Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Oct 27, 2022 at 10:09 PM
    #2021
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I experienced them soon after install on one truck, cleared them and they didn't come back.
    ndcmack[QUOTED] likes this.
  2. Oct 28, 2022 at 5:23 AM
    #2022
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I've had mine in for 6 months - not one problem.
    I've also towed several trailers, the heaviest being ~3500 lbs. No issues.
    Don't know why I waited so long to install them. Great upgrade.
  3. Nov 7, 2022 at 4:48 PM
    #2023
    AMTaco89
    AMTaco89 Well-Known Member
    Alex
    Santa Rosa, CA
    2015 Black Tacoma TRD Off Road 4x4
    MRBP Axle Dump Exhaust, URD True Cold Air Intake, URD Y-Pipe, URD Maf Calibrator, XTP Manifold Spacer, Blacked Out Grill Surround, Blacked Out Rear Bumper, BPF Front Skid, Avis In Channel Window Deflectors, Built Right Fabrication UCA, King Extended Travel Coilovers F/R, Icon 1.5 Inch AAL, 17 inch Method Double Standard Wheels, BFG K02's 285/70/17, 32 Inch Lower Grille LED Light Bar, OEM Roof Rack
    Anybody in nor cal want to install them for me? I’ll bring beer pizza and cash. I’m in Santa Rosa, California. Thanks
  4. Nov 8, 2022 at 3:56 PM
    #2024
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Nope!
    and tbh, I don't think you can actually throw any codes with this as I don't believe there isn't any rotational sensor on the exhaust cam itself, only the VVTi actuator on the intake cam.
    ndcmack[QUOTED] and JustDSM like this.
  5. Nov 8, 2022 at 4:00 PM
    #2025
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    100% spot on.
    ndcmack likes this.
  6. Nov 8, 2022 at 7:43 PM
    #2026
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Well… when I did @Dagralph cam gears I had him bump the ignition over to get the timing marks in the neighborhood. It threw about 19 codes when we started it up. VVI codes, position codes, codes for things I didn’t knew existed. I cleared them. Let it idle for awhile then took it on a test run. Then it dawned on me every plug for a sensor was undone when we bumped it over. The only code that came back was the one from the intake spacer leak on his way home.
    ndcmack and Dagralph like this.
  7. Nov 20, 2022 at 1:58 AM
    #2027
    Dagralph
    Dagralph Well-Known Member
    2015 SW DCLB taco
    Got a gasket in there. Codes cleared and I took it around the block without seeing again. Feels better too - quite a bit snappier and less bogged down. I’d say that solved the problem!
  8. Nov 20, 2022 at 12:19 PM
    #2028
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Glad to hear your good now! Need to get a tune in it now. It will pick up a little about as much as the cam gears. Nothing crazy just a little more.
    JustDSM and Dagralph[QUOTED] like this.
  9. Dec 6, 2022 at 12:06 PM
    #2029
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Any future GB for these cam gears? If not, where are people purchasing them off of, URD site?
  10. Dec 6, 2022 at 12:14 PM
    #2030
    mightytacoman
    Kel
    4.5L 1grfe
    No plans for a future group buy at this time. Urd will be your best bet.
  11. Dec 6, 2022 at 12:32 PM
    #2031
    4wdExplorer
    Orange County, CA
    Thanks, I just checked and they seem out of stock. Not sure how long it takes for them to restock.
    lukefndavis likes this.
  12. Dec 6, 2022 at 12:34 PM
    #2032
    mightytacoman
    Kel
    4.5L 1grfe
    If they are out of stock a month from now- I will step up and make more sets.
    Chris(NJ), 1slow4.0, Rezkid and 3 others like this.
  13. Dec 6, 2022 at 12:46 PM
    #2033
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    @Wackyhacky still looking to sell your set?
  14. Dec 6, 2022 at 1:01 PM
    #2034
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    YESSIR. Still have them for sale.
  15. Feb 7, 2023 at 1:41 AM
    #2035
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    URD's current price on these 1GR-FE exhaust cam gears is currently $139 -- well, about $132 after the tw discount code is applied.
    Are any more group-buys of this planned?
    20somethingwidataco likes this.
  16. Feb 7, 2023 at 5:44 AM
    #2036
    JasonLee
    15 TRD OffRoad
    I am coming to the realization as toon that I’m probably not going to get around to installing mine.
    DM me if you are looking for a set.
    Falldownhard likes this.
  17. Feb 7, 2023 at 10:53 AM
    #2037
    mightytacoman
    Kel
    4.5L 1grfe
    No group buys planned. Check in the @JasonLee . Sound like he can hook you up with a set. With the cost of everything going up- I'm not sure I can beat that urd price by lots anyways.
    JasonLee and GilbertOz[QUOTED] like this.
  18. Feb 24, 2023 at 10:50 AM
    #2038
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    I have an unused set available, if anyone is looking.
    Update: cam gears have been sold.
  19. Feb 24, 2023 at 11:37 AM
    #2039
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    I may be interested.
    fatfurious2 and rmepilot[QUOTED] like this.
  20. Feb 24, 2023 at 12:22 PM
    #2040
    rmepilot
    Rob
    Huntsville, AL
