Called Toyota about leaf spring recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evile, Oct 1, 2014.
  1. Aug 18, 2016 at 5:33 AM
    #581
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Did Toyota actually install recall springs on your truck? If they did I don't think you'd be eligible for a reimbursement. That's done if you had to replace the springs before the recall was done and even then it's going to be a little bit of a battle because they may want you to prove you replaced them due to a defect.
    Toyota's recall isn't about the negative arch or spring rate of the packs but the number of clamps, so from their perspective the ride height is irrelevant just as long as they are considered "safe" if an individual leaf breaks.
  2. Aug 18, 2016 at 5:42 AM
    #582
    MNPhildo
    MNPhildo Active Member
    Phil
    Minnesota
    07 TRD SR5 4dr Longbed
    Leer Topper
    Lameski...
    DaveInDenver likes this.
  3. Aug 18, 2016 at 6:10 AM
    #583
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    I have an appt to get my springs checked today, then they said 3-4 weeks for parts after that...all i see are bad things about these...should i just keep the regular 3 pack that is already on my truck and say screw it?
  4. Aug 18, 2016 at 6:12 AM
    #584
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    Are any of you guys getting replacements out of warranty period?
  5. Aug 18, 2016 at 6:22 AM
    #585
    Chris24
    Greensboro, NC
    It's a recall, so warranty doesn't matter. I'm at 90k miles and out of all warranties and i got all the recall letters about bringing my truck in.
  6. Aug 18, 2016 at 6:32 AM
    #586
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    I did not receive any letter... My springs SUCK.
    asuchemist likes this.
  7. Aug 18, 2016 at 6:37 AM
    #587
    cathodebiased
    cathodebiased Member
    Richmond, VA
    2008 Super White Access Cab 4x4 - 2.7L - 5-speed
    Getting in on this discussion...
    I recently picked up a 2008 AC that has had some sort of lift done on it, looks like 5100's all around and the front springs seem pretty stiff(not sure how to identify them). Rear leafs look brand new, I'm guessing the dealer did the recall before I bought it, it is a 4 leaf pack.
    Truck sat level when I bought it. Then I just picked up a shell and rack for the shell this week. Rear of truck now sits about an inch lower than the front, and the rear leafs are completely flat.
    Question is, will one of the 3 leaf progressive AAL's get me the additional lift I need and correct the flat leaf issue? I need at least an inch of lift just to level it with the shell installed, and that's not including any additional cargo in the back, so ideally, I'd probably be looking for 1.5"-2" of lift in the rear.
  8. Aug 18, 2016 at 6:38 AM
    #588
    Chris24
    Greensboro, NC
    i would call a local dealership and get them to run your Vin# to check
  9. Aug 18, 2016 at 6:50 AM
    #589
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I would take advantage of the recall. I had 3-leaf OE packs and found the recall springs were an improvement in ride. You'll get 4-leaf packs although it seems they are not really much increase in spring rate. I got a slightly lift, maybe 0.5 inch, but I also have a camper shell. It's only a couple of days out of your life for the inspection and work. They didn't keep my truck for a month waiting on springs.
    Chris24[QUOTED] likes this.
  10. Aug 18, 2016 at 6:56 AM
    #590
    Chris24
    Greensboro, NC
    Thanks...just sucks i have to go get them inspected since the latest appt they offer is 3pm, which means i have to leave work early and drive 40 minutes...but hopefully they'll be worth it, lol
  11. Aug 18, 2016 at 7:38 AM
    #591
    MNPhildo
    Phil
    Minnesota
    Leer Topper
    Is your truck an AC shortbed? Mine is a DC longbed with a topper and my recall Springs are bent all the way down to a frown (with nothing in the bed). If I put my ice house on, I'd be riding on the bumpstops. I really wish I had left my old rusted OEM 3 leaf pack (with an AAL) in instead of getting the recall. Now I forked up the $ on some quality old man emu leafsprings
  12. Aug 18, 2016 at 7:47 AM
    #592
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Access Cab with 6 foot bed. My original 3 leaf packs were badly negatively arched and the recall springs weren't that much better. They weren't flat like I'd expect at least. Like I say I don't think Toyota is uprating the springs to be equivalent with the TSB springs for load capacity.
    I still replaced them (I have standard Dakars, no extra leaf). I prefer the ride to be truck-like and it is with the OME, so I'm happy with them. But the original OEM 3-leaf springs rode just terrible and I thought the replacements were an improvement. It also turned out that one of my shocks was bad so even with a dead shock the recall springs were noticeably better.
    I'd guess you'd be happy with the recall springs with AAL put in. Plus there's a peace of mind I suppose that you'll have more clamps on the main pack, which all things equal is better than not having them.
    Chris24 likes this.
  13. Aug 18, 2016 at 12:53 PM
    #593
    KJM_SLC
    KJM_SLC Member
    I have the 4 leaf TSB on my 2006 AC and took it in for this. They said that since I have the TSB they didn't need to do the recall.
    Anyone else run into this? Do I actually need the recall?
  14. Aug 18, 2016 at 1:15 PM
    #594
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    as I remember, this new recall has to do with springs that only have 2-3 spring keepers. the new springs have 4 keepers.
  15. Aug 18, 2016 at 1:22 PM
    #595
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    If your TSB springs have 3 retaining clips per side, then you are included in the recall. The correct recall spring part # is 04005-34404. Don't let them BS you into getting the 04005-34305 springs; read your recall letter carefully. I am still waiting for my 34404 springs after 3 trips to the dealer and arguing with them that the 34404 springs replace the TSB 4-leaf set.
  16. Aug 18, 2016 at 1:33 PM
    #596
    KJM_SLC
    KJM_SLC Member
    I have the 4 retaining clips I believe and purchased the truck in 2014 so I'm not sure when it was completed. I would have to check part numbers to see which springs are in there now though. Thanks for the replies.
  17. Aug 18, 2016 at 1:35 PM
    #597
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    are the springs the same for a TRD Off Road ?
  18. Aug 18, 2016 at 2:16 PM
    #598
    nasaengr
    Red15 DC OR
    All AC/DC models that have the Harsh Ride TSB springs should get the new 04005-34404 spring set.
  19. Aug 18, 2016 at 2:38 PM
    #599
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    You will definitely gain the 1" you want because I gained 1.5" with the 3 leaf AAL and that's WITHOUT the over load. If you leave the overload you'd probably get closer to 2" and still be able to carry a load also. I'd say you'd be safe with the 3 leaf WITH THE overload kept in it
  20. Aug 19, 2016 at 7:32 AM
    #600
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    If toyota performed the recall on your truck, they are done with you. I put the springs on in january and was still waiting for the recall springs to arrive when i called toyota about the reimbursement. Basically, i had to fax them receipts, proof of ownership, reason for springs being replaced and that is how it works. They decide and notify you.
