CaliRaised Molle and Bed Cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DesertPreRunner, Apr 17, 2025.
  1. Apr 17, 2025 at 12:22 AM
    DesertPreRunner
    DesertPreRunner [OP] Member
    2011 PreRunner
    Hey folks, I am looking into getting the CaliRaised Front Bed Molle System (https://caliraisedoffroad.com/produ...front-bed-molle-system?variant=43782513295606) for my Taco. I am also considering getting some type of cover for the bed, likely a Gator SFX Tri Fold (https://realtruck.com/p/gator-sfx-tri-fold-tonneau-cover/v/toyota/tacoma/2011/) or a TonnoPro Tri Fold (https://realtruck.com/p/tonnopro-tri-fold-tonneau-cover/v/toyota/tacoma/2011/). My question is, are these two mods compatible? I couldn’t find a concrete answer on either website. I don’t want to buy a cover if it will not be able to be installed due to the Molle system utilizing the same bolts along the top of the bed. Any thoughts/suggestions are appreciated.
  2. Apr 17, 2025 at 5:49 PM
    Hay Lobos
    Hay Lobos Let's be friends.
    Ben
    The Great State of Maine
    2013 Tacoma SR5 Access cab
    My tri-fold attaches to the rail about 8 inches back from the nose end of the bed, and I don't think it would interfere, although it might not seal flush if it has to ride over the thin metal plates from the MOLLE rack. The tonneau frame is flexible enough that it would just lay over anything less than half an inch IMO.
    Does the front panel attach to the accessory rail on the bed sides, or require bolts down into the top of the bed sides? If it goes on the rail I think the clearance is probably fine.
    I think you should reach out to Caliraised via email and ask them.
    DesertPreRunner[OP] likes this.
  3. Apr 17, 2025 at 7:07 PM
    DesertPreRunner
    2011 PreRunner
    I believe it only attaches to the accessory rail, without bolting on the top, meaning it would likely work. I will email them, just to double check the fitment. I appreciate the help!
    Hay Lobos likes this.
  4. Apr 18, 2025 at 8:27 PM
    Hay Lobos
    Ben
  5. Apr 19, 2025 at 3:15 PM
    DesertPreRunner
    2011 PreRunner
    that’s sweet, I’ll definitely look into that
