Cam Gears for Lower Control Arms
Discussion in 'Suspension' started by Blackhawk131, Sep 21, 2017.
  1. Sep 21, 2017 at 6:04 PM
    Blackhawk131
    Blackhawk131 [OP] Well-Known Member
    I replaced the lower control arms and was curious if there was an "Special" way to install the cam bolts? Does it matter? If you put them in wrong what kind of problems will you see in the alignment?
  2. Sep 21, 2017 at 6:05 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Oh yes it does matter here is a picture.
  3. Sep 21, 2017 at 6:06 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  4. Sep 21, 2017 at 6:07 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  5. Sep 21, 2017 at 6:22 PM
    Blackhawk131
    Nice write up.. I have them installed correctly, just some reason I cannot get caster in spec. With these control arms I should be at 2.0 - 2.5 and all I am getting is .37. I need the tires to go forward so they will not rub!
