Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Jul 1, 2025 at 6:06 PM
    #2181
    wdunnlee
    wdunnlee Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    I have to do my valve cover gasket sometime this week and I was looking at these paired with an IMS. I’m at 150k miles with up to date maintenance. Is there such thing as “too high milage”
    I don’t want to put unneeded stress on other parts that may break.
    How much reliability am I compromising if I install these correctly?
    If none then why didn’t Toyota design their cam gears like this?
    TheBlueBeast15 likes this.
  2. Jul 1, 2025 at 6:11 PM
    #2182
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I wouldn't think these would effect reliability one way or the other. It might increase longevity as the engine works slightly less hard.
    Toyota has to appease the epa. Reburning some of the exhaust gases so they are slightly cleaner is one technique to do that.
  3. Jul 1, 2025 at 6:12 PM
    #2183
    wdunnlee
    Will
    Tidewater VA
    I was hoping you would say that :fistbump:
    That’s enough convincing for me :D
  4. Jul 1, 2025 at 6:29 PM
    #2184
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Gears. IMS. Tune. And never look back
    04TacoRunner and wdunnlee like this.
  5. Jul 10, 2025 at 8:04 PM
    #2185
    1madmnky
    1madmnky Well-Known Member
    Tony
    Kansas via Fullerton 714
    2010 Tacoma 4X4 DCLB
    Hella Supertones
    Is anyone still doing this mod?
  6. Jul 10, 2025 at 8:08 PM
    #2186
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Yep, I plan to do a 2014 Tacoma next week.
    mightytacoman[OP] likes this.
  7. Jul 11, 2025 at 7:49 PM
    #2187
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    5 years and about 40k later absolutely 0 issues.
    04TacoRunner likes this.
  8. Jul 14, 2025 at 12:42 PM
    #2188
    Argann
    Argann Well-Known Member
    Rich
    4Runner, Tacoma, Defender 90
    Yes. About to do a small write up on it. But want a few more tanks of fuel to get better data points.
  9. Jul 14, 2025 at 1:48 PM
    #2189
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    That would be nice data to have. This truck I'm doing is totally stock. Installing the IMS also and then a tune from OTT.
    JustDSM likes this.
  10. Jul 14, 2025 at 2:30 PM
    #2190
    wdunnlee
    Will
    Tidewater VA
    I got my IMS, cam gears are on the way.
    Should be gapping hellcats soon :mudding:
    mightytacoman[OP] and montijo505 like this.
  11. Jul 14, 2025 at 2:39 PM
    #2191
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Read about the hellcats but seemed some were having issues with them. That was during COVID though
  12. Aug 6, 2025 at 8:50 AM
    #2192
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    I've got about a year with the new cam gears in. Engine is stock, no mods or tunes, I'm coming up on 50,000 miles. I've got about 10k on the cam gears. Of those 10k miles about 5k were towing my teardrop from WA to TX, freeway flying solo there and exploring with my family coming back. I just (within the last month) installed a larger transmission cooler but haven't added any of those fill-ups to my mileage spreadsheet (yeah, I'm one of those guys). The engine is noticeably smoother at idle, enough so that my wife commented on it. My butt dyno doesn't notice any difference.
    Mileage gets discussed quite a bit. Most of my driving, aside from road trips, is in town. Before the cam-gear I was averaging 13.58mpg. After the cam-gear I'm averaging 13.53, so not much of a difference. Those numbers don't include towing.
    I have separate numbers for towing. Before the cam-gear I was averaging 13.23mpg (over about 10k miles). After the cam-gear I'm averaging 13.25 (over about 5k miles), so I'm pretty much in the same spot I was before. As I mentioned before, I've got almost 50k on the truck. I've towed the teardrop for 15k of those.
    Note, I'm not using the total life-of truck mpg. For that I'm at 13.79 mpg. I had a long road trip early on where I was getting over 20mpg for multiple tanks and that trip really skews the numbers. I've added bumpers, sliders, canopy, and tires (235/85R16 General Grabber AT).
    I can't personally say that I've gained anything from this mod other than a smoother sounding engine. It probably wasn't worth doing for me. On the same token, it's not worth undoing.
    (edited for punctuation)
  13. Aug 6, 2025 at 9:44 AM
    #2193
    Argann
    Rich
    @Louisd75 I just installed mine 2 mo ago. Thx for posting. Going to do a write up after todays fill up. That gives me 5 tanks before and 5 after.
