Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Apr 29, 2020 at 8:56 AM
    #501
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Bump..sets in stock
  2. Apr 29, 2020 at 10:15 PM
    #502
    ETALATE
    ETALATE Non Sum Qualis Eram
    Burlingame, CA
    2011 DCSB TRD OR
    Running OVtune 91 octane tune on my truck, any reason to think these will have any conflicts with one another ?
  3. Apr 30, 2020 at 4:28 AM
    #503
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. Apr 30, 2020 at 4:52 AM
    #504
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Well shit....Add another item to the list of things to get. :spending:
  5. May 3, 2020 at 6:21 AM
    #505
    mightytacoman
    Kel
    4.5L 1grfe
    When ever you're ready, I'll set ya up
  6. May 8, 2020 at 7:53 AM
    #506
    mightytacoman
    Kel
    4.5L 1grfe
    I have sets in stock ready to ship. Happy Friday everyone :cheers:
  7. May 18, 2020 at 12:39 PM
    #507
    mightytacoman
    Kel
    4.5L 1grfe
  8. May 18, 2020 at 12:43 PM
    #508
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Once I settle on tuning i need to see if I get any. I just got a whopping 6.9mpg on my tank of gas (S/C, cam gear, intake and bigger injectors) but lots of lead foot testing things out.
    TireFire[QUOTED] likes this.
  9. May 18, 2020 at 12:46 PM
    #509
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Once again. My results are the conglomeration of cam gears, cleaning of my throttle body and the entire intake tract and lower manifold up to the valves (lots of gunk in there) and adding a manifold spacer. I also didn’t drive like a maniac. And I was only getting 13-14mpg prior, worse in the winter. Wouldn’t want anyone to install just the gears and be disappointed they don’t net as much fuel economy
    nudavinci64[QUOTED] likes this.
  10. May 18, 2020 at 12:52 PM
    #510
    nudavinci64
    Robert
    My Crank TDC and top timing marks never played perfect. After talking with Kel we agreed to get the top lined up. The bottom was close but there is only one way to put the cam gears on. I was worried but its working great and timing is spot on. In case anyone comes to it. If you crank it over a handful of times 10 or so you will get al the pre-exising painted marks to line up. I like this instead of marking them (also did not have any white out to use)
    Also if your having trouble lining it up, removing the fan and shroud made it easier to turn and line up with a long ratchet/breaker if your doing it solo (which I did).
    I would suggest removing the plugs since you will not be fighting combustion. it moves freely without it.
    If you do not have the offset wrench, give it a good tighten. After time the engine will tighten it further. Its tighter than its needs to be from the factory.
    Also tons of recommendations but you can also get the offset 17mm direct from Snap-On for $30 if anyone prefers. I had actually ordered it before and naturally arrived after I had already bolted it back up. No issues with it so far.
    It went in with a ton of other stuff so I do not have an honest review of just the cam gears. I do see higher power at higher RPM/Speeds 60-90 as noted by another person. With the cam gears I also added the Maggie S/C, FIC 650cc injectors, NST pulleys, TRD FJ/T4R intake, new Iridium plugs for the S/C, cleaning TB, new coolant, CSF radiator and a 2.8 pulley.
    Mech_Eng and mightytacoman[OP] like this.
  11. May 18, 2020 at 1:19 PM
    #511
    nudavinci64
    Robert
    Totally, I did not install them expecting any mpg gain. I am getting 10-12mpg before so once I settle on my tuning at least getting the same. Any improvement would be great. Nice to se it.
  12. May 20, 2020 at 4:48 AM
    #512
    mightytacoman
    Kel
    4.5L 1grfe
    PRICE DROP memorial day deals
  13. May 22, 2020 at 3:04 AM
    #513
    mightytacoman
    Kel
    4.5L 1grfe
    Bump up for the weekend. Memorial day sales. $10 off sale price for military stands. Just mention your military in the pm for the discount.
  14. Jun 4, 2020 at 4:23 AM
    #514
    mightytacoman
    Kel
    4.5L 1grfe
    Bump. 6 sets left in stock
    fatfurious2 likes this.
  15. Jun 5, 2020 at 2:26 AM
    #515
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  16. Jun 14, 2020 at 4:54 PM
    #516
    mightytacoman
    Kel
    4.5L 1grfe
  17. Jun 18, 2020 at 9:02 AM
    #517
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Has anyone used this 17mm Mercedes wrench?? Price is right and looks like it should work getting stuff off and on.
    (lowers head in shame... i still havnt gotten time to put my cam gears in)
    https://www.ebay.com/itm/Mercedes-Benz-Offset-Engine-Mount-Wrench-17mm/184166049330
  18. Jun 18, 2020 at 9:11 AM
    #518
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
  19. Jun 18, 2020 at 9:12 AM
    #519
    nd4spdbh
    SoCal
    I got mine in december :oops:
    ARoman83[QUOTED] likes this.
  20. Jun 18, 2020 at 9:15 AM
    #520
    ARoman83
    Alex
    Wisco
    Only legal stuff
    :rofl:
