camber after lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KeithB, Apr 21, 2009.
  1. Apr 21, 2009 at 10:40 AM
    KeithB
    KeithB [OP] Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Just wondering if anyone else noticed their front wheels look like this \ / from the front end after lift. I got an alignment done at firestone after 2.5" lift Icons and TC UCA's. It drives great, no drifting or vibrations, absolutely no issues but just looks a little off / funny ya know.
  2. Apr 21, 2009 at 10:43 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    mine looks like that right now cause i haven't had an alignment done...
  3. Apr 21, 2009 at 10:54 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    the TC Uca's should fix that. I think you may have had an inexperienced alignment tech. the same thing has happened to me. Take it back its not right.
  4. Apr 21, 2009 at 11:04 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    i just got back from getting my truck aligned. just put icons on but is at factory lift (2") and it took them a bit to align, but they got it back to factory specs with no problem with stock a-arms
  5. Apr 21, 2009 at 11:09 AM
    KeithB
    Keith
    Cheshire, CT
    Feels right, just doesn't look right. I thought the TC UCA's were supposed to correct caster not camber. Camber should be uneffected by the lift. Heres the numbers:
    Camber: 0.5 / 0.3 spec -0.3 to 1.2
    Caster: 2.5 / 2.5 spec 1.3 to 2.8
    Toe: -0.3 / 0.3 spec -0.4 to 0.07
    Caster was the one that was way off before alignment but after lift at 3.6 / 3.9. But positive camber numbers give it the \ / look. I guess 0 / 0 would look like | | and negative number would be / \ .
  6. Apr 21, 2009 at 3:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    There is no reason the shop shouldnt be able to get the camber to 0*. Have them do it again. Tell them you want 0* Camber, and 0* Toe. Caster should fall inline, and to spec.
  7. Apr 21, 2009 at 3:24 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Mine looks like that too but I havent had irregular tire wear or any ill-handling characteristics. Just looks a little goofy.
    I'm due for an alignment, I'm going to get it done as soon as I have the cash to change the front lift on my truck to all OME stuff, already have the coils, just need the $400 shocks.
  8. Apr 21, 2009 at 3:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OME shocks should only be around $300.00 or less. Check out Wheelers, and see what they have.
  9. Apr 21, 2009 at 4:05 PM
    RelentlessFab
    Eric
    Sparks, NV
    Ah, yep. Forgot that they were only 300. glad to see that they're not 400 since I'll be getting them that much sooner, and I'm definitely gonna swing by wheelers and pick them up there. Those guys are great over there.:cool:
