CaliRaised light bar with CH4x4 switch
Discussion in '3rd Gen. Tacomas (2016+)' started by keoniboy70, Oct 6, 2017.
  1. Oct 6, 2017 at 5:42 PM
    keoniboy70
    keoniboy70 [OP] Well-Known Member
    Cypress, TX
    2017 Tacoma TRD OffRoad 4x4 DCSB
    17x9 FUEL Nitro 6 wheels with G2 285/70 R17 tires Dobinson struts and coils with Deaver AAL JBA UCAs Warn Semi-Hidden winch mount Smittybilt XRC9.5 RockyHill sliders SprintBooster Pace Edwards Tonneau With Yakima bars and bike carriers TRD Pro grill UpTOP Bravo rack SP-9100 Meso mirror lights and interior mods
    hey guys I recently installed the CaliRaised light bar and I’m having some issues with the wiring for the CH4x4 switch. I connected the included harness from the light bar to the CH4x4 switch as follows:
    Black to black
    White to green/yellow
    Blue to red/yellow (closest to green/yellow)
    Last red/yellow from CH4x4 switch to add a line connector which I connected to the 5amp fuse for the dash lights.
    My problem is the truck icon light never turns off. The switch works properly in that it turns the light bar on and off but no matter what the icon indicator never turns off. The text below the icon seems to work properly. When I turn the truck lights on it comes on. When I turn the truck lights off the text turns off. The truck is completely off but the truck icon light is still on. Did I wire it incorrectly? Is it a bad switch? Any help or explanation would be greatly appreciated.
    TIA
    Mike_Lowrey562 likes this.
  2. Oct 6, 2017 at 5:43 PM
    9TRDTCO
    9TRDTCO Well-Known Member
  3. Oct 6, 2017 at 6:57 PM
    Mike_Lowrey562
    Mike_Lowrey562 Well-Known Member
    Long Beach, CA
    2016 TRD OR MGM
  4. Oct 6, 2017 at 7:31 PM
    keoniboy70
    Cypress, TX
    This is with the car on and the switch on.
    And this with the car off and the switch off.
  5. Oct 6, 2017 at 7:59 PM
    AKLA98
    AKLA98 Well-Known Member
    Liam
    Boulder, Colorado
    2016 Tacoma TRD OR DCSB MGM
    Bilstein 6112/5160 with Dakar Heavy Leafs, Snugtop Rebel (Windoors, Lighted), Prinsu TopRac, CVT Mt. Bachelor, Falken AT3W, Wheelers Super Bumps, Clazzio Covers, Hardwired Escort Radar, Husky Mats, Morimoto HID's, Baja Designs Yellow Fogs, Caliraised Bumper LED Bar, Interior LED's, Second Skin Deadening, Focal Speakers, PRO Grille, and much more...
    I have the same problem, installed mine two weeks ago. Truck hasn't ran out of battery yet.
  6. Oct 6, 2017 at 8:37 PM
    keoniboy70
    Cypress, TX
    Is it supposed to stay on? I thought it turned off if the truck was off?
  7. Oct 6, 2017 at 8:41 PM
    AKLA98
    Liam
    Boulder, Colorado
    Definitely not supposed to be this way. I am going to look into mine tomorrow, would imagine the problem lies on the switch side.
  8. Oct 6, 2017 at 8:47 PM
    keoniboy70
    Cypress, TX
    Thanks for looking into it.
  9. Oct 6, 2017 at 8:50 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    You're hard wiring it straight to the battery. Obviously it's going to stay on. There's nothing wrong with the switch.
    Rudyp.27 likes this.
