Camry won't start after fueling
Discussion in 'General Automotive' started by ramonortiz55, Oct 8, 2015.
  1. Nov 17, 2016 at 11:46 AM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Okay.
    It cold idles at about 1300 RPM... Then once warms up, it idles at about 800 RPM..
    So I presume it fast idles fine.
  2. Nov 17, 2016 at 11:50 AM
    mschein1
    mschein1 Well-Known Member
    Lincoln, NE
    2021 Tundra OR CM
    Do these have IAC? I would clean that pretty good if so.
  3. Nov 17, 2016 at 12:02 PM
    ramonortiz55
    Ramon
    Texas
    stock
  4. Nov 17, 2016 at 12:03 PM
    ramonortiz55
    Ramon
    Texas
    stock
    I am still curious about this tho.. and how it would apply to the throttle body/IAC
  5. Nov 17, 2016 at 12:06 PM
    mschein1
    Lincoln, NE
    2021 Tundra OR CM
    I would clean the TB as well as possible and get all new vacuum lines.
  6. Nov 17, 2016 at 12:19 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I had the same problem with my 04 Tacoma, it turned out to be a bad charcoal canister, it went bad by me topping off the gas tank too much. same exact symptom fill the gas tank at the station and it acted like a flood condition, I would push the accelerator pedal to the floor and hold it there and then crank the ignition to get it started but would stumble till it caught on. after starting that way the truck would start fine as usual until I refilled the gas tank then it would do it all over again. had no check engine light or trouble codes for it too
  7. Nov 17, 2016 at 12:24 PM
    Mush Mouse
    mush
    2013 SR5
    CHARCOAL CANISTER
  8. Nov 17, 2016 at 12:24 PM
    ramonortiz55
    Ramon
    Texas
    stock
    hmm
  9. Nov 17, 2016 at 12:27 PM
    Mush Mouse
    mush
    2013 SR5
    I had the same issue took the truck to the dealer and asked about it and they said charcoal canister, bought a canister from camelback Toyota, had the dealer install it no more issues
  10. Nov 17, 2016 at 2:54 PM
    Tacoma Mike
    Southern Maine
    Yeup good.
    Ok then have you filled this vehicle up and kept topping off???.
  11. Nov 17, 2016 at 2:55 PM
    ramonortiz55
    Ramon
    Texas
    stock
    I probably have. If I did, it's probably subconsciously, without me paying attention lol
  12. Nov 17, 2016 at 2:55 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Fuel filter?
  13. Nov 17, 2016 at 3:02 PM
    ramonortiz55
    Ramon
    Texas
    stock
    if it was the fuel filter, wouldn't the issue happen every single time?
  14. Nov 17, 2016 at 3:24 PM
    Tacoma Mike
    Southern Maine
    Oh crap
    I thought 93 not 2003.
    Dam it all sorry.
    Find the hoses from the canister and trace them up to the throttle body area.
    If you have a handheld scanner this will be ideal cause you may set a code.
    Disconnect the vapor lines from the canister and plug them. Both ways.
    Then go fuel the car up. See how it starts.
    If it's ok then like others have said it could be a saturated canister.
    A saturated canister is not uncommon and the symtoms vary greatly.
    Adding fuel changes air flow into the system. If you have a leaking canister valve internally you can cause issues be having the fuel back flow into the section normally holding vapor.
    Again sorry for the misinformation.
    I usually read a lot better than that.
  15. Nov 17, 2016 at 3:25 PM
    #35
    ManBeast
    Zach
    Orange Park FL
    Idk , all i know is i saw a video with a bad fuel filter and it flowed way slower
    Perhaps half tanks,? Or does it do it exclusively with any amount of new fuel
  16. Nov 17, 2016 at 3:39 PM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    A clogged fuel filter will evidence itself first at higher RPMs, but yet start and idle fine.
    Think about it. Partially blocked, reduced flow. Higher RPM wanting more fuel and not getting it, poor high RPM running.
    If you have a clogged filter that is so clogged it affects the idle, it won't get out of its own way in gear.
    His situation is too specific to be a fuel filter IMHO.
  17. Nov 17, 2016 at 4:10 PM
    #37
    ManBeast
    Zach
    Orange Park FL
    Does it only happen when its completely filled or when any amount of gas is pumped?
  18. Nov 17, 2016 at 4:11 PM
    #38
    ramonortiz55
    Ramon
    Texas
    stock
    any moment.
    ManBeast[QUOTED] likes this.
  19. Dec 1, 2016 at 6:39 PM
    #39
    caw001
    caw001 New Member
    Toyota Camry 2003 Sage
    I am having the exact same issue with a 2003 Camry V6. Also replaced the cap. Am taking it to my buddy to look at this weekend.
  20. Dec 1, 2016 at 7:45 PM
    #40
    ramonortiz55
    Ramon
    Texas
    stock
    Our Camrys are brothers :)
    Keep me updated please
