Cam bolt question (now with answers and writeup)
Discussion in 'Suspension' started by Plain Jane Taco, Jul 21, 2017.
  1. Sep 11, 2019 at 1:44 PM
    #41
    Plain Jane Taco
    Plain Jane Taco [OP] Well-Known Member
    USA
    I wouldn't think it was because you lubed them. In fact, I would pull all of them and lube them. Antiseize has been proven to be very effective. However, as I've mentioned before, a heavy grease like bearing or marine grade would work quite well, I would guess.
    It's probably something else making the noise...like the AM bushing/LCA
  2. Sep 12, 2019 at 5:14 AM
    #42
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I'm pretty sure it's the bushing in the Dorman LCA. But I was thinking that it could be a combo. If the aftermarket bushing isn't long enough, or tight enough, or whatever....it could be used to using the rubber to grip the LCA bolt (cant remember if it was rubber all the way through or if there was a metal sleeve). The grease could be allowing it to slide forward/backward and causing the noise. I'm trying to get my OEM LCAs back so that I can rebuild them and get rid of this Dorman junk.
  3. Sep 12, 2019 at 5:13 PM
    #43
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Dorman parts junk? Oh come now! Personally, I wouldn't install Dorman valve stem caps on a vehicle I was trading in.
  4. Sep 12, 2019 at 5:38 PM
    #44
    CowboyTaco
    North Georgia
    11 TRD Sport
    I had relative success (or so I thought) with them in the past. I figured they were a decent option, especially since i had read that Moog has gone WAY downhill. Lesson learned, I suppose. I try to stick with OEM whenever possible, I guess I should have sucked it up and spent the extra. Live and learn.
    I will say that I've had pretty good success with the Dorman wheel bearing/hub assembly though. $25k+ on 2 of them and I've had them out on the trail a few times. Not saying I would buy them again, but they have been decent.
    Too Stroked[QUOTED] likes this.
  5. Dec 1, 2019 at 5:19 PM
    #45
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    I used white line bushings, OEM bolts and sleeves with the TC cam tabs welded in place. Everything has been great. Mine was a 2014 that spent 1 winter in SC, 1 in Indiana and the rest in VA. Had to cut all of them out. Antiseize them, torque properly and never worry again. I cant believe they come like this from the factory so dry and seize so easy.
    Norton and Plain Jane Taco[OP] like this.
  6. Dec 2, 2019 at 6:09 AM
    #46
    Plain Jane Taco
    USA
    :thumbsup:
    ready6delta[QUOTED] likes this.
  7. Dec 3, 2019 at 5:08 AM
    #47
    ready6delta
    JACOB
    Good write up man and good reference. How have things held up since you did this? Im about to take mine all apart again to replace lower ball joints and or just replace whole LCA with already pressed in LBJ but we will see.
  8. Dec 3, 2019 at 5:24 AM
    #48
    Plain Jane Taco
    USA
  9. Feb 17, 2020 at 3:26 PM
    #49
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    thanks for this. My 2004 has seized bolts and sleeves so when i cut them out, I will make sure to do this with the new parts. Looks like you just lube up everything EXCEPT the actual tabs?
  10. Feb 17, 2020 at 4:15 PM
    #50
    Plain Jane Taco
    USA
    I didn't lube up the backs of the actual cams. But everything else....yes. You can use antiseize or some kind of heavy grease....like bearing or marine grease
  11. Apr 22, 2020 at 12:22 PM
    #51
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    Great post Plain Jane. Thanks for the write up!
  12. Apr 22, 2020 at 1:56 PM
    #52
    Plain Jane Taco
    USA
    You're very welcome. Spread the word. I've been trying to for awhile now.
  13. Apr 22, 2020 at 2:07 PM
    #53
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I'll be putting on my new Dirt King LCA's soon and have a fresh set of cams to grease up at install time.
    Plain Jane Taco[OP] likes this.
  14. Apr 22, 2020 at 2:18 PM
    #54
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Nice write up. Two suggestions.
    1. Instead of anti-seize, use either Lucas Red n Tacky, or a high temp bearing grease. The anti-seize can get washed out easily where the two above mentioned greases will not.
    2. Torque to 130ft#'s. The 100ft#'s is not enough.
    Muajilong likes this.
  15. Apr 22, 2020 at 2:22 PM
    #55
    Plain Jane Taco
    USA
    I mentioned high temp grease in later posts.
    As far as the antiseize....I did an update at 2 years later last summer. It's a few posts back. Zero issue with disassembly. Everything came apart like butter and the antiseize was still there....at least the brand I used.
    As for the 100 ft lbs? That was the listing for the factory torque
    Unchained 5150 likes this.
  16. Apr 22, 2020 at 2:37 PM
    #56
    Plain Jane Taco
    USA
  17. May 13, 2020 at 9:42 PM
    #57
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    @Plain Jane Taco
    I screwed up and broke my bumpstop bolt and the only way to extract it seems to be to remove my LCA. Figure I’ll lube up my Cams following what you did, think there will be anything I have to do on top of your directions since I’ll be pulling the LCA out and putting it back in place?
  18. May 14, 2020 at 2:39 AM
    #58
    Plain Jane Taco
    USA
    I wouldn't think so. I've pulled my share of LCAs on many different vehicles, but never had to on a Tacoma. But it shouldn't effect what you're doing with the cam bolts
    HolyReptar[QUOTED] likes this.
  19. Feb 13, 2021 at 4:09 PM
    #59
    RHHousehold
    RHHousehold Well-Known Member
    CA
    2008 Access Cab TRD Offroad 4x4 V6
    Thanks for this write up.
    I have a had recent frame replacement and new LCAs so these bolts are all new. But I had some creaking noises when turning full lock.
    I went ahead and tightened the bolts which weren’t anywhere close to 100 ft/lb. Seems to have fixed the issue.
  20. Apr 27, 2021 at 4:49 AM
    #60
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Little thread revival here. Went back to all stock suspension, and it will need to be aligned now. A couple of years ago the cams were all pulled out and anti seize was used. Friday while the truck was on jack stands up front my alignment cams were checked with no weight supported by a jack. The rears moved perfectly but the front moved a little, if they were seized would they move at all? Or would you get zero movement because the LCA wasn't supported near the cams?
