Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Oct 17, 2022 at 7:15 PM
    #2001
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Doesnt the manifold spacer make it run leaner?
  2. Oct 17, 2022 at 7:20 PM
    #2002
    Dagralph
    Dagralph Well-Known Member
    2015 SW DCLB taco
    absolutely no idea, maybe? but I havent heard of people throwing and keeping those codes after installing.
  3. Oct 17, 2022 at 7:24 PM
    #2003
    99TacoDriver
    South Louisiana
    did you install that and the gear at the same time?
    only other guess I got is an O2 sensor
  4. Oct 17, 2022 at 7:27 PM
    #2004
    Dagralph
    2015 SW DCLB taco
    yeaaa they both went on at the same time.. O2 sensor also a good call. will definitely look into that if all else fails.
    on the topic of all else, is "permatex ultrahigh temp copper" gasket maker the right product?
  5. Oct 17, 2022 at 10:02 PM
    #2005
    Checkk
    Checkk Well-Known Member
    Tom
    2011 Toyota Tacoma Prerunner TRD OFFROAD
    Bank 1 bank 2 system too lean. probably a vacuum leak, (loose hoses, improper installation of intake gaskets, throttle body gasket, check hose at back of intake. Check o-ring on mass air flow sensor. I would check fuel trim with a scanner and report back readings.
  6. Oct 18, 2022 at 5:39 AM
    #2006
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I bought a sheet of the Cometic gasket material and cut a new one when the gasket that came w/ the spacer fell apart after I removed it during the cam gear installation. I didn't put one on both sides of the manifold spacer though.o_O
  7. Oct 18, 2022 at 5:40 AM
    #2007
    Chris(NJ)
    08 Indigo 4x4 DC OR
  8. Oct 18, 2022 at 5:43 AM
    #2008
    99TacoDriver
    South Louisiana
    well if the problem persist it may be easy enough to remove the spacer and see if that clears the problem.
    i dont have either of these mods done but im betting the manifold spacer is much easer to remove to see if the problem clears
    mightytacoman[OP] likes this.
  9. Oct 18, 2022 at 11:08 AM
    #2009
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    The Cometic gasket @Chris(NJ) mentions goes in between the manifold spacer and manifold. The OEM orange gaskets stays on the intake pendulum (this is a recessed gasket). Not having a gasket on the spacer/manifold side is 100% your issue.
  10. Oct 18, 2022 at 11:15 AM
    #2010
    Dagralph
    2015 SW DCLB taco
    okay, so maybe this cometic gasket is the better way to go than permatex? any idea is there is a PN for that, or does it need to be a custom cut piece?
  11. Oct 18, 2022 at 11:17 AM
    #2011
    Chris(NJ)
    08 Indigo 4x4 DC OR
    It's a much better option than slapping permatex on there. It comes in a blank sheet. Look at my pic above. You'll wind up placing the spacer on the sheet, trace it, then cut it out. Your local autozone/oreillys/whoever might even carry it. Otherwise, you can source it through Amazon/jegs/summit.
  12. Oct 18, 2022 at 11:18 AM
    #2012
    Dagralph
    2015 SW DCLB taco
    yea okay that's the route ill go then. thanks fellas!
    1slow4.0 and Chris(NJ)[QUOTED] like this.
  13. Oct 18, 2022 at 11:20 AM
    #2013
    Chris(NJ)
    08 Indigo 4x4 DC OR
  14. Oct 18, 2022 at 11:22 AM
    #2014
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
  15. Oct 18, 2022 at 11:34 AM
    #2015
    Dagralph
    2015 SW DCLB taco
    ordered up.
    mightytacoman[OP] and 1slow4.0 like this.
  16. Oct 18, 2022 at 12:35 PM
    #2016
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    Hey Everyone!
    I know this isn't really a trading post thread, but I have a brand new set of @mightytacoman machined cam gears I never got around to installing. $100 shipped (continental US only). PM me if interested.
    clenkeit and mightytacoman[OP] like this.
  17. Oct 18, 2022 at 2:10 PM
    #2017
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Keep us posted on if this cures your problem.
    1slow4.0 likes this.
  18. Oct 18, 2022 at 2:12 PM
    #2018
    Dagralph
    2015 SW DCLB taco
    you know it
  19. Oct 27, 2022 at 8:56 PM
    #2019
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Anyone experience cam position codes or any other check engine codes with this gear swap?
  20. Oct 27, 2022 at 9:10 PM
    #2020
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I installed these in May 2020 and have not had a single hiccup. They've been great for nearly 100,000 miles and I cant imagine life without them!
    GilbertOz and ndcmack[QUOTED] like this.
