Camera Source for 2014
Discussion in 'Audio & Video' started by rickoshay45, Apr 12, 2014.
  1. Apr 12, 2014 at 10:05 AM
    rickoshay45
    rickoshay45 [OP] Well-Known Member
    Rick
    Sanford Florida
    2015 Camry SE
    Camera Source now has a backup camera kit for the 2014s. You don't have the take the radio out just replace the tailgate harness.
  2. Jun 1, 2014 at 5:46 PM
    samsquamch1981
    samsquamch1981 Well-Known Member
    Tacoma
    you still may have to take out the head unit if it's not wired to it...unfortunately my 14 was wired at the tailgate, but not to the radio...i ended up having to order the wiring interface to run to my radio now from camera source.
  3. Jun 2, 2014 at 6:14 AM
    rickoshay45
    Rick
    Sanford Florida
    2015 Camry SE
    Good to know.
  4. Jun 2, 2014 at 6:45 PM
    samsquamch1981
    Tacoma
    yeah. if you only have 1 wire coming out at the bottom harness instead of 4, then you're not wired to the head unit.
  5. Jun 3, 2014 at 1:06 PM
    rickoshay45
    Rick
    Sanford Florida
    2015 Camry SE
    The tailgate is wired and connected to a harness under the truck. How difficult is it to remove the head unit if needed?
  6. Jun 3, 2014 at 6:19 PM
    samsquamch1981
    Tacoma
    I haven't taken it out yet, but looks simple to remove...however,Routing all of the new harness wires behind the dash to the head unit is gonna be a huge pita because of all the trim removal, etc...
  7. Jun 4, 2014 at 3:06 AM
    rickoshay45
    Rick
    Sanford Florida
    2015 Camry SE
    I see 4 wires going into the tailgate connector and 4 wires going out to the truck harness. Maybe I'm ok. Another poster in a different thread, also has a 14 Prerunner SR like mine and it was plug and play.
  8. Jun 4, 2014 at 5:48 AM
    samsquamch1981
    Tacoma
    If you have 4 wires coming out of the truck harness yours will be plug and play. Here's my harness with the 1 wire....I won't even be using any of the factory wiring with this install...My new harness should be here today...As soon as it stops raining here I'll install it.
