Camburg Balljoint UCA's
Discussion in 'Suspension' started by RecklessTaco, Dec 29, 2010.
  1. Dec 29, 2010 at 2:09 PM
    RecklessTaco
    RecklessTaco [OP] Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 33x12.50-17General Grabbers on 17x9 Black RBP 93R rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    So i had a question about the Camburg Balljoint UCA's?
    1- Are they better than stock? WHY?
    2- Why wpould someone spend the money to go with Camburg Balljoint UCA's instead of the Uniball joints?
    Im just trying to understand the thought process on this matter. i mean come on the whole purpose of the Uniball is to get rid of the crapy restricted balljoint, right?
  2. Dec 29, 2010 at 2:21 PM
    RecklessTaco
    Topaz Lake, Nv.
    So if im getting rid of my stock balljoints, do you think the Camburg balljoint UCA's are good, are the better than stock?
  3. Dec 29, 2010 at 2:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Most use the ball joint UCA's to save a few bucks. THe Uniball UCAs are stronger.
  4. Dec 29, 2010 at 2:23 PM
    RecklessTaco
    Topaz Lake, Nv.
    so if im looking for good Midtravel then i would want to go with the Uniball UCA's, right?
  5. Dec 29, 2010 at 2:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Right. The Total Chaos UCA's arent noisey like the Camburg, or Allpro ones, but they are a little pricey
  6. Dec 29, 2010 at 2:33 PM
    RecklessTaco
    Topaz Lake, Nv.
    What do you think about the new UCA's from DownSouth Motorsports?
  7. Dec 29, 2010 at 2:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Havent had a chance to try them. No idea on how much caster is built into them, what hardness Uniball, or manufactue rthey use, etc. They seem kinda bulky from the pics, and not sure how well they would clear larger tiers.
  8. Dec 29, 2010 at 2:38 PM
    RecklessTaco
    Topaz Lake, Nv.
    So if you were picking between TC or Camburg which would you choose?
  9. Dec 29, 2010 at 2:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    TC
  10. Dec 29, 2010 at 2:54 PM
    RecklessTaco
    Topaz Lake, Nv.
    Thanks Chris! You made my mind up for me! TC it will be !:D
  11. Dec 29, 2010 at 2:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  12. Dec 29, 2010 at 4:09 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    both the camburg uniball and ball joints provide the same amount of travel.
  13. Dec 29, 2010 at 6:12 PM
    danstacoma
    danstacoma Well-Known Member
    Dan
    pa
    07 Tacoma
    3 inch lift, painted badges, k&n cold air, cherry bomb, tinted windows, yellow fogs, and more to come
    what does that mean?
  14. Dec 29, 2010 at 7:34 PM
    danstacoma
    Dan
    pa
    07 Tacoma
    well i was debating on a set of uca's myself i didnt now to go with the tc or the camburg......
  15. Dec 29, 2010 at 8:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It really doesnt mean anything. The 1" unibal is WAY strong for anything the Tacoma could be subjected to. However, the 1.25" Unibal that Camburg uses seems to reduce clearance between the UCA and coil. If running a 2.5" coilover, the spring will hit the UCA.
  16. Dec 15, 2011 at 2:58 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Matt did you have stock UCA's when you posted this? haha
    I actually just ordered me some camburg 1.25 UCA's
