Can I add a 1/4" spacer to correct my lean even if I already have a spacer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DestinTaco, Jun 7, 2011.
  1. Jun 7, 2011 at 6:52 AM
    DestinTaco
    DestinTaco [OP] Well-Known Member
    Destin, Fl
    2011 Silver PreRunner Off Road DC SB
    Challenger tube step, OME 884 Coil, 2" AAL, Weathertech vent visors
    Probably a dumb question but currently have 884's with top plate spacer. Can I add the 1/4" spacer on the driver's side to correct the lean? Would it go right on top of the other one? Thanks.
  2. Jun 7, 2011 at 6:59 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You should be able to add the trimmer pack by OME. I dont think its quite 1/4" of a spacer. Look it up.
  3. Jun 7, 2011 at 7:06 AM
    DestinTaco
    Destin, Fl
    Problem is I don't have OME shocks. The toytec site says they only work with OME shocks.
  4. Jun 7, 2011 at 7:09 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Ah okay I didnt know that. But adding another 1/4" spacer sounds shady. I'm sure someone will chime in.
  5. Jun 7, 2011 at 7:16 AM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Yeah dosent sound too good. Like W W said, if younhad the OME shocks, you could add the trim packer. It goes between the lower spring perch and the so ring. It will correct the lean a little
  6. Jun 7, 2011 at 7:19 AM
    DestinTaco
    Destin, Fl
    Ok...sounds like there may not be a solution. Oh well, it really doesn't bother me, I just didn't know if that would work or not. It's barely noticable.
  7. Jun 7, 2011 at 7:51 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    You'll get over it. It bothered me to after I installed my lift but I could care less now.:cool:
  8. Jun 7, 2011 at 8:57 AM
    TRDSPORTtaco
    TRDSPORTtaco Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    How big is the spacer on right now?
  9. Jun 7, 2011 at 9:12 AM
    DestinTaco
    Destin, Fl
    about 3/4".
  10. Jun 7, 2011 at 9:13 AM
    DestinTaco
    Destin, Fl
    Is the lean a result of the lift I got or did it come off the line that way? I don't remember noticing it when I first bought it, but that doesn't mean it wasn't there.
  11. Jun 9, 2011 at 8:19 AM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    The 884's are not setup like the stock coils where the driver side is stiffer than the passenger side. I have 885's on my DCLB and the only way I could correct the lean is by putting the toytec 1/2 inch spacer on the driver side and 1/4 inch on the passenger side to help even it out yet give lift.
