Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Jul 21, 2021 at 10:56 AM
    #1681
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Welp, I think its lifter tick. Nevermind folks, false alarm.
  2. Jul 21, 2021 at 11:18 AM
    #1682
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I was gonna say my engine has always ticked since new.
  3. Jul 21, 2021 at 12:15 PM
    #1683
    fatfurious2
    David
    Ashburn, VA
    Catch 22 I guess here. Don't want to put too many miles before my big trip, but have to drive so not to have lifter tock. Maybe it was more pronounced beyo havent driven in a couple weeks an need an oil change
  4. Jul 28, 2021 at 10:57 PM
    #1684
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Lol classic Toyota lifter tick. Been no stranger to that since my 22r-e pickup. Got a kick out of the fact that the 4.0L used the same oil filter when I got it.
    Torspd likes this.
  5. Aug 16, 2021 at 1:40 PM
    #1685
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    I pulled this out today, for science! Really though I added this and the cam gears at the same time, and I’ve been curious if just the gears will net better mpg’s. I’ll report back after a few tanks
  6. Aug 16, 2021 at 3:18 PM
    #1686
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    There not in the pic but I have my second installation under my belt. 90B8FFC3-1890-4FA0-97B8-54A4C4D95C30.jpg The drive side was a mofo to pop loose me at 340# and my big buddy at 375# put enough hurt on it that the cam was slipping in the 24mm wrench. Went to a buddy’s shop and got a Snapon 24mm and 17mm extended Flank drive. Sounded like a gun shot when it broke loose.
  7. Aug 16, 2021 at 7:18 PM
    #1687
    montijo505
    Also, I noticed my throttle body is filthy, I've never cleaned it since I got it at about 92k miles. Sitting at 169k now. I didn't clean it today because I don't have any cleaner on hand. Also, did not want to change anything but removing the spacer. After two or three tanks though, I want to clean it. What is everyone using to clean the throttle body? I also need to install an oil catch can since there was some oil on the gasket for the spacer. I know the PCV valve is good because I replaced it when I installed the gears and spacer along with the spark plugs.
    knayrb likes this.
  8. Aug 16, 2021 at 7:54 PM
    #1688
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Do kill the messenger but I use throttle body cleaner:anonymous:
    montijo505[QUOTED] likes this.
  9. Aug 16, 2021 at 8:21 PM
    #1689
    montijo505
    Lol I meant any brand in particular anyone can recommend?
  10. Aug 16, 2021 at 8:30 PM
    #1690
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    I use CRC because that’s usually what’s in stock
  11. Aug 17, 2021 at 11:41 AM
    #1691
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    looking to get these installed in southern california. i'm on 255/80s now so up to 33, although the tires are "only" 50lbs each. I feel a little loss of power, but not much. hoping cam gears helps without having to regear my prerunner.
  12. Aug 17, 2021 at 11:44 AM
    #1692
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    @greenEFSI :boink:
    He's the goto installer out that way.
    greenEFSI likes this.
  13. Aug 17, 2021 at 1:58 PM
    #1693
    greenEFSI
    greenEFSI TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
    Dm sent :cheers:
  14. Aug 17, 2021 at 4:19 PM
    #1694
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I just through cleaning my TB an hour ago. I wish I had taken a picture on how dirty it was. The back side probably had a 1/32” tar on the butterfly and sides. Took a half can of CRC Throttle body cleaner and a tooth brush. I paid particular attention to the seam where the butterfly flap touches the body and the flap. It’s not sparkling clean but a ton better. The idle is smooth and steady now.
  15. Aug 22, 2021 at 6:23 AM
    #1695
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    @Gallowbraid You need these! ;)
    12TRDTacoma and Gallowbraid like this.
  16. Sep 3, 2021 at 11:43 AM
    #1696
    mightytacoman
    Kel
    4.5L 1grfe
    Bumping this up. Happy labor day weekend y'all.
    Be safe and have fun everyone.
  17. Sep 18, 2021 at 1:02 PM
    #1697
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Hey bud you got any more available?
  18. Sep 18, 2021 at 5:47 PM
    #1698
    mightytacoman
    Kel
    4.5L 1grfe
    Sets in stock ready to head out the door. Shoot me a pm and I'll get you squared up.
    12TRDTacoma likes this.
  19. Sep 22, 2021 at 8:58 PM
    #1699
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    Sent payment this morning and got confirmation they should ship out tomorrow. Looking forward to installing them on my FJ. Glad I stumbled upon this thread.
    montijo505 and plurpimpin like this.
  20. Sep 22, 2021 at 10:21 PM
    #1700
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Wait what? If I’m not mistaken the FJ is twin VVI.
