Cam bolt question (now with answers and writeup)
Discussion in 'Suspension' started by Plain Jane Taco, Jul 21, 2017.
  1. Apr 27, 2021 at 4:54 AM
    #61
    Plain Jane Taco
    Plain Jane Taco [OP] Well-Known Member
    USA
    Try it while supporting the LCA. Jack it up enough to compress the suspension a couple of inches and see if that makes a difference
  2. Apr 27, 2021 at 5:35 AM
    #62
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    All of mine spun a little bit but ultimately 2 of them had to be cut out. This is with wheels off the ground.
    Depends on the level of seize you're picturing, and what you consider locked up, I suppose.
    Plain Jane Taco[OP] likes this.
  3. Apr 27, 2021 at 8:47 AM
    #63
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  4. Apr 27, 2021 at 8:48 AM
    #64
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    What alignment cams are those?
  5. Apr 27, 2021 at 9:51 AM
    #65
    Plain Jane Taco
    USA
    Typical Tacoma from the rust belt. But that whole cam bolt debacle is completely avoidable. That guy also destroyed some of his cam alignment tabs using that air chisel. Very common for shops to do the same damage.
    That whole video made me cringe
  6. Apr 27, 2021 at 9:53 AM
    #66
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Right the truck looked like the vehicle from Cars with Rusteeze.
    vssman and Plain Jane Taco[OP] like this.
  7. Apr 27, 2021 at 1:49 PM
    #67
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Is there a way for me to check my front cams without jacking up the truck? Actually don't they leave the truck on the ground to align it?
  8. Apr 28, 2021 at 2:08 PM
    #68
    Plain Jane Taco
    USA
  9. Apr 28, 2021 at 2:12 PM
    #69
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  10. Apr 28, 2021 at 2:13 PM
    #70
    Plain Jane Taco
    USA
    barnaby and b8hickman like this.
  11. Apr 28, 2021 at 2:15 PM
    #71
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    That will be me later
  12. Apr 28, 2021 at 4:21 PM
    #72
    Plain Jane Taco
    USA
    Wait until you're actually there.....parts in hand at the shop. Then break out the silver wonder juice
  13. Apr 28, 2021 at 4:23 PM
    #73
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Shit, ah, burns the foreskin. Guess I should have waited.
  14. Apr 28, 2021 at 5:44 PM
    #74
    Plain Jane Taco
    USA
    You're doing it wrong o_O
    :rofl:
  15. Nov 2, 2023 at 1:28 PM
    #75
    William H. Bonney
    William H. Bonney Well-Known Member
    2016 TRDOR
    Not sure if anyone mentioned this yet, I just browsed through. But you will need a 22 and a 30mm socket.
  16. Nov 5, 2023 at 12:55 AM
    #76
    Roadkill69
    Roadkill69 Well-Known Member
    1998 Xcab 4x4 SR5 V6 TRD-OR; 2021 TRD-OR ACLB
    1st gen tacoma, 1998, 4WD v6 3.4L manual.
    The rear cam bolts are blocked by the rack and pinion. You have to remove all the steering gear i.e. rack, support bolts. Then basically pull it off mounts so you can angle the ends out enough to wiggle cam bolts out.
    Rack bolts are 19 and 22mm.
    Cam bolts are 19 nut and and 22mm bolt head.
    Once you pull the steering rack off, you might as well replace the bushings on it. Energy suspension makes a nice poly set.
    Did this today. Front cams you can access the front bolt with an impact wrench. Rear ones you need to use a socket and breaker to loosen rear bolt, then a wrench to work it out... steering rack blocks using a socket as bolt comes out.
  17. May 14, 2025 at 2:16 PM
    #77
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Has anyone had issues with the alignment slipping out of spec after using anti-seize on the internals? I asked a 4x4 shop about lubing the sleeve and bolt when they were doing my alignment but declined as they said it will cause alignment to easily slip.
    Also, If I recall correctly the cam bolt has several fixed positions, you have to back the nut/eccentric off 1/4" or so before it will actually budge/adjust due to channels on the bolt?
  18. May 14, 2025 at 9:38 PM
    #78
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I'm not sure about with anti-seize, but with grease I personally don't think it would matter that much... When the bolt has everything clamped under pressure, it squeezes the grease out from under where the surfaces make contact (meaning metal clamped against metal). Maybe if an impact caused it to initially slip very slightly, the grease could then allow further slippage because grease would then find it's way back in-between the contact surfaces as they're sliding... But up to that point I would say no, should be fine.
    I don't recall anything other than smooth rotation & movement with the cams loosened. Some aftermarket cam lock bolts have multiple fixed positions, but not OEM ones.
    Old posts from earlier, but 100ft-lbs is spec is for 2nd-gen. 135 (front bolt) and 139 (rear bolt) is spec for 3rd Gen (the 3rd-Gen bolts are bigger, so is why the higher torque).
