror fuzzy. anyone have this issue? Any solutions besides turning up the radio?
    Thanks in advance
  2. Sep 25, 2019 at 6:39 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I've seen this cover that goes over roof light bars. Makes them aerodynamic. Kinda expensive tho. I'll try to find the link
    Neil O[QUOTED][OP] likes this.
  3. Sep 25, 2019 at 6:41 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    https://www.morris4x4center.com/aer...yYNDZrgPRpLW2EB2diN1FYDEgHNorXwMaAg9MEALw_wcB
    They make different sizes
  4. Sep 25, 2019 at 6:46 PM
    Neil O
    Neil
    Beverly MA
    08 quad cab 4x4
    damn, pricy!!! Thanks very much!
  5. Oct 24, 2019 at 4:31 PM
    TacoBuddy
    TacoBuddy New Member
    my old jeep had a light bar. Howled and whistled to no end. Very annoying. I got some foam weather stripping from HDepot and stuffed it in between the cooling fins on the rear of the light bar. Trimmed the excess so it fit flush... problem solved.
  6. Jun 1, 2020 at 7:03 AM
    Cyrusjj
    Cyrusjj SHREDITOR
    Charlotte NC
    2015 Tacoma Prerunner
    VICE UNLIMITED custom bumper PRP Race Seats Advanced Fiber Glass Bedsides and fenders Baja Kits Pre-Runner Long Travel Front suspension Kings 2.5 Reservoir Front Coil overs Total Chaos Gusseted front spindles Camburg Rear Bed Cage Camburg Spring Under Long Travel Rear Deaver Rear Leaf Packs Kings 18" Triple Bypass Rear Shocks Pedal Commander Tru-Trac diff 4.77 Re gear aFe Momentum Gt Intake System aFe Mach Force 3" Cat Back System Spider Trax 1.5" Rear spacers Full LED swap out throughout Shift Knob, Climate knobs, radio knobs Rear View relocation bracket Expedition Essentials 2TPAM USB Powered Accessory Mount All Pro IFS Skid Plate All Pro Apex Rock Sliders Kicker Q series speaker upgrade throughout Cerwin Vega 10" sub under Driver seat Alpine 4 channel X-A70F Amp under passenger seat. 1200 Watt Inverter Dynamat on floors and inner and outer doors HID Headlights Power Stop Drilled and Slotted Front rotors Ceramic brake pads BFG KO2 315/70 R17 Method NV Wheels Caliraised Light Bar Future Plans URD Supercharger
    Mine does the same thing, major buffeting around 60mph.
    I cut some pieces of rubber and put them between the fins, that solved the 30mph hi pitched whine.
    Gotta figure out a solution other than removal.
    danielgonzzz likes this.
