Camburg UCA enlarged receptical
Discussion in 'Suspension' started by Alfamua, May 23, 2020.
  1. May 23, 2020 at 7:12 AM
    Alfamua
    Alfamua [OP] Well-Known Member
    Alfa
    Sacramento
    17 TRD OR
    Fox 2.5 coilovers dsc. Fox 2.o with dakar. SSO slimline stage 1 and 2
    The ball joint spin freely in the Upper Control Arm receptical. Any idea how to fix it? Tried all different brand of ball joints that I could get my hands on still with luck. Moog does have a oversize ball joint, however it's not for this application. What do you guys think about weld it in. Is it even safe?
    https://youtu.be/Z4m2W-8o9gY
  2. May 23, 2020 at 7:30 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    First I would check with Camburg. The brand Loctite does make bearing and sleeve retaining compound and you select it by how much clearance there is.
  3. May 23, 2020 at 7:32 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Are you sure those arms are not meant to use uniballs?
    Did you get the arms used or did you pick them up brand new?
  4. May 23, 2020 at 7:38 AM
    Alfamua
    Alfa
    Sacramento
    17 TRD OR
    I know the difference between uniball and ball joint. I took out a ball joint, which just fall out without being pressed. The other side is fine.
  5. May 23, 2020 at 7:57 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm not questioning your intelligence. Easy bro, just looking at it from the outside in without any info other than what I have on the original post.
    Was the previous ball joint worn out? Its almost as if the cup is defective or worn out somehow which shouldn't be happening.
    Since the sleeve is doing as you indicated, I would pick up a sleeve as previously suggested to get it all nice and tight back in there by Loctite if necessary, but I do know a joint is not supposed to rotate in the cup.