  10. Oct 6, 2017 at 9:01 PM
    keoniboy70
    Cypress, TX
  11. Oct 6, 2017 at 9:59 PM
    SolarController
    SolarController Solar Control Window Tinting
    ATV
    2016 Tacoma Limited
    -A.R.E. Z Series cap with power unlock, sliding and folding front window, -Custom wired cap LEDs from Recon with liftgate switch to trigger when door is open (switched with OEM cargo switch and bypass option for the liftgate switch) -LED Interior Dome Lights -Phillips LED Extreme Reverse Light -PIAA LED 6000k Headlights -PIAA LED 3000k Foglights -Cali Raised 31 in. LED Light Bar w CH4x4 push switch -Tint measures 5% in rear, 10% front doors, 5% top and bottom strips on windshield, under 5% on the cap glass. (Undone)-DRL mod to delete dimming when Headlights on -Debadged (Limited badge blacked out and moved onto the cap) -Piano Black Tacoma inserts on tailgate -Chrome delete on mirrors, grill surround trim, and fog light bezel with Avery Black Brushed Metal Vinyl Wrap. -Black vinyl delete from door pillars -Color Matched rain guards (out channel AVS) bug guard, and engine cover -ABS Thermoformed front Toyota and side Limited emblem. -HS MegaBlast Air Horn Kit. -K&N Drop-in filter -Pop and Lock power tailgate -Ceramic Coating Silver Package -Circuit breaker and fuse panel for electrical accessory protection -OEM TRD skid plate install -ARB OBA Single compressor installed onto the D/S deck rail (no tank needed) -CaliRaised Molle Panel, Full P/S Suspension: -OME HD Dakars -OME 888s -Bilstein 5100s all around, bottom setting -SPC UCAs
    If you turn the headlights completely off then it should turn off. I spliced my wire to the "illuminate" cargo switch right next to it. Also you should have the relay powered with the parking lights so the bar will turn off automatically if you accidentally leave it on.
    bertle likes this.
  12. Oct 7, 2017 at 1:21 AM
    cosmic_3000
    cosmic_3000 Active Member
    Alaska
    '17 OR DCLB w/ JBL
    The Caliraised wiring harness connects directly to the battery, so basically it is always hot. Does your light bar turn on with the truck turned off when you flip the switch?
  13. Oct 7, 2017 at 1:53 AM
    TAF_Taco
    TAF_Taco Well-Known Member
    Patrick
    Lacey, Wa.
    17 TRD Sport Access Cab
    17" Method NV w/BFG KO2 CVT Rainier RCI bed rack Empyre Off Road grille Cali Raised bumper light bar/fogs
    Switch what the white and blue wires are connected to and see if that works. I had the same issue last week and that fixed it.
    keoniboy70 [OP] likes this.
  14. Oct 7, 2017 at 7:56 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    2017 SR5
    It should always be hot, but it shouldn't always be lit.
    It should still only light up when pushed in.
    I REALLY wish someone would make a simple single LED, three wire switch that was OEM styled.
    All these ditch light and bar harnesses are completely random colors it seems and it's a major PITA.
  15. Oct 7, 2017 at 9:14 PM
    keoniboy70
    Cypress, TX
    I did this and the world is right again! Thanks again!
    TAF_Taco likes this.
  16. Oct 9, 2017 at 12:06 AM
    TAF_Taco
    Patrick
    Lacey, Wa.
    Glad to hear.
  17. Oct 9, 2017 at 3:16 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Sounds like your wire harness is like mine. White is power to switch and blue is trigger to relay. On this harness cut the white and hook the switch side to an ignition on fuse in box using an add-a-tap. The way these harness are wired they get power to switch off the relay.
  18. Mar 14, 2018 at 9:50 AM
    bangers
    bangers Active Member
    2006 Tacoma
    I just posted a related question. I looks like in your video you may have both your light bar and ditch lights hooked into the same add a fuse. Is that the case? Would you consider adding a third to the same add a fuse. Any risk?
  19. Aug 22, 2020 at 9:33 AM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    which fuse under the dash is for the switch lights when you turn your headlights on?
  20. Sep 1, 2020 at 6:00 PM
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    In a similar situation here - I have two CH4x4 rocker switches installed for a dual function LED light bar, and everything about the switches functions properly except for the text not lighting up. Light within the switch for the logo turns on when activated, and lightbar activates just fine, but the text beneath the logo doesn’t ever turn on.
    Where can I tap into, or add a fuse for two rocker switches to have the text light up when the car is on? I also have an ARB rocker switch that functions perfectly all around. Can I tap into the wire that the ARB switch uses for constant power?
