Can a soft front suspension cause wear on the outside of the front tires?
Discussion in 'Wheels & Tires' started by pidro_el_pirata, Feb 17, 2013.
  1. Feb 17, 2013 at 1:40 PM
    pidro_el_pirata
    pidro_el_pirata [OP] Well-Known Member
    Can a soft front suspension cause wear on the outside of the front tires? I just got my tires aligned and the alignment was relatively good but the outsides of the front tires were more worn compared to the inside. Trying to figure out what could cause the wear since the alignment was good.
    My rear shocks were replaced within 50,000 miles but I don't think the front shocks have ever been replaced. There is no doubt that they do need it- I'm the second owner and the truck has 139k on it.
  2. Feb 17, 2013 at 7:38 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, HomerTaco Raptor grill, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Toyo AT2, Avid light bar
    Not sure if its the same but when I had my Mustang my wife thought she was in the Daytona 500 all the time. She wore the outside edges off from driving so fast through turns. When I took it in for tires, the shop thought alignment was bad, but it was fine.
  3. Feb 17, 2013 at 7:49 PM
    Mr. Biscuits
    Mr. Biscuits gentleman, scholar, part-time delinquent
    Brennen J
    Bakersfield
    2000 PreRunner TRD V6
    -Bilstein 5100/ Eibach 3" lift -Custom 2" lift rear leaf pack -Crystal clear headlight housings -updated (01-04) rear tail lights -custom front tube bumper -custom rear tube bumper -Deckplate mod -Aero Turbine 2525 exhaust -Kenwood Headunit -Pioneer Speakers -black door handles -Debadged, rebadged black -Ultraguage
    The outer tread will always wear faster than any other part of the four tires because of ^that. Even if you don't take corners quick it's still going to wear because all the weight gets thrown to that tire in a turn. If it's bad rotate the rears tires up and fronts swap sides in rear
  4. Feb 17, 2013 at 8:16 PM
    pidro_el_pirata
    Yea I had them rotated so they will even out. I was just wondering about the technical aspects of the suspension affecting the wear.
