Camburg Lift Spindles:Largest tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dubstar2003, Jan 18, 2011.
  1. Jan 18, 2011 at 6:52 PM
    dubstar2003
    dubstar2003 [OP] Active Member
    Jacob
    Texas
    2007 PreRunner
    Projector Headlights Westin Bullguard Westin Nurf Bars Custom Hood Lifts Black'd Out Badges Alpine Headunit w/Ipod Satoshi Grille 6000K HID'S BILSTIEN 5100'S UP FRONT
    Hey TW,
    I am getting the Camburg lift spindles in a few weeks and wondering what is the largest tire I can fit with this lift?
    I'm running 285/50/20 now, but I'm getting a extremely good deal for set 305/50/20 Toyo Open Country's.
    So I guess my ?'s are 1) Will they fit
    2) If Maybe, how much trimming.
    3) What are people running in the rear with the Camburgs upfront?
  2. May 5, 2011 at 9:01 AM
    05offroad
    05offroad Well-Known Member
    Michael
    El Cajon, California
    '05 Long Travel Prerunner
    I've lost track
    Bump..
  3. May 9, 2011 at 1:21 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    I'm curious too.. Is there anything else done to your suspension right now?
  4. May 9, 2011 at 1:24 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    on their site they used to recommend 285/75/16, now they just say that they need a "maximum wheel backspacing of 4.5"
    my manager runs the camburgs with 315/75/16's so you should be good with just about anything..he has 6.5" of lift up front
  5. May 9, 2011 at 1:26 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    1) Will they fit Yes, but prepared to start chopping
    2) If Maybe, how much trimming. Maybe is not a ? You might need an extra lift out of your coils. So Camburg Spindle + 1inch from your Coils. Then the Cab Mount Chopped. You might look into also trimming the pinch well. Inner Fender Flare Trimming and Front Bumper Trimming. Then depends on the offset of your rims too. IT sound like a lot but it really isn't.
    3) What are people running in the rear with the Camburgs upfront? Your rear will need at least a 3inch All Pro lift. You will hit the fender flares when your fully stuffed. So remember that.
  6. May 9, 2011 at 1:36 PM
    05offroad
    Michael
    I've lost track
    ^^^^^ I recently got spindles and I have my cab mount chopped, the inner fender well, and outside flare cut back...I'm only running 285's but there looks to be plenty of clearance for 305's
  7. May 9, 2011 at 1:44 PM
    RAD
    Rad
    LAX & LOGAN
    Yes, but remember, when you turn at full cock or reverse. Thats when you notice the larger tires. Offset backspacing of rims play a part also
  8. May 9, 2011 at 2:40 PM
    05offroad
    Michael
    I've lost track
    My rims have 4.5 back spacing. At full lock there is still plenty of room. But the cab chop is definitely needed
  9. May 9, 2011 at 2:45 PM
    08pretaco
    az
    plenty of room when your not flexed out...right? are you just talking about parking lot manuevers with the wheel locked or are you saying when the wheels stuffed in the well?
  10. May 9, 2011 at 2:45 PM
    08pretaco
    az
    Silly question to the OP:
    Why did you get spindles if you planned on putting those beefy big ass wheels on?
  11. May 9, 2011 at 2:50 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    i run 305/65/17 barely any trimming not even cab mount on the tire size calculator it says mine are bigger than yours will be. also i am running the tsb leaf pack with and added AAL so almost 3 inches in the rear.
  12. May 9, 2011 at 2:55 PM
    08pretaco
    az
    I realize its his truck and i have never seen it so I am curious as to how he came across spindles as his choice for a lift for what he is looking to accomplish. A simple question, nothing demeaning or derogatory just a simple question because I felt like asking.
  13. May 9, 2011 at 3:18 PM
    08pretaco
    az
    I asked a question addressed to the OP curious about his reason. Are you the OP?
