Can 6-1/2" Speakers fit Access Door mount?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by khfactor, Feb 9, 2008.
  1. Feb 9, 2008 at 2:30 PM
    khfactor
    khfactor [OP] Well-Known Member
    Philadelphia, PA
    07 White TRD Sport
    Pop N Lock + Hose Clamp. DTRL, AFE drop-In Dry filter, 6-1/2" Replacement Speakers, JVC HD Radio, Sam's club variety Floor mats (cheap but effective), Chrome Exhaust tip, Bed Mat from ol' Ford Ranger. As of 3/25/2020, the Odometer just turned 70K.
    I checked the Crutchfield web site and it said that only 5-1/4" will fit the factory cutout for the Access door speakers. I want to go with a larger size speakers for bass and what not.
    Can I use the 6-1/2" Diameter speakers? Any good recommendations? I like Pioneer or Kenwood (trying to stay within $100 max.)...
    Thanks.
    I know I will need an adapter for the speakers. If 6.5" will fit, then I may just get the speakers from Crutchfiled despite what the Crutchfield web says. I want the free adapters and speaker wiring harness...
  2. Feb 9, 2008 at 3:08 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    6 1/2s fit on ********* mounts. I suspect that crutchfield says 5 1/4 or whatever because that is what the mounts they have made is designed around. It would be cost prohibitive for them to have mounts in every possible size, and if they use the same mount in other vehicles that are designed around 5 1/4" speakers then that is what they stick access cab taco owners with.
    Having never seen the included crutchfield mounts perhaps they could be modified to take 6 1/2" speakers though.
    As for speakers I have always been happy with pioneer ts-a series speakers. I believe the current model number is a 1672R for a 6 1/2" speaker.
  3. Feb 9, 2008 at 3:15 PM
    PatheticJoe
    PatheticJoe Well-Known Member
    Sacramento, CA
    07 Prerunner SR5 TRD Sport - Access Cab
    Pioneer speakers are the best choice for the money in my opinion. Go with the ********* adapters and you should be fine with mounting 6.5s.
  4. Feb 9, 2008 at 6:07 PM
    khfactor
    Philadelphia, PA
    07 White TRD Sport
    Hi,
    Just checked the price on Crutchfield and the Pioneer TS-A1672R is $79.99 + $7.00 shipping. Also checked Newegg.com and they are $49.00 with free shipping.
    Guess where I clicked? Now, I need to secure a pair of speaker wiring harness. Where can I get them? Does Scoche or Mitra carry speaker wiring harnesses for 2007 Tacos?
    I realize that I can get them thru ********* with the adapters. But if I do not get the ********* adapters, is this something I can easily pick up at Circuitcity or Walmart???
    If anyone know the Scoche part # or Mitra part #, that would be a great help... Thanks..
  5. Feb 9, 2008 at 10:05 PM
    maverick491
    South Jersey
    Scoche part number SHTA02B
  6. Feb 10, 2008 at 12:51 PM
    khfactor
    Philadelphia, PA
    07 White TRD Sport
    Thanks for the Scoche part #. :)
  7. Feb 10, 2008 at 1:48 PM
    Fyr Lt
    Fyr Lt Member
    Florida
    2006 Tacoma SR5 V6 w/Borla exhaust, TRD and Aero Package
    Double Din Kenwood, 2 IDQ10's pushed by solo kicker sub. Focal components front and rear pushed by single Alpine, Capacitor, rearview camera, and still adding more.. Nexus gauge cluster in the worx (hard to find what i'm looking for).
    Hey Khfactor, you can put 6 1/2'' speakers and or components in your doors. You'll have to modify the brackets from ********* a little bit. You can check out the pics of my install for suggestions.
  8. Feb 10, 2008 at 5:00 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    I ordered the pioneer TS-A6972R 6x9" and the TS-A1672R 6.5" from radio shack for $60 and $50 each. This compares to $100 and $80 at best buy, curcuit city, and crutchfield. Ordered the Taco tunes mounting kit as well. Let you know how the install turns out. I plan on keeping the stock 6-disk head unit which I understand is Pioneer as well. Anybody know for sure? May install a amp. later but will decide after the speakers are installed. Later
  9. Feb 11, 2008 at 3:36 PM
    khfactor
    Philadelphia, PA
    07 White TRD Sport
    I am also interested in adding an AMP to the stock 6-CD headunit. If you get this combination, please let me know what type of Amp you got and how you hooked it up. Pictures would be great also....
