Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Oct 15, 2019 at 9:10 AM
    #141
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    FTFY
    adubkins likes this.
  2. Oct 15, 2019 at 11:19 AM
    #142
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well that dunna make much grammatical sense no mo
  3. Oct 15, 2019 at 11:22 AM
    #143
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Maybe "Y'all'll" ??
    TireFire likes this.
  4. Oct 15, 2019 at 11:23 AM
    #144
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Brilliant! :cheers:
    p.s. Also sounds like gurgling something. Lol.
  5. Oct 15, 2019 at 11:56 AM
    #145
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    so how will this effect my totally stock v6
  6. Oct 15, 2019 at 12:10 PM
    #146
    mightytacoman
    Kel
    4.5L 1grfe
    Positively. Increase mid/low range, increased fuel economy. Don't take my word for it. look through this thread to see what others are saying or pm some of them.
  7. Oct 15, 2019 at 6:59 PM
    #147
    tathambenjamin
    tathambenjamin Well-Known Member
    ben
    2008 4Runner SR5
    -2.5/1.5 spacer lift -270/65/17 Cooper AT3
    Interested in how these would work in combination with the pedal commander? Anybody have any experience with that?
  8. Oct 16, 2019 at 5:59 AM
    #148
    mightytacoman
    Kel
    4.5L 1grfe
    The pedal commander wont effect these. separate systems.
  9. Oct 16, 2019 at 7:21 AM
    #149
    sr57e
    sr57e Well-Known Member
    Alex
    Dallas, TX
    05 preRunner
    Motor: k&n intake -Wheels: xd wheels/ dynopro 265/70/17 -Front: icon LT coilovers w/ camburg uniball UCA -Rear: Weavers HD, Icon 2.0r soon: 4.56 gearing/ arb / dual compressor
    its not retard; its angle challenged
  10. Oct 16, 2019 at 11:27 AM
    #150
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    I'm "stock" motor-wise but I have a tune via HPTuners that requests a little more timing advance and adjusts the throttle mapping. Truck drove better after the tune, but feels more powerful and smooth now with the cam gears.
    They are a great bang for the buck.
    I need to get logs and see if I can get moar powa out of them with a re-tune.
    mightytacoman[OP] likes this.
  11. Oct 16, 2019 at 2:26 PM
    #151
    tathambenjamin
    ben
    2008 4Runner SR5
    Yeah, maybe I need to ask more carefully. So, the pedal commander I think interacts with your ECU to adjust torque curve via fuel delivery, adjusting timing, etc. If I am understanding what I have read about pedal commander? These gears adjust timing by lengthening the time exhaust the exhaust valve is open, thereby increasing both mpg and generating some low end power by more completely burning fuel in the cylinder due to previously mentioned increased timing?
    So, I get that there are two different systems, but I suspect that a truck with these gears and a pedal tuner in eco or sport mode would drive somewhat differently than a truck just using pedal commander in the same mode. My question: How do they interact? Does pedal commander go to a predetermined torque curve and then the additional mechanical timing retard still happens via the gears? Is pedal commander constantly adjusting- would it cancel out the gains of these gears and simply perform like a truck only using pedal commander?
    Hopefully you catch my drift- they are both affecting mpg and timing. Are they beneficial/ necessary together?
  12. Oct 16, 2019 at 2:29 PM
    #152
    tathambenjamin
    ben
    2008 4Runner SR5
    Your comment here may address my questions. Going to figure out if HPTuners essentially works like pedal commander.
  13. Oct 16, 2019 at 2:45 PM
    #153
    mightytacoman
    Kel
    4.5L 1grfe
    I see what you're saying. Explaining it isn't easy but the jist of it is the tables that pedal commander modifies signals for are different tables than those affected by changing these gears. Pedal commander only modifies the signal that would effect the "accelerator pedal position° table. Where as the gears have more to do with knock learn tables and ignition timing.
    Pedal commander is a signal modifier that doesn't change the tables themselves. Hptuners allows changing those tables plus a whole bunch more..
    smelly621 likes this.
  14. Oct 16, 2019 at 3:28 PM
    #154
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    They make the exhaust valves open later, reducing the overlap when intake and exhaust valves are both open. Duration of valve opening is determined by the camshaft profile which isn't changing here.
    Indeed, the ECU will be able to run more advance (fuel/spark) with the gears, regardless of if you had a pedal commander or not. The pedal commander will continue to work the same as with OEM cam timing.
    Correct, these gears are always doin' their gear thing, and there is no variable exhaust timing on our version of the 1GR.
    It's altering the throttle position signal before it gets to the ECU, but based on my understanding that's all it can do - there is no feedback from the ECU to the pedal commander.
    As mentioned - HP tuners is able to change the tables/calibrations for the throttle pedal, fuel/spark timing, intake runner length change-over, maf calibration table, auto trans shift-points, etc..
  15. Oct 16, 2019 at 4:29 PM
    #155
    tathambenjamin
    ben
    2008 4Runner SR5
    I appreciate all the clarification. I am starting to understand. Im sure I will be back with more half informed questions. :DDefinitely considering adding these to the list of future additions. Need to do the valve cover seals, so will be in there anyway.
    Torspd and mightytacoman[OP] like this.
  16. Oct 17, 2019 at 12:27 PM
    #156
    Sailor_Nick
    Sailor_Nick Well-Known Member
    Nick
    Massachusetts
    2011 Tacoma TRD-OR DCSB 6-speed
    Bilstein 5100's, 32" tires
    I installed these about 6 weeks ago and have put a few tanks of gas through the truck since then. I was mainly looking for MPG increase but the extra power is nice too. My truck is bone stock besides URD EL headers. Stock ECU no tuning.
    The truck definitely runs better and smoother throughout the rev range. Shifts smoother (6MT) i think because of the better valve overlap and scavenging. feels a bit more powerful in the low-mid range
    Previous MPG was averaging about 16 and maybe 17 if driving VERY gently. MPG's are now 18, 17, 18, 19 MPG in the last few fill ups with normal driving. getting about 310 miles on a tank before dangerously low level. the Gains are worth it in my opinion.
    I'm impressed and would recommend to anybody with a 4.0. @mightytacoman was great to deal with and gave excellent support. He's doing us all a great service by machining these gears for such a great price.
    stvhwrd, old55guy, Torspd and 6 others like this.
  17. Oct 17, 2019 at 12:31 PM
    #157
    mightytacoman
    Kel
    4.5L 1grfe
    Thank you for taking the time to write the review buddy. I appreciate it!
    old55guy and Sailor_Nick[QUOTED] like this.
  18. Oct 30, 2019 at 10:00 AM
    #158
    mightytacoman
    Kel
    4.5L 1grfe
    Bump up.
    More sets coming in.
  19. Nov 5, 2019 at 10:02 AM
    #159
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    For those who have done this have you reused valve cover gasket and surgetank/upper intake manifold gasket?
    garciav and TireFire like this.
  20. Nov 5, 2019 at 10:05 AM
    #160
    mightytacoman
    Kel
    4.5L 1grfe
    50/50. By my understanding of it now, if your gasket isn't cracked, I would reuse it.
    old55guy likes this.
