Camper Shell -How many seal the top rails with silicone to prevent leaks?-
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ruff -Daulton-, Apr 12, 2022.
  1. Apr 13, 2022 at 2:26 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    For what it's worth, I had a Snugtop put on mine, close to a year ago. Snugtop dealer installed. No any extra measures were done when it was installed (Any that I did anyway..) I just trusted that the installation guys have done it a ga-zillion times and knew what they were doing.
    Well, after going through winter here ... A lot of snow/rain ... Zero issues.
  2. Apr 13, 2022 at 2:30 PM
    GoodDogRUGER
    GoodDogRUGER 2021 SR ACCESS V6 4x4
    Heath
    SOCAL
    2021 SR Access Cab V6 4x4
    6112/5160, 285/75/17 BFG KO2 , SPC, Method 703s, BMC/CMC, ARE DCU,
    What he said... I had to take mine of and seal between the bed and plastic rails.
  3. Apr 13, 2022 at 5:27 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I have an ARE and they did pull off the bed rail caps and silicone under those. Also did a great job on the front of the bed. It was like 4 hour install, I was thinking WTF are they doing in there until I saw what they were doing. Wiring was done very well too.
  4. Jun 14, 2022 at 2:40 AM
    willhahn24
    willhahn24 Well-Known Member
    2016 Tacoma
    Do you have a part number for the rubber plugs?
  5. Jun 14, 2022 at 3:52 AM
    dogodell
    dogodell Active Member
    2019 Tacoma SR
    Butyl tape works to make the plugs necessary to seal the front corners if you don't want to track down oem. There is also a small traingle hole underneath the bed rail in front corners that also needs to be sealed. Butyl here again makes less mess than silicone and ready to use instantly.
  6. Jun 14, 2022 at 4:17 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
