Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. May 7, 2021 at 11:20 AM
    #1501
    Jake7
    Jake7 Well-Known Member
    Levi
    Tritown Washington
    08 TRD Sport
    aFe CAI, TRD S/C with 2.8 URD Pulley, Doug Thorley long tube headers, AFE Y pipe, Banks monster exhaust
    I did a supercharger rebuild with port polish, snake bite pulley mod, venom cooler, new plugs, belt, new fuel pump and oil catch can. Ive trouble shot it down to cam gears. I took no pictures of install. Ive been running long tube headers for 2 years without noticing too dirty of exhaust and AFR is the same as before or a little leaner.
  2. May 7, 2021 at 8:42 PM
    #1502
    TacoTuesday1
    SD CA
    IDK if it's possible to screw up. I mean it has to go one way. On the new notch. Front/F facing front. Tensioner bolted back into place.
    And cam gear on the keyway.
    I mean I guess it could jump a tooth and be out of time on the chain?
    Unless it's out of time for another reason? Like I've heard of neglect can cause 4.0L to stretch timing chain more than a well-kept one. But I doubt yours is neglected therefore hopefully no timing chain stretch.
    Besides that the way to tell timing is turn it over by hand clockwise to the 0 alignment mark on crankshaft, with alignment marks facing top on the cams. Then find the sight marks (lines)/windows and see if everything is lined up right.
    But it's tricky and a repair manual with pictures probably has to be referenced to know, because there's a lot of lines. It's not just 2 like a normal car it's like 4.
    Speaking of that I wonder how these affect a timing chain job and if I should keep my old gears
    for example if the repair manual is written on how to time the stock parts
    let's say years down the road I need to replace the timing chain;
    would it be better to, at least temporarily, put stock cam gears back in to line up the new timing chain, before swapping the upgraded ones back in at the end
    like if someone for whatever reason has to do a more in-depth tear down to re-seal lower main timing cover, replace chain, etc.
  3. May 8, 2021 at 1:48 PM
    #1503
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    You don't need to keep your old gears. My gears still have a factory keyway of 0° if you wanted to use it for whatever reason.
    Doing a timing job is very easy with the front cover removed.
    As for checking timing- I have posted a great video of all the timing marks when things are at perfect timing towards the bottom of the 1st post.
    parel likes this.
  4. May 8, 2021 at 7:30 PM
    #1504
    TacoTuesday1
    SD CA
    oh yeah I forgot about that! (the stock groove on opposite side)
    now to figure out what to do with my old gears...
  5. May 11, 2021 at 11:06 AM
    #1505
    mightytacoman
    Kel
    4.5L 1grfe
    I got sets going in the mail tomorrow if anyone wants to place an order before then- I'll have yours in the mail too. Most will have them before the weekend hits.
    YOTA LOVER and Chris(NJ) like this.
  6. May 17, 2021 at 7:18 AM
    #1506
    mightytacoman
    Kel
    4.5L 1grfe
  7. May 18, 2021 at 4:53 PM
    #1507
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Alright killers, I got my gears from Kel about a year ago with all intention of getting this thing done (timing chain, oil pump, water pump). Ended up having to wait another 20k because life, but hot-damn I’m really happy with the results.
    Pulled the front clip off entirely (wanted better access, not necessary), broke down the top of the motor, pulled valve covers, spun the motor to TDC and got to work pulling the front cover. Took my sweet ass time doing the work, keeping it methodical and clean. Very happy to discover the internals were all super clean and in great shape. New gears installed easily, and installing new chains, tensioners, and guides was very straight forward. All said and done, not an awful job, but definitely not for a novice without assistance. I did use a youtube video, some guy from WI or MN. His motor looked like shit, but his video was informative and comprehensive.
    i’ve since gone through two tanks of fuel, and I did realize a better MPG. I’m up to 16.5mpg on 33x10’s. Truck holds gear better, and when it winds up (think on-ramp) to 3-4.5k rpms the truck is really awake and the motor is kicking her in the biscuits. Other than the gears, the motor is bone stock with 176k on it. I’d wager I could hit 17.5 MPG if I start driving like an old man.
