Camshaft Position Sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by JimBeam, May 17, 2012.
  1. May 17, 2012 at 9:27 PM
    JimBeam
    JimBeam [OP] BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    So apparently mine has a malfunction
    meaning I need to change it
    Anyone here done it? recommended place to buy the sensor? pictures of WTF it is and what is involved in changing it?
  2. May 17, 2012 at 9:36 PM
    JimBeam
    JB
    2015 Tundra
    gracias senor
    now...my check engine light came on and threw the code for that malfunction (p0340)...i cleared it but it came back on a couple days later
    obviously it needs to be changed...but how bad is that need? like before i drive it again or i need to get to it in the next couple weeks? or meh when i have time/money?
    Toyotapartsales has it for sale for $123.00 shipped...RockAuto has the delphi OEM for like $234
  3. May 17, 2012 at 9:44 PM
    JimBeam
    JB
    2015 Tundra
    what's odd...is that it comes on when i let the truck run and idle for extended periods of time...like in a drive-thru...
  4. May 17, 2012 at 9:45 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    check ebay....
  5. May 17, 2012 at 9:48 PM
    jesus
    jesus
    bakersfield
    i just did I check for Camshaft Position Sensor, tacoma 2002 ad there about 14 alot of them under $100
  6. May 17, 2012 at 10:01 PM
    JimBeam
    JB
    2015 Tundra
    i'm hesitant to use ebay these days...i'm a very untrusting person...i have a handful of internet vendors that I trust...and thats not one of them
  7. May 17, 2012 at 10:12 PM
    jesus
    jesus
    bakersfield
    I've have good luck with my stuff form ebay and most come with warranty:D just check part # and brand
  8. May 17, 2012 at 10:14 PM
    Rmesa1
    Rmesa1 Well-Known Member
    Any coolant leak these sensors are pretty reliable only time I have seen them gombadnis when the water pump is leaking and the sensor is contaminated with coolant. Sensor is easy to change just remove the top timing belt cover and you can get to it.
  9. May 17, 2012 at 10:27 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Do you think it might have something to do with your timing belt? Maybe skipped a tooth? Ive never heard of these sensors going for no reason
  10. May 17, 2012 at 10:34 PM
    JimBeam
    JB
    2015 Tundra
    current belt has been on for 2+ years and it doesnt seem to be running funny
    coolant levels are normal etc
  11. May 17, 2012 at 11:51 PM
    scocar
    scocar hypotenoper
    Stop going though drive-throughs. It isn't a cruiser built for donut runs.
  12. May 17, 2012 at 11:53 PM
    JimBeam
    JB
    2015 Tundra
    you hush your mouth! the cruiser doesnt hit drive-thrus
  13. Mar 19, 2013 at 6:37 AM
    budget76
    budget76 Active Member
    New Jersey
    98 xt-cab 4x4 4cl/2.7 stock man
    soon want dual lockers Picture was my 85 dual arb great
    just threw the p0340 cam position sensor code.
    Not taking chances new delphi cam position sensor on ebay $30 and new delphi crank position on ebay $50. have 130K miles on it and i want a trouble free 300K, so new parts always as time allows. I use this puppy (2.7 4wd) 750 miles a week and still searching that elusive 24MPG. maybe some day.
  14. Mar 19, 2013 at 7:57 AM
    BamaToy1997
    Bill
    Navarre, FL
    Jeff, I can get you a Toyota factory original cam sensor for $150 shipped to you as long as you are in the continental US.
  15. Mar 19, 2013 at 9:22 AM
    BamaToy1997
    Bill
    Navarre, FL
    By the way, a failed camshaft sensor on the Tacoma will not stop it from running. It will put it in an alternate fuel timing mode however, (AKA failsafe-mode). Can you drive with a failed sensor, yes. Is it a good idea? Not really, but then again, the choice is up to the individual owner.
    To test the camshaft sensor, you can disconnect the connector and measure the resistance of the camshaft sensor. On a cold engine the resistance should be between 835-1400 ohms. On a warm sensor it should read 1060-1645 ohms. A warm sensor is one that is between 122-212 degrees F.
  16. Aug 11, 2013 at 9:39 AM
    soup101
    soup101 Active Member
    Joe
    Maryland
    04 SR5 TRD DC 4x4
    OME 882 Coils, OME Dakars with D6XL AAL, Nitrocharger Sport Shocks, Sky Manufacturing rear axle relocation plate set 3/4 inch towards rear, BAMF BPV Relocation Bracket, Leer 100R Shell, Trail Gear Sliders, Trail Gear Low Profile Front Bumper, CBI Outback 1.0 Rear Bumper w/ tire swing-out, Cornfed Suspension Diff Drop
    While changing my timing belt, water pump etc. I managed to somehow put a small dent in my camshaft position sensor. Will this dent cause an issue? I don't want to put this all back together only to have to tear it apart again to replace this sensor. Thanks for any advice.
  17. Aug 11, 2013 at 2:48 PM
    soup101
    Joe
    Maryland
    04 SR5 TRD DC 4x4
    Decided I'll just replace it since I have it torn down. Pretty sure the dent would cause issues.
  18. Nov 23, 2021 at 11:20 AM
    Oceanbound86
    Oceanbound86 Member
    Bill
    07 toyota tacoma trd
    So I have been having the same issue with my 07 tacoma I initially replaced both sensors it got the light to turnoff for about a day then it came back on iv been digging in researching alot and iv learned that it could be a number of things causing the p0340 code so I had my friend hook it up to his professional code reader and it said that my passenger side air bag sensor was starting to fail and not read people in the seat and then he told me that could actually be the reason why I'm getting the cam position sensor code aswell I'm still confused on how this makes any sense but iv done just about everything to get the p0340 code gone and nothing has worked yet my truck runs completely fine except when she gets warm and driven for a bit sometimes takes longer to start sometimes it doesn't when it's cold starts no problem and evan the light is gone for a few hours so I guess I'll replace that sensor and see if it does have an affect to the p0340 code anybody ever heard of this?
