Camerond05's build page. Slow. Boring
Discussion in 'Long Travel Suspension' started by Camerond05, Nov 26, 2016.
  1. Nov 26, 2016 at 9:42 PM
    #121
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  2. Nov 26, 2016 at 9:44 PM
    #122
    Camerond05
    Camerond05 [OP] Well-Known Member
    Cameron
    Missouri
    2020 Tacoma DCSB
  3. Nov 26, 2016 at 9:46 PM
    #123
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You're welcome. If you're throwing down the bills I want your ride to be as legit as all these - no sense in spending money and not having anything special in the end.
    Camerond05[OP] likes this.
  4. Nov 26, 2016 at 9:47 PM
    #124
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    Yup, good guy right there.
    Do you know the purpose of the battery in the bed?
  5. Nov 26, 2016 at 9:48 PM
    #125
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The core support (sheet metal holding all your engine compartment items in place that aren't directly mounted to the frame) will start to bend / break under the weight of the battery bouncing around on rough terrain.
  6. Nov 26, 2016 at 9:53 PM
    #126
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    Ah gotcha. Thanks man, once again
  7. Nov 26, 2016 at 10:26 PM
    #127
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Mine are piggybacks, the tube configuration I have on the bypass the resi is out of the way, remotes give you some extra flexibility on how you might want to build things. There's like 4 different tube layouts you can order fyi
  8. Nov 26, 2016 at 10:30 PM
    #128
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    I really like your bed cage, still leaves space in the bed. Did you start it from scratch?
  9. Nov 26, 2016 at 10:30 PM
    #129
    Basikbiker
    Trav
    Most people move the battery to the passenger side in the bed to keep the wieght off the support and to combat the "taco lean"
  10. Nov 26, 2016 at 10:31 PM
    #130
    Basikbiker
    Trav
    The only thing on my truck that I didn't build myself were the sliders. I bought those and welded em on
  11. Nov 26, 2016 at 10:31 PM
    #131
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    Understood, do you know what causes the taco lean, luckily my truck doesn't have it. Got a few buddies that have it forsure
  12. Nov 26, 2016 at 10:32 PM
    #132
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    So badass man! Did you just mount up the piggies and get some measurements and go from there??
  13. Nov 26, 2016 at 10:32 PM
    #133
    Basikbiker
    Trav
    The driver, the gas tank and battery are all on the same side that's why
  14. Nov 26, 2016 at 10:35 PM
    #134
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    @Basikbiker shit man, just realized you're from commifornia also! Where abouts?
  15. Nov 26, 2016 at 10:35 PM
    #135
    Basikbiker
    Trav
    No, when cycling the new springs I went to full droop measured full extension, traced the arc of the upper eyelet fully extended on a board, then went to full bump, collapsed the shock to about 1/2" shaft travel left and traced that arc on the same board, where the arcs intersect is where your upper shock mount goes.
  16. Nov 26, 2016 at 10:38 PM
    #136
    Basikbiker
    Trav
    Mar
    mariposa
  17. Nov 26, 2016 at 10:41 PM
    #137
    Camerond05
    Cameron
    Missouri
    2020 Tacoma DCSB
    Not too far. I'm near Tahoe.
    That sounds confusing, but actually pretty simple. Had to reread that a few times! Thanks man!
  18. Nov 26, 2016 at 10:52 PM
    #138
    Basikbiker
    Trav
    Yea it's hard to explain through text
  19. Nov 27, 2016 at 2:59 AM
    #139
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  20. Nov 27, 2016 at 10:10 AM
    #140
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    Also, Don't bother with any +2" kit. If you are spending that kind of money, might as well go big or go home. Also, if you are worried about width between a +2" kit and a +3.5" kit on trails, you probably shouldn't be on that trail anyway!