    Also, Kel answered all of my questions and gave me a few solid pointers to make sure I did it right. Try getting that kind of service anywhere else. Thanks to Kel, I’m happier than a pig in shit and my Taco is ready for another 175k.
  8. May 20, 2021 at 10:08 PM
    #1508
    gpdx
    gpdx Well-Known Member
    Portland
    13 DCSB TRD Offroad
    5100/887, topper, rack, 265/75/16
    Checking in about a month after installing the gears. My work schedule changed a bit after installing so my drive patterns were different so I didn't have a direct comparison to my old MPG. In the last few weeks I've watched my ultra gauge closer than I ever have before.
    I've had this truck for about 6 months and my MPG has been a pretty steady 15.5 with only slight changes from different types of drives. It didn't change after a tire down size, new spark plugs, air filter, and a couple other little maintenance items. Being back to a comparable commute and normal around town driving I was at 17 MPG on the ultra gauge, and 17.2 by hand calculating (they're always a few points off). So that's a solid 1.5 mpg increase! And I'm still enjoying the power that these provide, especially hitting the gas at a stoplight.
    Interesting MPG note that I noticed on a trip from Portland to Seattle and back- MPG drops a lot in the 70-75 mph range. 60-65 seems to be the sweet spot on my truck. I guess a big, lifted box isn't so aerodynamic at those higher speeds. ha.
    Thanks again Kel! These are rad.
    YOTA LOVER and mightytacoman[OP] like this.
  9. May 21, 2021 at 4:31 AM
    #1509
    mightytacoman
    Kel
    4.5L 1grfe
    1.5mpg aint nothing to sneeze at! Better yet- that seems to be what most people are getting as an increase. Really glad you're enjoying them buddy.
    gpdx[QUOTED] likes this.
  10. May 21, 2021 at 6:20 AM
    #1510
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    My UG is consistently reading 17.5 MPG with daily driving. Can't recall MPG pre gears. That's with intake, 76MM TB, gears, URD EL headers and HPTuners. I'm also running a Hybrid BAMF front bumper, 32" tires, 4" lift, and 4.56 gears in the rear.
  11. May 24, 2021 at 5:05 AM
    #1511
    YOTA LOVER
    NH
    4th tank of fuel and I’m up to 17.3. This is fun!
    mightytacoman[OP] likes this.
  12. May 24, 2021 at 5:17 AM
    #1512
    mightytacoman
    Kel
    4.5L 1grfe
    Doing a memorial week sale! $15 off for this entire week! My biggest sale ever!
    YOTA LOVER, prise, gpdx and 3 others like this.
  13. May 24, 2021 at 3:39 PM
    #1513
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
  14. May 24, 2021 at 4:11 PM
    #1514
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Been thinking about this for a while, Memorial day discount is the cherry on top :) PM incoming...
  15. May 24, 2021 at 4:30 PM
    #1515
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I saw..
    I've got too many other things to do to the truck right now. Soon tho. And thanks for lookin out Buddy. <3
  16. May 25, 2021 at 1:22 PM
    #1516
    Crgrey42
    Crgrey42 Well-Known Member
    Cory
    CNY
    Superwhite 13 TXPRO DCSB
    I will stop by and grab a set if you're local this weekend!
  17. May 25, 2021 at 1:37 PM
    #1517
    mightytacoman
    Kel
    4.5L 1grfe
    I should be around. Get ahold of me
  18. May 25, 2021 at 3:18 PM
    #1518
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I need to get my set marked before @mightytacoman leaves TW! Or else Im going to have to drive up there and have him install for me
  19. May 25, 2021 at 3:21 PM
    #1519
    mightytacoman
    Kel
    4.5L 1grfe
    I'm not leaving the site anytime soon. No worries on that front
    fatfurious2 likes this.
  20. May 25, 2021 at 3:52 PM
    #1520
    fatfurious2
    David
    Ashburn, VA
    ok thanks! :hattip:
