can i add transmission fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RDAY, Mar 9, 2010.
  1. Mar 9, 2010 at 11:23 AM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    I made a mistake and pulled the transmission bolt instead of the oil bolt but seen the color of it so i put it back on i prolly lost a quart or 2 tho. Can I add some more like 3 quarts to be safe and then just pull the over fill plug to let the extra come out. And do this without having to check the temperature of it?
    Also does anyone have a pic where the transmission fill cap is?
    Thanks guys!
  2. Mar 9, 2010 at 11:31 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
  3. Mar 9, 2010 at 11:53 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
  4. Mar 9, 2010 at 11:57 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Yes you can. Just have to full it through the over flow plug. When it starts to come out it is full. There is no fill cap for the tranny it is a sealed system. You just pump it in through the overfill plug.
  5. Mar 9, 2010 at 12:02 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    so u pump it in through the overfill plug underneath the truck that is like a 5mm plug or something? and what do i need so that i can pump it in?
    Thanks
  6. Mar 9, 2010 at 12:03 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Read the link I posted. There's a lot more to it than just adding fluid (make sure you use the correct fluid..............................................................)
    You have to ensure you have the correct level... which means using the diagnostic mode. Read the link, it's not to hard but you can't skip anything.
  7. Mar 9, 2010 at 12:44 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    so I just cant just add some i have to drop all the existing and do everything the link says even tho the stuff i have in it is still good?
    how much does the dealer charge to change the fluid?
    Thanks
  8. Mar 9, 2010 at 12:49 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Truth be told, I'm sure it will be fine if all you do is replace the same amount that came out. Buy a bottle pump, it's fairly easy. Read the link that was posted, lots of info there.
  9. Mar 9, 2010 at 12:52 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    FYI, dealers will charge about $190 for the tranny flush.
  10. Mar 9, 2010 at 2:24 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    You know I was under the truck today and did an oil change.
    All I can say it I hope you don't do any other mods or service.
    It is hard to make this mistake ... real hard.
    Kind of like a surgeon taking off the head when the left foot was scheduled for removal .
    I give you credit for trying but you loose points for not asking first if you are this unsure of what to do.
    If you do any more work ask first ......... JMO
  11. Mar 9, 2010 at 2:35 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    no dont pump it through the check plug...
  12. Mar 9, 2010 at 4:10 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Right,
    wrong,
    wrong,
    wrong,
    wrong,
    wrong.
    I'd stick to offering advice on things you know. This way if your info is incorrect, it won't cost someone else $4000 to fix a problem due to misinformation.
  13. Mar 9, 2010 at 4:13 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Please give a reason as to why not to fill it through the overfill plug! If you feel the need to post with out reason please don't as it is not funny he is asking for help. Now if you have a legitimate reason you should have posted it a few hours ago.
    If I were you I would top it off using the over fill plug. You just drained some there is no need to follow all of the instructions in the link, which is a very good link and is how to drain and replace the fluid, but in your case just top it off. This is how your dealer will do it when you show up but charge you a ton.
  14. Mar 9, 2010 at 4:14 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Well then please give the correct info. As this is how the dealer will top off your fluid. I have read all of your how to about it, and I agree completely with you about swaping fluid. But as per my dealer they just fill it as I have stated. Now they may be incorrect but my truck is fine and I had this done in 2007
  15. Mar 9, 2010 at 4:19 PM
    Fortech
    CANADA
    There has been a link posted with the correct procedure for the OP to follow so his question has been answered - with a detailed procedure with pics and video.
    You don' fill from the overflow plug because that isn't the correct procedure. There is a FILL plug for that purpose. If you fill from the overflow the level won't be correct, and it is much simpler to fill the correct way. If he don't want to drain that's fine. Skip to the part about adding fluid. The tranny costs $4000 to replace. Perform the procedure correctly.
  16. Mar 9, 2010 at 4:22 PM
    Fortech
    CANADA
    The correct info is in the link provided, which I wrote and performed many times, according to the Toyota factory Service Manual - which is they way the dealer would do it, and Toyota recommends. Is this good enough or do you need more?:rolleyes:
    You don't fill from the overflow plug. You fill from the 24mm fill plug on the top right side of the transmission.
  17. Mar 9, 2010 at 4:24 PM
    dog tired
    NE Ohio
    The guy can't do an oil change -- do you feel comfortable with him doing the trans refill ?
    I do not mean to slam him but ........ @ 4000.00 for a trans replacement just let him tow it in to a shop for repair
    JMO
  18. Mar 9, 2010 at 4:25 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Well then OP please follow their instructions as I certainly would not like you to harm your vehicle. The steps I told you to perform are the ones that were done by my dealers on my truck some 3 yrs ago.
    Please don't think I am saying the other way is incorrect because I certainly am not.
  19. Mar 9, 2010 at 4:26 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    This is the exact same thing I did when I did my first oil change. Listen to Fortech, he knows what he is talking about.
  20. Mar 9, 2010 at 4:27 PM
    Fortech
    CANADA
    He asked, the correct info was given. What he wants to do with it is up to himself. Every backyard/professional mechanic had to start somewhere.
