Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Jul 28, 2020 at 9:00 AM
    #661
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Yup, Got mine the other day!
  2. Jul 28, 2020 at 9:51 AM
    #662
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    gotcha. 3 to go
  3. Jul 30, 2020 at 6:59 AM
    #663
    mightytacoman
    Kel
    4.5L 1grfe
    we've hit 8.
    I'll do 8 for a group buy. Gonna wait a week though for others to jump in.
    @nd4spdbh Any update on your thoughts after running them for a couple weeks now? what mpg change if any did you get? Also added your graph to pg 1
    BigWhiteTRD likes this.
  4. Jul 30, 2020 at 8:13 AM
    #664
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Definitely some more umph in the mid range where one would expect with these. Its hard to get consistent pulls for MAF numbers in the 2000-3600 rpm range in an auto (without making a wacky trans tune) simply due to how the trans is going to shift. And I hadnt thought of doing a "dyno trans tune" so i could pull from the bottom of second to the top before installing.
    No idea on mpg numbers yet, Hardly doing much driving as of late and if i am its all city or "dyno runs" for tuning purposes. I will be doing a LONG trek from southern ca to essentially Oregon in two weeks, we will see how mpg numbers look, I will be loaded down however with 2 standup jetskis in the bed of my truck and gear inside.
  5. Jul 30, 2020 at 8:32 AM
    #665
    marcp3
    marcp3 Well-Known Member
    marc
    2015 tacoma dclb trd sport
    I want in the 2nd group buy please.
    do you ship to Canada G1S3K2?
    Thanks
  6. Jul 30, 2020 at 8:48 AM
    #666
    mightytacoman
    Kel
    4.5L 1grfe
    Can do, I'll add you to the list. Canadian shipping is usually $20 more I've found. So $140 would be your cost
  7. Jul 30, 2020 at 8:49 AM
    #667
    marcp3
    marc
    Perfect!
  8. Aug 2, 2020 at 2:44 PM
    #668
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    Helping buddy with install but don’t see the orange mark on inside links . I wanna make sure it’s going on the right spot . Any help will be appreciated. I’ve rotated several times and it’s only 2 yellow links in the inside .
  9. Aug 2, 2020 at 3:02 PM
    #669
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Forget the orange marks. Just make sure the timing marks are aligned as per the URD instructions
    mightytacoman[OP] likes this.
  10. Aug 2, 2020 at 3:08 PM
    #670
    Comato$e
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    Ok thanks
  11. Aug 4, 2020 at 7:33 AM
    #671
    mightytacoman
    Kel
    4.5L 1grfe
    bump, Last day of group buy will be this Friday 8/7.
    420taco and BigWhiteTRD like this.
  12. Aug 4, 2020 at 10:16 AM
    #672
    Tacolover07
    Tacolover07 Well-Known Member
    German
    11 DCSB sport
    Leveling kit, 33’s, new headlamps,
    So we finally Installed the gears...after a couple days and a few issues. Mighty taco man was pivotal and spot on with his assistance. So the verdict...after addressing the check engine and traction control light (bad cam shaft sensor connector). I can definitely say there’s a difference in sound during accelerating almost like its breathing better. The gas pedal seems more sensitive and responsive so I can see where I might get better mpg’s. Also I have a 2011 dcsb w no camper or add ons except I do have the 2/3” lift with “33’s” and auto trans. The truck overall feels lighter for sure, and this is just city stop and go driving. lol report back after a week or so when I’ve gone through this tank of gas. Big shout out to my guy comato$e who did the work.
  13. Aug 4, 2020 at 11:05 AM
    #673
    mightytacoman
    Kel
    4.5L 1grfe
    Glad I was able to walk ya through it and trouble shoot as needed. Looking forward to you reporting back after a tank or 2 of fuel.
  14. Aug 4, 2020 at 5:17 PM
    #674
    jgang
    jgang Well-Known Member
    Put me down for a set. I'm a retired GI, so thanks for the military discount, BUT, I'll gladly pass that discount on to the last guy needed to make the group buy happen as an incentive to sign up.
  15. Aug 4, 2020 at 5:50 PM
    #675
    mightytacoman
    Kel
    4.5L 1grfe
    You're in
  16. Aug 7, 2020 at 10:43 AM
    #676
    mightytacoman
    Kel
    4.5L 1grfe
    Bump. Last day to get in.
  17. Aug 8, 2020 at 4:26 AM
    #677
    mightytacoman
    Kel
    4.5L 1grfe
    Closed. I'll be sending PMs to GB2 members with payment details after some coffee.
  18. Aug 8, 2020 at 5:35 AM
    #678
    mightytacoman
    Kel
    4.5L 1grfe
    check your inboxes gentlemen
  19. Aug 8, 2020 at 6:57 AM
    #679
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    :spending:
    Thank you!
  20. Aug 11, 2020 at 10:07 PM
    #680
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    Just finished the install. Not too bad of a job, about 4 hours from start to test drive. What a difference. Idles much quieter/smoother and drives loads better. I did install both the gears and the XTP plenum spacer together, so I'm sure mine is more drastic than others.
    Excited to report on MPG's in a few tanks. I've been keeping a manual log since I decided to do this project. No codes/leaks and everything looks good so far.
    AllTacosFloat likes this.
