Can anyone tell me what's going on with these spark plugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by devldogs55, Oct 21, 2012.
  1. Oct 21, 2012 at 4:19 PM
    devldogs55
    devldogs55 [OP] Member
    2007 Tacoma 4x4 V6
    Well I did a bit of a tune-up today and changing the spark plugs was on the list. It's on a 2007 Tacoma V6 4x4.
    Here's a couple of the plugs I pulled out. All plugs looked like the first two pictures, but the driver's side plug closest to the rear of the truck (don't know the # of the cylinder) was a little wet. It was the only one that was wet though.
    Plugs likely hadn't been changed EVER. They were the typical Denso on one side and NGK on the other which I've only ever seen done by the factory, and the truck has about 80k miles on it. My guess is those plugs have 80k miles on them as well.
    Also it's "interesting" to note that all of the old plugs were eroded away so much that the gap was over .060 on all of them. One was as much as .075 !
    No wonder my mileage was so bad!:mad:
    And the wet one
  2. Oct 21, 2012 at 4:22 PM
    98tacoma27
    Ben
    Not Beech Creek
    Looks like normal wear. Is that oil on the bottom one? Smell like gas?
  3. Oct 21, 2012 at 4:39 PM
    dalesrn
    dalesrn Tacoma TSS
    Dale
    Southeast Louisiana
    2008 Tacoma PreRunner DC with TSS Package
    Borla exhaust system, Sirius Satellite Radio, Chrome package, Trailer Hitch, Clazzio Leather seat covers, TSS badging, Anytime on fog lights mod, Daytime driving lights mod, Dual backseat DVD players w/monitors, 3rd Brake Light "TSS" mod, Bed pocket lights mod, Seat belt chime mod, Bed storage compartment auxillary outlet mod, Shorty antenna, Armor Lid Tonneau Cover, Line of Fire tailgate light
    sub'd
  4. Oct 21, 2012 at 4:50 PM
    badger
    badger Well-Known Member
    07 SR5
    Was the oily plug loose? I've found 2 things. First, plugs in these trucks and some other vehicles that I've had can come loose over time. I think it is probably the difference in expansion between the aluminum head and the plug causing that. I've never seen it happen in a cast iron head. Second, the recommended service interval is too long for my taste. I pulled mine last time at 40K instead of 30K because I was driving thousands of highway miles and the ODO racked up before I could get the work done. The erosion at 40K was way more than I expected. None of the plugs were at full torque either. I plan to pull mine at 20K this time, and will probably stick with a 20K service interval.
  5. Oct 21, 2012 at 4:57 PM
    devldogs55
    2007 Tacoma 4x4 V6
    None of the plugs were lose - and it smells like gasoline. Thanks for that chart too! It'll save me some searching next time.
  6. Oct 21, 2012 at 5:40 PM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
  7. Oct 22, 2012 at 7:21 AM
    devldogs55
    2007 Tacoma 4x4 V6
    I cleaned the MAF and the throttle body yesterday (same day as plugs). I basically followed the writeup here on this board to the T.
    Big thanks to genxer36 and chris4x4. Doing either job isn't hard but I've never done it on the 4.0 before. I'm still used to the 3VZE, so having those writeups was awesome.
  8. Oct 22, 2012 at 7:28 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    That looks like normal wear for a plug with that many miles on it. That's a LONG time to go without changing them, I'd guess you'll see some pretty noticeable improvements after your new ones.
  9. Oct 22, 2012 at 7:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    ^^This is what I'm thinking. The plugs in the V6 are supposed to be changed every 30k miles so considering your truck went more than double the recommended interval, it's not surprising they don't look great. To me, for the number of miles on those plugs, they don't look THAT bad.
  10. Oct 22, 2012 at 7:56 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Based on what I've gathered over the years (many threads and my own plug changes) the rear most driver side plug seems to consistently be the dirtiest on these engines, so I wouldn't be too concerned about that.
  11. Oct 22, 2012 at 8:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^
  12. Oct 22, 2012 at 8:18 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    This This ^^^^
