can I drive without the front drive shaft?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Mar 2, 2011.
  1. Mar 2, 2011 at 5:30 PM
    ywen
    ywen [OP] Well-Known Member
    want to replace the u joints on my truck, truck is a like an old jalopy at the present.
    I've never replaced u joints before so I want to start with the front driveshaft so at least I can drive the truck without it being in 4wd.
    Then I thought, what's at the front diff input and transfer case output after I pull the DS? I'm assuming I don't want those parts exposed too long to the winter elements?
    Is driving without a drive shaft only recommend to diagnose issue? Or can I realistically drive for a while without a drive shaft?
    Oh and how much would it be to pay a shop to replace a u joint?
  2. Mar 2, 2011 at 5:35 PM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    i wouldn't do it cause im pretty sure you'll piss all you t-case fluid out the open out put shaft. i would just leave it and get some new ones on the way and change em out in one day.
  3. Mar 2, 2011 at 5:36 PM
    ywen
    so that's my other ques... does fluid come out of the diff and transf case after I pull the DS?
  4. Mar 2, 2011 at 5:49 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    not necessarily tacos, but ive known people that drove without the front drive shaft. . . the only problem i believe where that would happen would be on an AWD vehicle like the jeep GC's for instance (had one and found out!) . . . but yeah just keep in regular ole high gear 2WD and it should be fine.
  5. Mar 3, 2011 at 9:09 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Yep. There are 4 bolts/nuts on each side of the DS. I removed mine (both front and rear) when I dropped the transmission to change the clutch. Just make sure you bolt it back on in the right orientation (I think it's not totally symmetrical).
  6. Mar 3, 2011 at 9:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Pre-Runners do it all the time :D
  7. Mar 3, 2011 at 9:12 AM
    jandrews
    '09 FourDubDee TRD OR
    You'll be fine.
  8. Sep 28, 2011 at 6:43 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    make sure u dont put it in 4wd!! other wise u should be good
  9. Sep 28, 2011 at 10:58 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    It's fine you won't lose any fluid and you can put it in 4wd if you want too.
  10. Sep 29, 2011 at 9:52 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    ^ this. You can put it in 4WD, but obviously it's not going to work. There are no seals on the drive shafts so you will not lose fluids from either the diff or the t-case.
  11. Sep 29, 2011 at 10:32 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Why would the case or pinion side leak if you took the driveshaft out?
    Lolz.
    That'd be weird if it was designed like that.
