Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Oct 5, 2020 at 6:58 AM
    #821
    jgang
    jgang Well-Known Member
    I can't speak to the SAIS delete, but I can tell you it's tricky to remove and reinstall. You can access the lower bolt to the bracket through the wheel well. Getting the rear steel pipe off the studs while trying to remove the bracket requires some leverage and a bit of luck. Be sure the new gaskets stay in place.
    ARoman83 and 12TRDTacoma like this.
  2. Oct 5, 2020 at 7:18 AM
    #822
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Is your SAI delete already done?
    ARoman83[QUOTED] likes this.
  3. Oct 5, 2020 at 7:30 AM
    #823
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    Already complied with!
  4. Oct 5, 2020 at 7:32 AM
    #824
    ARoman83
    Alex
    Wisco
    Only legal stuff
    Was just wondering if the install should be just like pre '12 or if there is still something to be aware of during install.
  5. Oct 5, 2020 at 7:35 AM
    #825
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Thats about how long it took me doing everything right and fixing gaskets which became dislodged on the truck for one reason or another. The improvement is not in your head. The cam gears are designed to allow for a cleaner more thorough burn so what you actually feel is a physical running improvement. Like most owners who note an improved running condition after 15-20,000 mile initial "break in," it's just the cam gears wearing to allow for .5 degrees of retard. It's not just in their head either. The engine is running better, they just don't know why.
    The SAIS reinstall is tricky, especially if you have done the delete prior to all this. Primarily the bolt at the wheel well. I fought that thing with a co worker because the SOB wouldn't thread back in without a second pair of hands.
    mightytacoman[OP] and ARoman83 like this.
  6. Oct 5, 2020 at 7:39 AM
    #826
    ARoman83
    Alex
    Wisco
    Only legal stuff
    So if I don't plan on reinstalling SAIS after gear install I should be good?
  7. Oct 5, 2020 at 7:42 AM
    #827
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    I did my SAIS delete with my cam gears. I bought a preSAIS valve cover off EBay for a cleaner look and installed it on the way back out. Other than that it’s the same.
    12TRDTacoma and ARoman83[QUOTED] like this.
  8. Oct 5, 2020 at 7:43 AM
    #828
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    You need it turned off before it gets removed.
  9. Oct 5, 2020 at 7:49 AM
    #829
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm not sure what you are attempting to install or how you intend on accomplishing it so I can't say yes or no. Are you going to rip out all of the SAI system and block off the tubes at the manifolds themselves?
  10. Oct 5, 2020 at 7:56 AM
    #830
    ARoman83
    Alex
    Wisco
    Only legal stuff
    Already done all of that. I was just inquiring if the procedure for installing the gears will differ now?
  11. Oct 5, 2020 at 7:56 AM
    #831
    ARoman83
    Alex
    Wisco
    Only legal stuff
    That's what I thought, just wanted to verify! Thanks for the info gents!
    12TRDTacoma likes this.
  12. Oct 5, 2020 at 7:58 AM
    #832
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    It’s the same, your 45 minutes ahead now.
  13. Oct 5, 2020 at 7:59 AM
    #833
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah, you would have less overall steps and no need to bolt that BS SAI manifold back up to the block and valve cover if it's already deleted.
  14. Oct 5, 2020 at 8:02 AM
    #834
    ARoman83
    Alex
    Wisco
    Only legal stuff
    That's great news lol
  15. Oct 5, 2020 at 3:11 PM
    #835
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
  16. Oct 5, 2020 at 3:16 PM
    #836
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm here to serve those who have served me. It's no problem at all good sir! :hattip:
  17. Oct 5, 2020 at 4:22 PM
    #837
    ARoman83
    Alex
    Wisco
    Only legal stuff
    Very much appreciate it, but on this forum, I wouldn't expect anything else!!!
  18. Oct 6, 2020 at 10:23 PM
    #838
    iunek808
    iunek808 Well-Known Member
    oahu
    04 tacoma dblcab prerunner 4x4
    Tundra 5100's w/Fj springs Deaver leafs 4x4 conversion w/manual hubs Jshift
    You know when some will be shipped out?? Wanna install this weekend
  19. Oct 7, 2020 at 4:51 AM
    #839
    81runner
    81runner Member
    Elliott
    07 4runner
    Mods loading...
    Just joined up to get in on the next GB. Please add my name to the list
  20. Oct 7, 2020 at 6:13 AM
    #840
    mightytacoman
    Kel
    4.5L 1grfe
    Good news- all sets from gb4 have been shipped out
