Camburg 4" lift spindles and shocks install is finally DONE!!!
Discussion in 'Suspension' started by 08pretaco, Dec 31, 2009.
  1. Jan 26, 2010 at 10:09 AM
    #41
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
    Okay thanks I figured you wouldn't just wanted to confirm :thumbsup:
  2. Jan 27, 2010 at 10:29 AM
    #42
    JNL
    JNL Well-Known Member
    Jamie
    Atlanta
    08 DC Prerunner TRD Sport
    Would it be easier to completely disconnect the calipers/remove brake lines first and test fit them on the new spindles? It seems like it would be easier to grind them down when they are off the truck. Can you just use a dremel to grind them down?
    How hard was it to remove the hub assembly from the spindle? Any special tools required?
    I have really been wanting to get a set of these, I just want to know how hard the install is going to be.
  3. Jan 27, 2010 at 10:57 AM
    #43
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Its easy to remove the hub assembly, 4 bolts each side and no special tools required at all.
    The grinding is easy, once things are back on place the caliper on the disk and if it doesn't slide all the way on to align the 2 bolts take it off and grind until it does. At that time its a do and check thing.
    Set aside a good 8 hours to do this you will need all the time and be patient. Things don't always go smoothly but if you rush it and get mad your likely to mess something up. Many people have done this themselves and with instructions, patient, and asking questions to other members very easy!
  4. Jan 27, 2010 at 11:19 AM
    #44
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    What about your sway-bar, i didnt see one there! Did you remove it?
  5. Jan 27, 2010 at 6:39 PM
    #45
    08pretaco
    az
    Long long long ass time ago. I hate that damn sway bar, much better flex off road and on road manner hasn't changed much for me if any!
  6. Jan 29, 2010 at 1:35 PM
    #46
    08pretaco
    az
    Alright this is a heads up for those who install themselves: you need the grease the balls off the wheel bearings and new housing assembly otherwise your wheel bearings will go to hell and you'll have to take off the hub assmbly, break lines and all that good stuff.
    Mine just went and I'm not a happy camper :(
  7. Jan 29, 2010 at 11:40 PM
    #47
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    ^ why would you have to add extra grease? as long as you kept the bearings completely clean when you installed them, there should be no issues w/ the swap? there was no extra grease in my OEM spindles when i installed mine.
    i think there is some other cause as to why yours failed.
  8. Jan 29, 2010 at 11:58 PM
    #48
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    :thumbsup: Sick dude! Hate these damn gov comps, can't wait to check out the vid
  9. Jan 30, 2010 at 9:21 AM
    #49
    08pretaco
    az
    When I called camburg that's the only thing that they told me. I also mentioned that I didn't take apart the hub assmbly and also noticed that there wasn't any greasy in my spindle. They still mentioned that that's most likely the problem. I'm gonna take it in for another alignment and see what happens with that. Otherwise there really isn't anything else I can do, well take it in to toyota or a shop to see if they can figure it out other than that I don't know
  10. Jan 30, 2010 at 2:56 PM
    #50
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ well, that doesnt really make any sense to me. i'll ask some of the mechanics i know at the refineries that i work w/ to confirm, but it sounds like camburg is bs'ing a little on this one.
  11. Jan 30, 2010 at 5:05 PM
    #51
    08pretaco
    az
    ^what do you think it might be? I went to the alignment shop, my alignment checked out and thinking about it it doesn't make sense because the hub assembly was never taken apart.
    I don't kmow what it could be cause my wheels are balanced :confused:
  12. Jan 30, 2010 at 6:44 PM
    #52
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ well...what exactly are the symptoms? why do you think it is the wheel bearings? what exactly is the problem?
    cant really suggest anything until i know exactly what is the matter.
  13. Jan 30, 2010 at 9:15 PM
    #53
    08pretaco
    az
    Forgot I didn't post in this thread sorry.
    Ok so when I get to cruising speeds around 55+, I get spuratic steering wheel vibrations. They can range from 30 min of driving then the return trip no vibrations at all. On a given drive it can go 5 min of vibrating a couple of it stopped then a min of vibrating and then 20 minutes of it not.
    I have gotten tire balancing done mulptiple times as well as took it back in for a realignment, non of that helped. I have gone over the install and retorqued everything I could without getting the bolts on the hub assembly, I visually looked and non of them are backed out at all.
    Any ideas?
  14. Feb 3, 2010 at 2:46 PM
    #54
    08pretaco
    az
    i dont have the sway bar connection bracket incoperated with my spindles....how do i go about doing that?
  15. Feb 3, 2010 at 2:59 PM
    #55
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Is that one of those. "You don't need them,but their reccomend." ?
  16. Feb 3, 2010 at 3:04 PM
    #56
    08pretaco
    az
    no with spindles you really dont need them, spend the 450+ on something else :)
  17. Feb 3, 2010 at 3:14 PM
    #57
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Took me about 30 minutes each spindle to get that DAMMNNNNN!! ABS sensor in.
  18. Feb 3, 2010 at 3:56 PM
    #58
    yosh2000
    CO
    '17 Tundra CM 5.7
    you trade your current spindles w/ camburg w/ the spindles that have the sway bar provisions in them! seriously, you would have to do some fabbing, cutting and welding to make the sway bar work if they did not come from camburg like that.
    this is the reason i got mine w/ the sway bar provision, i can always not use it, but at least i have it!
  19. Sep 16, 2010 at 11:55 AM
    #59
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Hey man what size tires are you running in these pics? What tire is it? What do you have the coilovers set at? Is it 1.6" (coils) + 4" (spindles) totaling 5.6"?
    I'm seriously considering getting some Camburg spindles but I dont wan't them to dwarf my 265/75/16 Duratracs, which are basically brand new so I am stuck with them for a while.
  20. Dec 9, 2010 at 6:50 PM
    #60
    NoMallCrawlTaco
    NoMallCrawlTaco © "HELL FUCK YEAH!" © COPYRIGHT FOR MY PROTECTION!
    Arizona
    4" Camburgs Icon AAL 3 Pac BLHM Tacoshi Grill More to come...
    Got my Camburgs today.
    How do those new brake lines connect?
    Did you ever find out what the vibration was?
