Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Sep 9, 2019 at 10:57 AM
    #101
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I thought the crank pulley sometimes leaked. Hopefully someone else can chime in.
  2. Sep 9, 2019 at 11:01 AM
    #102
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Man...I've been trying to chase down a leak for weeks now. I've got the NST crank and fan pulley, but had enough oil on my inner driver CV to think that my re-seal/ECGS bushing job didn't work. I even ordered a new seal and went down to town to buy gear oil today to change it this afternoon, but dang does it ever look like it's leaking from the crank now that I look more closely. Thanks for the heads up!
  3. Sep 9, 2019 at 11:02 AM
    #103
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    The original NST pulleys didn't include a steel sleeve over the aluminum hub, so the spring tensioned crank seal would etch a path for oil there. They now come with steel sleeves over the aluminum hub to prevent premature wear.
    The funny thing is this happens with the stock steel dampner hub too. Both hubs I've pulled have had heavy scar-age there. Clean them up with some emerycloth and a new seal. You should be GTG.
    12TRDTacoma and Torspd like this.
  4. Sep 9, 2019 at 11:04 AM
    #104
    mightytacoman
    Kel
    4.5L 1grfe
    Justin or whoever can make some adjustments to your tune to take advantage of the additional timing. It will help some but isn't a NEED.
    Torspd and JustDSM like this.
  5. Sep 9, 2019 at 11:11 AM
    #105
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    PM incoming so I don't derail the thread.
    JustDSM likes this.
  6. Sep 9, 2019 at 11:45 AM
    #106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Wrinkle powder coat. He can answer the rest.
  7. Sep 9, 2019 at 12:19 PM
    #107
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Always add Grease to crank seal and or crank pulley sleeve.
    12TRDTacoma and DocME like this.
  8. Sep 9, 2019 at 1:54 PM
    #108
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Valve covers were from my spare engine. It's a wrinkle powder coat.
  9. Sep 9, 2019 at 2:12 PM
    #109
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Thanks.
    I'd like to do something to my valve covers when I install these - spare sets are quite expensive. :(
  10. Sep 9, 2019 at 2:32 PM
    #110
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    On P265/70R17 and about 2” lift all around I’m getting 20.5 to 21 every tank. I am running URD LT headers and a tune from JustDSM though.
    I would by far give the gears best bang for the buck of all my engine mods. My idle is much smoother and the power band is much more consistent. I’ll never own a 1GR-FE that doesn’t have them.
    I’ve got the alternator and water pump pulleys on the way from them, have for over six weeks:mad: I’m not running my truck as a tow/play truck without a balancer, but that’s just me. I’m gonna put a super damper on probably, as it is lighter than the factory, or so I’ve been told.
  11. Sep 9, 2019 at 4:45 PM
    #111
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Have started thinking the same (but would also always want a tune now too).
    Question for OP @mightytacoman - do you see any issue with sending you my stock gears I just removed to get machined in case I get another rig in the future? (have an itch for a DCLB I can't seem to get rid of).
    DiamondW[QUOTED] likes this.
  12. Sep 10, 2019 at 5:24 AM
    #112
    mightytacoman
    Kel
    4.5L 1grfe
    Ya I can machine your stock gears buddy. I machined a set with around 200k on them. There is little to no wear on the teeth but you can see where the stock keyway is ever so slightly wider from wear.
    smelly621[QUOTED] likes this.
  13. Sep 19, 2019 at 7:10 AM
    #113
    mightytacoman
    Kel
    4.5L 1grfe
    bump up for views
  14. Sep 30, 2019 at 9:21 AM
    #114
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Random question: how did it get established that 3° was the magic number? And not, say, 4°?
  15. Sep 30, 2019 at 9:23 AM
    #115
    mightytacoman
    Kel
    4.5L 1grfe
    It's what Urd found to work best. @dark vader trd pro had me do him a set at 4°. I wonder if he's installed them or not.
  16. Sep 30, 2019 at 10:31 AM
    #116
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Actually, for clarification, APR found it to be 3 degrees. URD used to work closely with APR.
  17. Oct 5, 2019 at 4:51 PM
    #117
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Why did I have to find this!? I just did The HP Tuners yesterday via JustDSM. I had no intentions of modifying my engine till I got a lift put on...this is not helping my cause. I will have to wait though for now
    mightytacoman[OP] likes this.
  18. Oct 5, 2019 at 6:25 PM
    #118
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Wait you shall not!
  19. Oct 5, 2019 at 6:47 PM
    #119
    SpanishTaco
    SpanishTaco Well-Known Member
    CT
    2015 Blue DCSB TRD Sport
    You try to put your wallet away...and they pull you back in!
    DAMN YOU, TOYOTA WORLD!!!
    https://youtu.be/fvzdehnJA9k
    TacoFergie[QUOTED] likes this.
  20. Oct 5, 2019 at 7:08 PM
    #120
    old55guy
    old55guy Well-Known Member
    mike
    2011 dcsb trd white
    none
    Ok I hope this makes sense On page one The stock gear timing dot is at 12:00 ? With the install of your gear the dot is at 7:00 ?
    I see the line you make to timing chain mark ! ( I assume that"s how you get the 3degs ) Am I thinking right ?
    Also would this Mod. still pass my California smog test ?
    Thank you very much for your R & D
    Update I get it now you modify a stock gear with a new slot !!!
    Bozo me !
