Camburg Ball Joint UCA Install
Discussion in 'Suspension' started by nvdeserted, Apr 7, 2010.
  1. Jan 28, 2011 at 7:27 PM
    TacoBow
    TacoBow Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    I'm with ya there... I see how their uniball and standard ball joint UCA's differ.
    What I'm looking for is how much increase in caster do the Camburg standard ball joint UCA's allow over the stock UCA. (Or compared to the Light Racing UCA would be nice to know as well.)
    As advertised, the LR UCA claims a + 2 degree gain over stock.... and uses a OEM "like" ball joint. I like the fact that these use a stock ball joint... mainly for the weather we have here.
    Got any numbers?
  2. Jan 28, 2011 at 7:45 PM
    Hugebergen
    Hugebergen Crash and burn live and learn
    Saskatoon Sask
    3"Toytec ULK, box mat, angle brackets in box corners for tie downs, anytime fog lights, bhlm, black grill and lip, trimed front flaps, 7089 procomp rims with 285/75/16 Toyo M/T tires, black badges with trd badges added,anytime foglights, lamin-x yellow fogs, illuminated 4x4 switch, colour match satoshi, Camburg ball joint UCAS.
    I'm getting these forsure. But I might get them with the b/j installed and not reuse the stock ones. Good right up
  3. Jan 28, 2011 at 10:09 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    No I do not. But it will be enough to correct for alignment problems associated with lift.
  4. Jan 29, 2011 at 8:55 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Only difference is in the strength. I've confirmed with camburg they have as much added droop and built in caster as its stronger brother. I know I have 3* caster and could get more if I wanted. Not sure about LR as far as added droop but it seems their caster is adjustable as where burgs is built in.
  5. Jan 29, 2011 at 8:12 PM
    TacoBow
    Central PA
    That's the info I was searching for...
    I'm hoping to learn if the Camburg OEM ball joint type UCA will allow for a zero degree camber setting while maintaining at least a 2 degree positive caster when combined on a 2nd generation Tacoma with a 2 or 2.5 inch lift.
    I was considering 5100 shocks up front, on their max 2.5 inch setting, but didn't want to purchase these UCA's if a 2+ caster and a 0 degree camber was not possible after install.
    Thanks to all who replied. :thumbsup:
  6. Feb 23, 2012 at 4:14 PM
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB
    sub'd
  7. Mar 27, 2012 at 11:07 PM
    Manwithoutaplan
    ID
    OK so i just installed these bastards today. My question is their a cover so water doesnt just sit in the pocket where the bj is??? MY other question is how the heck do you get the dust cover on any tips???
    sorry for thread revival
  8. Mar 27, 2012 at 11:11 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    That was one of the complaints from previous owners when I was reading through old threads. I haven't gotten a chance to check these out in person, but I'm thinking I'd probably drill a small drain hole.....course, I'd have to look at it to be sure.
  9. Mar 27, 2012 at 11:40 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    What dust covers did you get?
  10. Mar 28, 2012 at 10:09 AM
    TacoBow
    Central PA
    I never did find a cover that would stay in place atop the opening in the UCA. That's probably a good thing for around here, snow and slop and salt and such, followed by mud and grit and chit... all that trapped inside and speed corrosion. I just hose it out real well when I wash the truck and forget about it. It'll hose ya back, so move out of the way when ya put the water to it.
    As far as that dust cover, when I did mine, the rubber grease boot over the ball joint was held in place by a spring steel clip. Start one edge and just work it back on carefully. You could use some type of pry tool I suppose, (like a wooden paint stick blunted down on the belt sander to resemble a over sized straight screw driver), BUT if you slip, you could be buying a new boot.
  11. Apr 21, 2013 at 11:01 AM
    djo991
    djo991 Active Member
    07 Double cab SR5
    Nothing on it .... FOR THE MOMENT
    Some plasti dip could seal this opening ?
  12. Jul 22, 2013 at 1:27 PM
    anotherreject
    anotherreject Well-Known Member
    Can i follow these instructions to replace my upper ball joint on a 2nd gen? Or is there something different or any other steps i need to know?
  13. Jul 22, 2013 at 2:55 PM
    Manwithoutaplan
    ID
    Yep you can.
  14. Jul 23, 2013 at 8:13 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    So, will they? I just bought 2nd Gen DCSB that already had the Camburg Ball Joint UCA'S installed. Will they work well with Bilstein 5100 OME 885 combo?
  15. Jul 24, 2013 at 8:46 AM
    #35
    Manwithoutaplan
    ID
    Here is help thing for the ball joints for camburg arms. Used a Door cap that you would find at home depot with some Silcone.
  16. Jun 6, 2014 at 12:31 PM
    #36
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  17. Nov 11, 2014 at 8:23 PM
    #37
    austin62
    austin62 BushMaster
    Austin
    california
    99 LT trd, 2002 2.4l
    Halfed 3 linked on 33s with 4wd , kings infront ,foas in rear and bumped and strapped 24 travel in rear and 16 infront all bumped on foxs. Fully caged and lights galore
    Also if you have ever had to pay for the camburg balljoint rebuild kit compared to the uniballs its night and day price difference
  18. Oct 9, 2015 at 2:46 PM
    #38
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    Any updates in the Camburgs ..how they are holding out etc ..thanks
  19. Nov 13, 2015 at 2:25 PM
    #39
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    New camburgs are black :) thanks to your write up my install def went smoother !!image.jpgimage.jpgimage.jpg
  20. Jul 31, 2016 at 1:53 PM
    #40
    Tacomalx4x4
    Tacomalx4x4 Well-Known Member
    Corey
    Wv
    07 6spd DCSB silver
    3inch ultimate, straight exhaust, XD's 285's, grill, lights, fog mod, jvc unit. Rear cam mod, pioneer 3ways
