Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Apr 26, 2022 at 7:16 AM
    #1921
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Here's my before and after mileage for a year. No real power gain has been noticed, less engine braking when letting off the gas gives a feeling of less rolling resistance.
    *I run 2 sets of tires 255/85/16MT and 265/75/16AT, some low numbers are offroad
    1 year before Cam gears Average 14.64397mpg
    1year after Cam gears Average 15.30167mpg
    GilbertOz, Slashaar and HappyGilmore like this.
  2. Apr 26, 2022 at 8:28 AM
    #1922
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Is this something you do just to verify the cams are installed correctly?
  3. Apr 26, 2022 at 8:30 AM
    #1923
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Urd has said that some of these trucks left the factory with incorrect timing. I haven't seen or heard of anyone here having that problem but it certainty doesn't hurt to check while your there.
    Slashaar likes this.
  4. Apr 26, 2022 at 8:31 AM
    #1924
    Scott B.
    Scott
    Georgia
    Quick question -
    What is the trick to release the piece holding the 2 heater hoses to the back of the intake?
    I can see (in a mirror) what looks like a release, but haven't figured out to open it.
  5. Apr 26, 2022 at 8:31 AM
    #1925
    Scott B.
    Scott
    Georgia
    I will definitely check. It's only 36 rotations...
    Sandman614 likes this.
  6. Apr 26, 2022 at 8:34 AM
    #1926
    mightytacoman
    Kel
    4.5L 1grfe
    I think the trick is to go from the wheel well but I personally never installed these on a late model 2nd gen. @greenEFSI care to chime in?
  7. Apr 26, 2022 at 8:37 AM
    #1927
    greenEFSI
    greenEFSI TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
    Don't bother with the clip it will break and is not sold separately. Use a deep 10mm socket on a 1/4" ratchet and remove the 10mm bolt that secures the bracket to the manifold :thumbsup:
  8. Apr 26, 2022 at 8:37 AM
    #1928
    Scott B.
    Scott
    Georgia
    Interesting...
    I can get very close to it from the top, but there is limited room between the intake and the firewall.
    I think I will find a bigger mirror, and see what I can see.
  9. Apr 26, 2022 at 8:38 AM
    #1929
    Scott B.
    Scott
    Georgia
    Thank you.
    I'll give that a try.
  10. Apr 26, 2022 at 8:55 AM
    #1930
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Guessing NGK copper plugs?
    4.56 is pretty ideal if you drive 65(+) on the freeway. I'm on 35s with 4.88 and I'd be happier with 4.56. I will change back down when the 8" axle breaks. No problem getting around 15mpg mixed driving otherwise.
  11. Apr 26, 2022 at 9:41 AM
    #1931
    gpdx
    gpdx Well-Known Member
    Portland
    13 DCSB TRD Offroad
    5100/887, topper, rack, 265/75/16
    There’s one tab on each hose that locks them on to the metal clip. With a mirror and a small pick or screwdriver you can get them off. When I helped @TheOnlyPajooned we pushed on the tabs the wrong way for 10 minutes and when we switched they came off right away. Can’t remember if it was pushing up or down on them that worked.
  12. Apr 26, 2022 at 10:42 AM
    #1932
    Scott B.
    Scott
    Georgia
    I found the bolt! It was easy to see on the other side of the engine.
    Bolt out, continuing on my way. The SAIS is next...
  13. Apr 26, 2022 at 12:22 PM
    #1933
    gpdx
    Portland
    13 DCSB TRD Offroad
    Going through the wheel well will give you easier access to a few of those SAIS bolts.
  14. Apr 26, 2022 at 12:55 PM
    #1934
    Scott B.
    Scott
    Georgia
    Absolutely!
    Also, I pulled out the rear mounting stud. The one steel pipe didn't want to move off the studs - it was easier to pull the mounting stud out of the valve cover.
  15. Apr 26, 2022 at 12:57 PM
    #1935
    Scott B.
    Scott
    Georgia
    Another question -
    Fuel rail, driver's side, at the firewall end - I have what appears to be the fuel inlet, with a connector that is interfering with removal of the valve cover. I see the locking mechanism to release the fuel line.
    Question is, is the line pressurized? If so, how do I gracefully release the pressure?
  16. Apr 26, 2022 at 12:59 PM
    #1936
    mightytacoman
    Kel
    4.5L 1grfe
    you shouldnt have to disconnect that. but if you're insistent on it needing to be done- there is little to no pressure in the line. it'll drip out some is all
  17. Apr 26, 2022 at 1:02 PM
    #1937
    Scott B.
    Scott
    Georgia
    So there is room to wiggle the VC forward to clear it? It didn't seem like it - but I didn't push too hard.
  18. Apr 26, 2022 at 1:04 PM
    #1938
    mightytacoman
    Kel
    4.5L 1grfe
    wiggle more, It'll clear
  19. Apr 26, 2022 at 1:05 PM
    #1939
    Scott B.
    Scott
    Georgia
    I will give it a try.
    Thanks.
  20. Apr 26, 2022 at 3:44 PM
    #1940
    Ted Yoder
    Ted Yoder Well that didn't work
    06 DCLB
    In Progress
    Yup. NGKs. After my Moab trip, I wish I was running 4.88s. But the 4.56 is decent for highway driving. On the 2nd tank of fuel now. Noticeable difference in power and smoothness of idle and shifting.
