Can I make the hi beam indicator light dimmable?
Discussion in 'Arizona' started by bkrdave36, Apr 19, 2013.
  1. Apr 19, 2013 at 10:49 PM
    bkrdave36
    bkrdave36 [OP] Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Daystar 3 inch lift, BFG All Terrain KO Tires, Avid Light bar and step rails, custom made bed rack with Tepui Ayer Rooftop Tent, BHLM, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod,Rigid Knockoff LED Floodlights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper. thats it so far .... to be continued!
    Is this possible? I hate that its the only light that doesn't dim.
  2. Apr 19, 2013 at 10:49 PM
    bkrdave36
    Dave
    Wittmann,AZ
    On my 2006 Gen 2 DCSB
  3. Apr 19, 2013 at 11:09 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    Why would you want to dim the high beam indicator? :confused:
    Do you drive with the highs?
    edit: im guessing you mean the low beam indicator and if so no you camnot dim it
  4. Apr 19, 2013 at 11:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Remove it, then move the dash illumination to the HVAC illumination on the back of the dimmer.
    Dash lights off when the headlights are off, on with the headlights, and no stupid light bulb.
  5. Apr 20, 2013 at 9:20 AM
    Aw9d
    Aw9d That one guy
    Az
    You can swap the LED to a different color. I run all UV leds in my gauge cluster and its very dim. Tacosunday can help you out with that. He has a LED thread and does good work.
  6. Apr 21, 2013 at 2:52 PM
    bkrdave36
    Dave
    Wittmann,AZ
    The blue light that comes on when you hit the high beams. Thats the one I want to be on the main dash light dimmer.
  7. Apr 21, 2013 at 3:03 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    ^^This. Tacosunday replaced the leds in my truck and he also took out the chime and some other lights that I didn't care for.
  8. Apr 21, 2013 at 3:24 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    then you would need to figure out which wires that go into the cluster to tap into to make it all happen...
    but why would you want that light to dim with the rest? :notsure: :confused:
  9. Apr 22, 2013 at 9:21 PM
    bkrdave36
    Dave
    Wittmann,AZ
    Because when I dim the dash lights I have this bright blue beacon shining right in my face. It defeats the purpose of dimming the dash lights when I'm road cruising for snakes!
  10. Apr 22, 2013 at 9:23 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Gaffer's tape.
    Black, won't leave a residue.
  11. Apr 22, 2013 at 9:23 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    i see...damn i never noticed it being that bright...:notsure: im stumped
  12. Apr 23, 2013 at 9:49 PM
    bkrdave36
    Dave
    Wittmann,AZ
    TacoSunday sent me a link to a thread he has. Until I decide, I just put a piece of tape over it.
