Camburg Ball Joint UCAs vs LR Adjustable UCAs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by goufcustom, Aug 1, 2012.
  1. Aug 1, 2012 at 4:02 PM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Trying to decide, I need some UCAs, and after shipping I can get either of these for the same price: $400. I have an extra set of stock UCAs (~6k miles) so the fact that the Camburg's dont come with Ball Joints is a non-issue. I also have access to a press so installing the ball joint is also easy.
    For the LR they are nice because they have the ball joint with them and they are adjustable. Worried that the adjustability will be the downfall or could come loose. Sounds like there was a design change to solve the bushing issues too.
    The Camburgs are nice because they are simple, no moving parts for the moron doing the alignment. I am concerned that the ball joint could come out, but that should be very unlikely.
    I am not able to swing for the uni-ball ones unless I find a used pair for $400 or less by the weekend or so.
    I see tons of folks with the LR ones, and no issues, but the Camburgs have a draw to them for simplicity and the name sake. I would order the LR from Fat Bobs and the Camburgs would come from DSM.
    ETA: Which would you go with and why? Seems like the Camburgs are relatively new, so more folks have the LRs.
    ETA: I have a TRD Off Road 2nd Gen DC SB with 5100s in the front set at 0.85 with eibachs. So about 2.5"+ of total lift in the front, on factory wheels, maybe bigger tires soon. I dont want to rub on UCAs on the bigger tires. I also need caster and camber increases, so if the Camburgs wont give me more camber then that makes my mind up quick.
  2. Aug 1, 2012 at 4:04 PM
    jandrews
    '09 FourDubDee TRD OR
    Uniball is stronger, no need for adjustability because the design of the arms and the misalignment spacers of the uniball allow for correct alignment.
    Uniball, always, if given the choice.
  3. Aug 1, 2012 at 4:18 PM
    goufcustom
    MD
    Not the question... I am not able to spend the extra $300 for that, and the "stronger" part is really not needed, my offroading is minor and mild at best.
  4. Aug 1, 2012 at 4:20 PM
    jandrews
    There is not a single question mark in your entire OP. What is it exactly that you want to know?
  5. Aug 1, 2012 at 5:01 PM
    goufcustom
    MD
    Fixed :eek:
  6. Aug 1, 2012 at 7:02 PM
    jandrews
    Well, you have my answer.
  7. Aug 1, 2012 at 8:43 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Not sure how much newere the Camburg is than the LR. Seems to me they've both been around long enough. I think the appeal of the LR is that you don't have to go through the work of switching out the ball joint and if I'm not mistaken, the ball joint in the LR is reported to be a little stronger than stock.
  8. Aug 1, 2012 at 8:52 PM
    jandrews
    ...Don't have to swap any balljoints with camburg either...the entire UCA gets replaced. I wouldn't be surprised if LR is beefier.
  9. Aug 1, 2012 at 9:00 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    LR have some adjustability
    Camburgs look prettier?
    My camburgs came with ball joints pressed in already so were straight bolt in
  10. Aug 1, 2012 at 9:44 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    FWIW you can replace the ball joints on the LR UCAs pretty damn quick and easy, all you do is unbolt it top and bottom and swap in a new one. I like that feature too.
    Also I know you like the name Camburg but SPC is a pretty big name in alignment parts. Lot's of shops will replace oem parts with SPC. Just FYI.
  11. Aug 1, 2012 at 10:20 PM
    penguins_cc
    Will
    Bellevue, WA
    Are we talking about the ball joint Camburg or the uni-ball Camburg UCA? When I was researching UCAs, it seemed tha their uni-ball UCA comes with the ball, but the ball joint UCA uses the ball joint from your stock UCA. For example:
    FWIW, I gave the Camburgs some serious consideration before I went with the Desert Industries UCA. No particular reason except I was infatuated with the UCAs I purchased.
  12. Aug 1, 2012 at 10:23 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  13. Aug 2, 2012 at 3:54 AM
    goufcustom
    MD
    Talking about the Camburgs that use the factory ball joint not the uniballs, need a budget option, unless a used set of uniballs come up for sale soon.
    Anyone ever have issues with the shop adjusting the LRs?
  14. Aug 2, 2012 at 6:18 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    They're not going to adjust the LRs, unless you pay a custom alignment shop lots of money, that's my opinion anyway. You'll have to set them, then let the shop deal with the LCA cams to dial it all in.
  15. Aug 2, 2012 at 10:15 PM
    jordanmcqueen
    jordanmcqueen Active Member
    jordan
    salt lake city
    white, smooth ride, with plenty of potential!
    20% tint to match the back, immryo rear view mirror adjustment, 3" suspention lift, black front valance, wheels in the market.
    How important are new UCA's when putting a three inch lift kit on?
  16. Aug 2, 2012 at 10:39 PM
    OZ-T
    Peter North
    British Columbia
    Depends how perfect you want your alignment to be
  17. Aug 2, 2012 at 11:18 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Id get the camburgs if you dont mind going to a shop to press in the ball joints. The camburgs seem beefier in my opinion. I the camburg uniballs and my friend had the uniball version. The construction is nearly exactly the same. That and they dont have the bushing problems. Ya. Id go with the camburgs. Just dont get moog ball joints because they wont fit. They warn you on camburgs site.
  18. Jan 20, 2014 at 9:56 PM
    SpeedwayBlueAlex
    SpeedwayBlueAlex Well-Known Member
    Alex
    Modesto
    SWB 4x4 TRD OFF-ROAD 6-SPEED
    I just replaced my lower ball joints on my taco last week and was actually getting ready to order camburg ucas. If I get a different upper ball joint (keep moog as my lower ball joints ) will that work? Or dos the lower and upper ball joint have to be the same for them to work on camburgs ucas:confused:
  19. Jan 20, 2014 at 10:37 PM
    1tacoplease
    1tacoplease I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I'm running g 5100's in the front set at the highest. Don't really notice any issues. Are getting UCA's necessary?
  20. Jan 21, 2014 at 7:36 PM
    1tacoplease
    Temecula
    Do I need to get some new UCA's?
