Called Toyota about leaf spring recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evile, Oct 1, 2014.
  1. Jun 18, 2016 at 5:29 PM
    #421
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    I hope you find your overload springs. I read through a couple of threads and members that did have the old leaf pack with AAL's they were able to get them replaced and the dealer just gave the AAL back to the owner as they will not install the AAL with the new leaf packs. It feels like the dealer is just giving you the run around. If there's another dealer you can try , you should check with them as well. If dealers are giving you a hard time I would call corporate Toyota and open a case.
  2. Jun 20, 2016 at 10:15 AM
    #422
    sccurran
    sccurran Member
    Las Vegas, NV
    06 Tacoma SR5 V6 4X4 Access Cab
    RevTek coil spacers with All Pro add a leaf
    Thanks, I did find the overload springs but not the center pin. I called another dealer who sounded much more reasonable saying they could install my AAL's & will only charge for the additional labor involved and possibly new u-bolts and center pin if needed. That sounds fair to me. They just had to order the fit kit which will take a week or two...
    TRDSport10 likes this.
  3. Jun 21, 2016 at 10:27 AM
    #423
    matadorCE
    matadorCE Well-Known Member
    Melbourne, FL
    '05 Prerunner Accesscab TRD Offroad
    I got the letter in the mail yesterday. So do they do an inspection first (and of what?) and then they determine if they're going to change parts or do they just put a new leaf pack on? From the way the letter reads it seems they're putting new hardware but now I'm confused since people are saying they got an inspection then it was a wait for the parts to come in?
  4. Jun 21, 2016 at 10:37 AM
    #424
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    WP_20160620_10_40_52_Pro_LI.jpg a few hundred pounds in the back with stock suspension and the new leafs. Fine by me. Oh and 265/70/17 tires
  5. Jun 21, 2016 at 10:54 AM
    #425
    TRlPPlN
    Honestly im not even sure why they need to inspect the truck. I made my appointment, they looked and said yep we need to order them since they don't stock the leaf packs. They looked at how many clips are on it and that was it. They'll put a new set of leafpacks + hardware required.
    looks like yours is good to go. did it look like you lost a little bit of rake with out the load?
  6. Jun 21, 2016 at 11:22 AM
    #426
    sccurran
    sccurran Member
    Las Vegas, NV
    From what I understand they replace the whole leaf pack free of charge as long as it's stock. If you have AAL's or lift blocks they charge for the additional labor and hardware (if needed). But I had to call 3 different dealers to get that info. First place quoted close to $500, last place quoted just under $200, because I have AAL's. Haven't called Toyota corporate yet but going to see if they tell me something different...
  7. Jun 21, 2016 at 11:42 AM
    #427
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Just got new leafs installed today
    I sit 1.5" lower now.
    Time for an AAL
  8. Jun 21, 2016 at 12:39 PM
    #428
    matadorCE
    Melbourne, FL
    Yep, seems like a waste of time to make us come in only to be told "come back when we have parts". But it's free and we've been waiting like 2 years for the fix so I guess jumping through some hoops is to be expected.
  9. Jun 21, 2016 at 12:51 PM
    #429
    FLnative
    FLnative Member
    I currently have Bilstein 5100's on all four corners with the front shocks are set at 1.75" and the TSB 4 leaf springs in the rear. As she sits, I'm happy with the ride and the height even with my topper.
    I recently got the leaf spring safety recall letter, but I am not sure if I should go through with it after reading most of these posts. Is the consensus keep the original TSB leaf pack if you have it?
    It would be very annoying to get the new springs and then have to purchase an AAL.
  10. Jun 21, 2016 at 12:57 PM
    #430
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    The new springs definitely sit lower but I think they hold up to the weight a little better.
  11. Jun 21, 2016 at 1:14 PM
    #431
    5.0 Hatch
    5.0 Hatch Well-Known Member
    Got my letter yesterday here in Louisiana. Called dealer first thing this morning and they said that the parts are in stock and to drop it off in the morning. No inspection needed...
  12. Jun 21, 2016 at 2:41 PM
    #432
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    get airbags, solve all height and payload issues :) :thumbsup:
    Oregon TRD likes this.
  13. Jun 22, 2016 at 11:27 AM
    #433
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
    (I haven't read the whole thread yet) @alan did Toyota reimburse your lift? After jumping through a ton of paperwork hoops, they denied me. I'm going to call Friday to complain
  14. Jun 22, 2016 at 12:37 PM
    #434
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    Pretty much what I'm gonna do. New shit springs with the Ride Rite kit.
  15. Jun 22, 2016 at 1:03 PM
    #435
    fredlyzone
    fredlyzone Member
    Fred
    Austin, Texas
    2010 Tacoma PreRunner 4x2 TRD Off Road w/JBL
    Bilstein 5150, Stereo upgrade
    So is the consensus that you need to remove your AAL before you have Toyota do the swap? I wouldn't want to pay them to do to recall work!
    Fred
  16. Jun 22, 2016 at 4:25 PM
    #436
    inesshell
    probably have to extend the axle mount with a spacer like i will have to eventually. Probably something for this weekend, i have been putting it off for a year but it hasnt done any harm to the truck so far.
    Oregon TRD[QUOTED] likes this.
  17. Jun 22, 2016 at 4:33 PM
    #437
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Thinking about doing this .. not sure which air bag to use though .. any advice .. :confused: ..... Thanks
  18. Jun 22, 2016 at 5:33 PM
    #438
    TRlPPlN
    I was thinking of getting airbags but since I don't tow or haul heavy stuff that much but will always have a camper shell on I think I'm going to try these with my recall leaf pack.
    http://www.supersprings.com/
  19. Jun 22, 2016 at 5:52 PM
    #439
    Glamis
    Glamis date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    i love my air bags. I have had them for years. I got them right after the !st TSB springs. I can tow my trailer at stock height and makes the truck handle grate wile towing.. My dealer is making me take them off before i get this set of spring. I did fight to have them order the parts with the bags on the truck. I tow with my truck on the weekends.
  20. Jun 22, 2016 at 6:21 PM
    #440
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
